Go Back   240SX Forums > General Section > 240SX Forum News
240SX Forum News Check here for the latest on the site
Closed Thread
Old 09-17-2008, 10:32 AM   #1 (permalink)
neo
Administrator
neo's Avatar
neo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthyneo The posts made by this user are trust worthy
Thumbs up Please help me welcome Silver Mine Motors
Please join me in welcoming Edan from http://silverminemotors.com/main.sc Please be sure to check out their site for your big brake needs.
That should always be your very first mod, BIG BRAKES!
- Jose
neo is online now
Old 09-17-2008, 11:41 AM   #2 (permalink)
Registered User
bajaracer1 is on a distinguished road
Hey guy’s my name is Edan, I’m the owner of silver mine motors. I guess I’ll tell you a little about our company, then I’ll tell you what we have available for your car, and lastly what we have planed for the future.
Currently I have two cars. 1978 280z and 1990 240sx. When I got the z after a few months of driving it as my daily driver I realized that I needed better brakes. Since there weren’t too many cost effective kits on the market I decided to put my own kit together. When I finished I decided to put the kit on the market. Since them I have been making more brake kits for the z cars. Currently we have three kits available for them.
About six months ago I got my 240sx and decided to start selling brake kits for them as well. Basically if the demand for the brakes is high enough I will keep making better and better kits. Right now we carry two brake kits for your car.
I am already in the process of making a rear brake kit which will be completely new to the market. It should be done in about 3 months. I am also going to be selling suspension parts in the near future so check back every few weeks for that.
Anyway here some pictures of the kits we sell right now and their descriptions.
Thank you for the warm welcome neo!
Price = $435
Stage 3 big brake kit for 240sx (s13 and s14).
This kit includes:
1. Dual piston calipers.
2. C.N.C. drilled, slotted and vented rotors with Zink plating to prevent rusting.
3. DOT approved custom fabricated steel braided brake lines.
4. Ceramic brake pads.
5. All necessary hardware.
As you can see this is a complete kit. There are no other parts needed to complete the installation. This is a big brake kit for any Nissan 240sx. The calipers are two piston calipers, which are a big increase in piston size as opposed to the single piston caliper that came on the car from the factory. The drilled, slotted and vented rotors are professionally built with CNC machines, and zinc plated to prevent rusting. These rotors have diamond slots. This eliminates dust build up at the end of the slot and helps dissipate gasses evenly through out the rotor. The steel braided brake lines are custom made to fit this brake kit for easy installation. They are also government DOT approved just like the stock brake lines that come on new cars from the factory today. So you can believe they will not have any problems. They are also steel braided with a layer of clear lamination to prevent expansion of the line under pressure. The ceramic brake pads are made by Posi Quiet. They have a 25% increase in pad surface area when compared to the stock 240sx brake pads. They are very quiet and smooth. If you don't want the brake pads you can subtract $20 from the final price. This brake kit will make your 240sx stop so much faster after it is installed. These brakes are off a car that weighed over 1500 pounds more that the 240sx and came with a v8 engine that made 300 horse power. This brake kit will fit all 240sx cars with the stock 4x4.5 and 5x4.5 bolt patterns.
Price = $475
Stage 4 big brake kit for 240sx (s13 and s14).
This kit includes:
  • Four piston calipers.
  • C.N.C. drilled, slotted and vented rotors with Zink plating to prevent rusting.
  • DOT approved custom fabricated steel braided brake lines.
  • Ceramic brake pads.
  • All necessary hardware.
As you can see this is a complete kit. There are no other parts needed to complete the installation. This is a big brake kit for any Nissan 240sx. The calipers are four piston calipers, which are a big increase in piston size as opposed to the single piston caliper that originally came on the car. The drilled, slotted and vented rotors are professionally built with CNC machines, and zinc plated to prevent rusting. These rotors have diamond slots. This eliminates dust build up at the end of the slot and helps dissipate gasses evenly through out the rotor. All rotors are drilled to fit any stock four or five lug 240sx bolt pattern (which is 4x4.5 and 5x4.5). The steel braided brake lines are custom made to fit this brake kit for easy installation. They are also government DOT approved just like the stock brake lines that come on new cars from the factory today. So you can believe they will not have any safety problems. They are also steel braided with a layer of clear lamination to prevent expansion of the line under pressure. The ceramic brake pads are made by Posi Quiet. They have over 25% increase in pad surface area when compared to the stock 240sx brake pads. They are very quiet and smooth. If you don't want the brake pads you can subtract $20 from the final price. This brake kit will make your 240sx stop so much faster after it is installed. These brakes are off a car that weight about the same as your 240sx but had a twin turbo v6 engine with 300hp. It was considered one of the fastest cars made in the 90’s. This kit will fit all 240sx cars with the stock 4x4.5 and 5x4.5 bolt patterns.
How to contact me:
Email: edan@silverminemotors.com
Phone: (818) 636-2797
bajaracer1 is online now
Old 09-17-2008, 12:37 PM   #3 (permalink)
neo
Administrator
neo's Avatar
Welcome, the kit looks great!
neo is online now
Old 09-17-2008, 01:52 PM   #4 (permalink)
Registered User
eomund's Avatar
eomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthyeomund The posts made by this user are trust worthy
Looks awesome. Wish I had money right now
Ride the Pig Club Co-Founder [Pics coming soon]
Quit Whatifgaming, looking for a new review site
S13 Status: Daily Driver
If at first you don't succeed, destroy all evidence that you tried
eomund is online now
Old 09-17-2008, 02:06 PM   #5 (permalink)
Registered User
allntrlundrgrnd's Avatar
allntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthy
i want
Tow Hook Crew Member #11
-Pete
RamRod Racing
http://www.240sxforums.com/forums/sh...d.php?t=113069
SR & KA parts for cheap!!
Originally Posted by newtodrifting View Post
dude, dont quote my Gramer
allntrlundrgrnd is online now
Old 09-17-2008, 04:20 PM   #6 (permalink)
Registered User
OpenThrottle's Avatar
welcome
Patiently Waiting
How to run your boost/vacuum lines (click me)
OpenThrottle is offline
Old 09-25-2008, 03:28 PM   #7 (permalink)
neo
Administrator
neo's Avatar
Originally Posted by allntrlundrgrnd View Post
i want
Call and order
neo is online now
Old 10-30-2008, 12:35 PM   #8 (permalink)
Registered User
dez240sx's Avatar
dez240sx is on a distinguished road
nice might have 2 get 1 when i get some cash
Drift to live, live to drift. s13 PAN
dez240sx is offline
Closed Thread
F/S 5Zigen Fn01rc Silver 17x9/10 5x114.3 500.OBO d0wn5h1ft For Sale and Wanted 0 05-30-2007 04:31 PM
TopHat Crate motors..... DRFTMSTR KA24DE/T and KA24E 17 01-14-2006 08:35 PM
CA motors anyone? Chris69427 SR20DET Engines 11 07-30-2003 09:31 PM
Silver, White, or Black? silviabsessed Polls 19 05-20-2003 08:31 AM
JDM motors can be legal? jZa_pHive S13 240SX (89-94) 6 05-04-2003 10:57 AM
Forum Stats
Members: 62,148
Threads: 97,519
Newest Member: roccky.watson
Forum Sponsors
Latest Threads
Forum Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright©2001-2007, DeeperImage, Inc™ | All Rights Reserved®
DeeperImage, Inc. and 240SXFORUMS.COM are in no way affiliated with Nissan Motors Co, Ltd. All Trademarks are property of their respective owners. 240SXFORUMS.COM is an enthusiast community for the Nissan 240SX.
