KA24: OEM Injector size - Nissan 240SX Forums
Beginnerís Forum **240SX 101. NO FLAMING ALLOWED**
post #1 of 10 Old 08-18-2008, 06:39 PM Thread Starter
one30five's Avatar
one30five is on a distinguished road
Points: 2,339, Level: 29
Points: 2,339, Level: 29 Points: 2,339, Level: 29 Points: 2,339, Level: 29
OEM Injector size
What is the flow rate of the stock red injectors of a ka24de? I know this is a dumb question, and I have seen it asked before, but I couldn't find it again (that's why i'm asking here).
one30five is offline
post #2 of 10 Old 08-19-2008, 12:14 AM
Quoted: 230 Post(s)
Points: 2,147,744,183, Level: 100
Points: 2,147,744,183, Level: 100 Points: 2,147,744,183, Level: 100 Points: 2,147,744,183, Level: 100
Activity: 42%
Activity: 42% Activity: 42% Activity: 42%
270cc's
post #3 of 10 Old 08-19-2008, 12:14 PM Thread Starter
one30five's Avatar
Damn, that's what I thought. I was hoping it was lower so I knew what was wrong with my settings in my MS2.
Thanks for the help.
post #4 of 10 Old 02-12-2011, 01:18 AM
Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100 Tweak110100100
Garage
i know this post is from a while ago, but i was searching and i was wondering whats the biggest fuel injector you can go with for a stock ka24de, see my car recently started showing signs of a vacuum leak, and i popped the hood and discovered a hose that was cracked, i replaced it, but still showed signs of a vacuum leak, and eventually discovered it was the injector o-rings, so i figured why not replace all injector after 189xxx miles, im also building my ka, so if i can buy a bigger injector size to carry me through as i add more power to the car while also good for a stock motor, if the stock injectors are 260-270 then i assume 300cc will be just fine, am i thinking right?
Tweak110100100 is offline
post #5 of 10 Old 02-12-2011, 02:54 AM
starcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthystarcrutch The posts made by this user are trust worthy
Points: 214,749,153, Level: 100
Points: 214,749,153, Level: 100 Points: 214,749,153, Level: 100 Points: 214,749,153, Level: 100
Holy old thread, batman! Anyways, no. If you get bigger injectors, you'll need a tune. Send them out and get them flow tested and matched if you're worried, but a stock ass KA24DE isn't going to get much of a power boost from having epic injectors.
starcrutch is offline
post #6 of 10 Old 02-12-2011, 02:33 PM
Garage
Yeah I know it won't give massive gains, but fo sho, brand new stockers will work out just fine
post #7 of 10 Old 02-14-2011, 09:30 AM
Matt Cramer's Avatar
Matt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthyMatt Cramer The posts made by this user are trust worthy
Points: 644,253,974, Level: 100
Points: 644,253,974, Level: 100 Points: 644,253,974, Level: 100 Points: 644,253,974, Level: 100
That depends on whether you have a tuning device to adjust your fuel or not. If you're getting something like a standalone engine management system installed to handle future mods, the sky's the limit. If you are running the stock ECU, I wouldn't bother upsizing the injectors just yet. I'd just send them out to have them cleaned and flow tested. We use WitchHunter Performance for that ourselves and have had great results from them.
Matt Cramer
Engine Management Systems
Matt Cramer is offline
post #8 of 10 Old 02-14-2011, 10:38 AM
Quoted: 230 Post(s)
Activity: 42%
Not only that but from the Factory the 240's run pretty rich under WOT as is, throwing ~30cc more fuel just makes it richer.
post #9 of 10 Old 04-26-2011, 02:57 AM
Booom's Avatar
Booom is on a distinguished road
Points: 3,046, Level: 33
Points: 3,046, Level: 33 Points: 3,046, Level: 33 Points: 3,046, Level: 33
so the obd1
ka24de and obd2 run the same CC?
Booom is offline
post #10 of 10 Old 04-26-2011, 03:45 AM
Quoted: 230 Post(s)
Activity: 42%
Yes.
You may post new threads
