1995-1998 240SX (S14) Post your cars and Projects here S14s only
01-03-2010, 03:53 AM
#1 (permalink )
240SXForums Slut
214749270
Points: 2,147,663,153, Level: 100
240-kid's Daily Driver (ST Class Build)
Lol, I thought I'd never make a build thread lol, but here it is.
Main reasons I'm making this build thread is:
1. Some of you may know some not but my car recently had a Hit and run in the parking lot while I was away, There's a hole in my bumper and my trunk doesn't close properly.
2. Now that I have a "Real" job I can actually support this thing a do shit right
Here are my Plans so far for Starters but there's much more on paper then this...
Engine :
eBay 70mm CAI (Installed): Gonna coat it with Dupli-Color
Bed liner and Top it w/ a coat of
Satin Black to give it an OEM Plastic Look
Fujita 3" Filter
S13 Cams (Bought, Needs to be Installed | Installing in Stock 240/248 Configuration)
OBX LW Underdrive Pulley Set
MR 3" Test-Pipe: Gonna replace w/ the Courtesy 80mm Resonated piece to clean up the Rasp that may because by the DP and for the extra .15" of Flow
lol
Courtesy Parts 80mm Down-Pipe &
Resonated Test-Pipe
Blitz Nur Spec-R 80mm Exhaust (Installed)
Dynomax Black Exhaust Hanger Bushings
Nismo Mounts
Custom Ground Kit
Drivetrain :
Z1 Performance 14lbs Flywheel
Z1 Performance Carbon-Kevlar Clutch (Currently using Centerforce Stage 1)
ER 15lbs 1pc Steel D/S
Nismo Mount
Suspension : Currently Koni Yellows w/ Tanabe GF210 Springs
ES Bushings
ES Steering Rack Bushings
Stance LX Coilovers (Waiting for Quotes)
SPC Arms:
Tension
- Traction & RUCA Combo:
Driver |
Pass.
Toe-Rods
PBM 7mm Tie-Rod Spacers
Project Silvia Tie-Rods
Perma-Cool P/S Cooler : I need to keep that P/S Boiling before we have a fire...
Brakes :
Q45 Front Brakes
Portfield R4-S Pads Front &
Rear
SilverMine Motors Front 11" Q45 Rotors (4 & 5-Lug Pre-Drilled)
R1Concepts E-Line Drilled & Slotted
Agency Power Braided Lines
Wheels & Tires :
Kei-Office Wheels: Might upgrade to FN's if I do a 5 Lug Swap
17x7+32 Front & 17x8+32 Rear (Installed)
Powder Coat Wheels: White
Ichiba Studs & Spacers: 20mm Front & 15mm Rear (Bought, Needs to be Installed | +12 & +17 Effective Offsets)
Sumitomo HTR Z III's : Good combo of Grip, Price, & Life
215/45/17 Front & 235/45/17 Rear
SCCA ST Class Set-Up :
Enkei Black RPF1's:
16x7+25 - 13.7lbs ea.
Switch Spacers around 15mm Front & 20mm Rear
Kumho Ecsta XS's: Not the best in this category but it's fairly cheap and it will give me more then enough grip
225/50/16 - 22lbs ea.
Interior :
RedlineGoods Black Leather Shift & eBrake Boot
Yashio Factory Shift Knob (KAT0 & unreal- Know how sexy it is
Old Alpine H/U: Upgrading to a
9886 when the time comes
Alpine Type-S 6.5" Front Components : (Installed) Rears were removed
Pioneer 2 Channel Amp
Exterior :
Used Trunk (Having thoughts on a Seibon CF Piece if the Paychecks permit...)
Used Rear Bumper
Re-Finish Clear Coat
Home Depot Front Lip v.2
eBay Clear Side Markers
LED Lighting A.A. Front
AutoLumination
Rear Damage:
Thanks for lookin...
Edit: Just for fonix...
Get your shit Straight!
01-03-2010, 03:55 AM
#2 (permalink )
240SXForums Slut
214749270
For the Stance Coilovers I'm waiting for quotes from IntensePower and MVP Motorsports
01-03-2010, 03:59 AM
#3 (permalink )
0
Points: 361,087,120, Level: 100
mmm tow hitch dmg
what color is the rest of the car?
01-03-2010, 04:04 AM
#4 (permalink )
240SXForums Slut
214749270
Yep, tow hitch owned my bumper...
The cars Ruby Pearl:
240-kid's Garage :: My DD/Experiment SX
01-03-2010, 04:07 AM
#5 (permalink )
185543393
Points: 1,855,449,334, Level: 100
and why is that the only picture you put up
01-03-2010, 04:13 AM
#6 (permalink )
240SXForums Slut
214749270
Cause my car has looked the same for about a year now... lol
Fine I'll put pics up just for you fonix...
01-03-2010, 02:14 PM
#7 (permalink )
0
Points: 574,627,757, Level: 100
damn sorry to hear about the hit and run, that sucks ass but im glad you are finally going to do what you really want to the car.
im subscribing, i know this will be a sweet build.
if i would have known that you will be getting a lightweight drive shaft i would have sold you mine drive shaft shop steel one for cheap but oh well cant do nothing about it now.
good luck on the build and take your time on it
FairLady Z
01-03-2010, 02:17 PM
#8 (permalink )
240SXForums Slut
214749270
Yeah, but shit happens, it just sucks when it happens to you...
That would have been nice lol, but oh well
Also IDK about this being a sweet build lol. It'll be nice but nothing too fancy.
The real project starts after this one is finished...
It'll be a Sleeper N/A KA in Stage one, then a 350whp Turbo Sleeper in Stage 2. It'll be fun...
01-03-2010, 02:19 PM
#9 (permalink )
0
Originally Posted by
well see i knew it will be nice, with the knowledge you have and experience with your car it will be nice. it will just take time.
FairLady Z
01-03-2010, 02:30 PM
#10 (permalink )
240SXForums Slut
214749270
I suppose
Stage 2 should be an animal though lol, Full boost by 2700? WTF hahahah
01-03-2010, 03:40 PM
#11 (permalink )
0
I suppose
you will be driving beside a ferrari and your car will pull this number on it
FairLady Z
01-03-2010, 05:27 PM
#12 (permalink )
240SXForums Slut
214749270
I hope so
01-03-2010, 06:24 PM
#13 (permalink )
240SXForums Slut
214749270
Post 1 updated
01-04-2010, 01:24 AM
#14 (permalink )
240SXForums Slut
214749270
Get paid on, Tuesday. Hopefully it's as healthy as I'm hoping
01-04-2010, 02:37 AM
#15 (permalink )
0
Clean Car, looks like its off to a good start. Hey, they still serve chili over spaghetti noodles on the island?! haha
01-04-2010, 02:46 AM
#16 (permalink )
0
Points: 353,953,440, Level: 100
nice build thread. ive been thinking about starting one as well. and sorry to hear about the hitch damage. damn rigs need to watch where there goin
01-04-2010, 02:57 AM
#17 (permalink )
240SXForums Slut
214749270
reckless13
Yes they do lol, LMK if your coming down and we can meet up...
carps13guy
Thanks. and yeah, bet the guy either 1, didnt notice, or 2, called my car a ricer and drove off...
Did a rough estimate on my build cost: ~5500(+/- 100) Including shipping of products.
Not too bad IMO
01-04-2010, 02:58 AM
#18 (permalink )
u iz gonna get raped!
214749004
Points: 2,147,508,660, Level: 100
lookin good scoot
Let me know how you like your 240/248 swap, and if you had to do anything to get them in.
im going to try the HD V.2 lip. i tried the V1 lip using the edging, and that fell apart after two good scrapes, and didnt look good at all.
96 S14
[I|H|E|240/248|~25*@dizzy|crappy OEM clutch=15.8@86]
ic2drop
unreal- attempts nothing, he completes it all with authority.
boxfresh
you are so full of win it almost scares me.
01-04-2010, 03:02 AM
#19 (permalink )
240SXForums Slut
214749270
Will do, I may also look into the Nistune Type-4 if they can have a decent turn around time and I can get a decent tuner...
But That'll Require an Innovative LC-1 on my part. Not a fan of the widebands on the Dyno @ the tailpipe, IDK why lol.
Oh and BTW, that chrome Door trim was taken off the day after the shoot, IDK why I didnt do it before lol
01-04-2010, 03:05 AM
#20 (permalink )
185543393
thats right kid make me happy
01-04-2010, 03:07 AM
#21 (permalink )
240SXForums Slut
214749270
I try to make everyone happy
01-04-2010, 04:07 AM
#22 (permalink )
214749004
thats what she said.
96 S14
ic2drop
boxfresh
01-04-2010, 12:45 PM
#23 (permalink )
0
Looking forward to see your build. Be sure to take more pictures!
01-04-2010, 01:29 PM
#24 (permalink )
214749004
Oh, and scoot, try using the Rustoluem 2000F engine enamel @ autozone. I used it on my intake pipe, and it came out very very matte, and my intake pipe is very cool to the touch even after extended driving. Only part that gets remotely warm is the part that goes next to the radiator fan. The rest of the pipe is cold. Uncoated, the entire pipe would be warm. I swear i felt a slight HP increase, but that could just be the weather.
96 S14
ic2drop
boxfresh
01-04-2010, 11:34 PM
#25 (permalink )
240SXForums Slut
214749270
Your butt dyno agree's lol
Powered by vBulletin® Version 3.7.6 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
AutoGuide.com Truck European Import Domestic Manufacturer The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community. Visit AutoGuide.com today. For advertising information, on the AutoGuide.com network please request a media kit or email us: sales@autoguide.com
