Go Back   Nissan 240SX Forums > General Section > Multimedia Section > 1989-1994 240SX (S13)
1989-1994 240SX (S13) Post your cars and Projects here S13s only
Old 11-15-2009, 04:35 PM   #1 (permalink)
Red Dragon is on a distinguished road
Points: 568, Level: 11
Points: 568, Level: 11 Points: 568, Level: 11 Points: 568, Level: 11
Red Dragon: Project 240SEX-E Coupe
This is my 240SX Drift Project. She looks a bit rough right now but she will get a fresh coat of matte black paint in the summer. I plan to do a SR20DET swap first.
My modification plans
- Matte Black Paint Job
- S13 SR20DET Motor and Transmission
- 6 Point Roll Cage
- Coilovers (Apexi N1)
- Sway Bars
- Energy Bushing Kit
- Hydraulic E-Brake
- Front Brake Line Lock
- VLSD Differential
- 17" or 18" Mesh wheels + tires
IF YOU HAVE A HUD SPEEDO SEND ME A PM!
I NEED LOT OF PARTS so it you have parts that can benefit me for sale, PM me!
Parts Needed (aftermarket):
-Front Mount Intercooler Kit
-Downpipe
-Turbo Elbow
- Boost Gauge
- Air/Fuel Gauge
- Flywheel
-Fuel Pump (255)
- Hydraulic E-brake
- Front Brake Line lock
- Wheels (Mesh or multi-spoke)
- Short Shifter
- Sway bars (aftermarket)
- Strut Bars, bracing, control arms, tie rods, Etc (anything suspension related)
OEM Parts Needed:
-Power Steering Lines from DUAL CAM KA 1991-1998 Hi-Pressure and Return
-Radiator + Electric Fans + Hoses Kit (compatible with SR20 and S13)
- VLSD Differential
- Speedo (HUD)
1989 Nissan 240SX - XE Coupe - Grey
2.4L KA24E S13 - Zenki
Modifications
EXTERIOR
INTERIOR
ENGINE & DRIVETRAIN
Custom Catback Exhaust
WHEELS & SUSPENSION
Red Dragon is offline   Reply With Quote
Old 11-19-2009, 02:02 PM   #2 (permalink)
driftr240sx's Avatar
driftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthydriftr240sx The posts made by this user are trust worthy
Points: 54,064,011, Level: 100
Points: 54,064,011, Level: 100 Points: 54,064,011, Level: 100 Points: 54,064,011, Level: 100
Liking the Coupe and Good Luck on the build
ライブドリフト
Chuki Fan #98
driftr240sx is offline   Reply With Quote
Old 11-19-2009, 02:06 PM   #3 (permalink)
The Canadian Enforcer
boxfresh's Avatar
boxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthyboxfresh The posts made by this user are trust worthy
Points: 2,147,495,009, Level: 100
Points: 2,147,495,009, Level: 100 Points: 2,147,495,009, Level: 100 Points: 2,147,495,009, Level: 100
Activity: 99%
i think your car likes me, she's winking at me. jk good luck on the build! sounds like it'll be pretty sick
boxfresh is offline   Reply With Quote
Old 01-23-2010, 01:55 AM   #4 (permalink)
Update January 22 2010.
A little update on the project.
I sprayed the car with some Rust black paint to cover up the primer. I plan on repainting the car matte black in the summer time. So its just a temporary fix.
I also sprayed the under body of the car with some under body coating.
I got my 1997 S14 Sr20det from JMI Japan Motor Import. Great people to deal with. Shipping was very fast.
I order some parts off frsport.com and ebay.
$1400 worth of parts.
I have clean up the sr20 motor and replaced the gaskets in the motor. Hopefully i can pull the ka24 out and get the SR20 to run during spring break. Stay tune.
Want to Buy Parts: If you have them, shoot me a PM
SR20DET Camshaft Cap Bolts. I need 2 Medium Bolts (2.25 in) and 2 Short Bolts (1.5 in). Or the entire set.
OEM VLSD
Power by Max Coilovers
Front Mount Intercooler S13
Intercooler Piping Kit S14
BOV
Hydraulic E-brake
Line Lock
OEM Radio/CD player
Rims: 17X9 (offset range 10 to 30) 4X114.3
Tires approx size: 215/40R17 to 235/40R17
Mod List
Exterior
Custom Paint Job!
Interior
Air Spencer CS-X3 Squash
Engine
S14 SR20DET Kouki Swap
OEM Nissan 300ZX Fuel Filter
NGK Iridium IX Spark Plugs Heat 7
Circuit Sports Stainless Steel Rocker Arm Stopper
Top Fuel Zero 1000 Air Filter
Spec Stage 3 Clutch
Circuit Sports Radiator Hose Kit
Megan Racing Aluminum 3 Row Radiator
3" Downpipe
3" Test Pipe
Walbro 255LPH HP Fuel Pump
2X 12” Radiator Slim Curved Fan
ARP Engine Head Stud Bolt Kit
Drivetrain
Hawk HP Plus Front Brake Pads
Hawk HP Plus Rear Brake Pads
DIF Stainless Steel Clutch Line
Suspension
Tein Inner Tie Rod
Tein Outer Tie Rod
Wheels & Tires
15” Tear Drops Rims
Old 01-23-2010, 02:21 AM   #5 (permalink)
fonix36's Avatar
fonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthyfonix36 The posts made by this user are trust worthy
Points: 1,855,449,334, Level: 100
Points: 1,855,449,334, Level: 100 Points: 1,855,449,334, Level: 100 Points: 1,855,449,334, Level: 100
Activity: 21%
Activity: 21% Activity: 21% Activity: 21%
are those boltons i see
Build thread Updated CLICK ME
http://techgeekandmore.com/ <--- click me
Originally Posted by Panda-Eats-240 View Post
naughty naughty fonix
fonix36 is online now   Reply With Quote
Old 01-24-2010, 11:53 AM   #6 (permalink)
ooo fonix caught you lol jk
Nice are you planning on upgrading the turbo?
Or are you just gonna run the t25?
lookin good
ライブドリフト
Chuki Fan #98
Old 01-24-2010, 04:33 PM   #7 (permalink)
^Sorry but i dont understand??
Na i will be sticking with the stock turbo for now. Maybe next year.
Old 01-24-2010, 11:13 PM   #8 (permalink)
He means you have a bunch of boltons in the picture with all the parts
ライブドリフト
Chuki Fan #98
Old 06-11-2010, 10:57 PM   #9 (permalink)
She Alive!
Check out my For Sale thread, for SR and KA parts.
CA KA24E and parts. SR parts. Canada - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum
Old 06-11-2010, 11:03 PM   #10 (permalink)
boxfresh's Avatar
Activity: 99%
looks like a pretty clean swap! good job
Originally Posted by ic2drop View Post
Eventually, everyone gets their penis slapped for posting something dumb... the question is: when?
Old 06-12-2010, 05:57 PM   #11 (permalink)
Miniksa's Avatar
Miniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthyMiniksa The posts made by this user are trust worthy
Points: 63,696,186, Level: 100
Points: 63,696,186, Level: 100 Points: 63,696,186, Level: 100 Points: 63,696,186, Level: 100
Thats a nice swap man!!
I'm a noob watcha going do?!!?1
Miniksa is offline   Reply With Quote
Project 240sex-c s13_fiend 1989-1994 240SX (S13) 29 04-23-2009 09:48 PM
new coupe project zenki24de 1989-1994 240SX (S13) 3 12-17-2008 05:55 AM
My S13 coupe project GregFarz78 1989-1994 240SX (S13) 8 05-05-2008 09:31 PM
my 89 coupe ... project studgus 1989-1994 240SX (S13) 45 03-24-2007 02:22 AM
1991 Nissan 240sex coupey *56k=death* nessiehaze Cars For Sale/Wanted 17 08-17-2006 10:51 PM
