Go Back   240SX Forums > 240SX Introduction > Beginner’s Forum
Beginner’s Forum **240SX 101. NO FLAMING ALLOWED**
LinkBack (1) Thread Tools
Old 01-06-2009, 03:31 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Registered User
60koriginal1993 is on a distinguished road
rough idleing...
Ok here goes 1993 240sx ka24de 60,000 original miles here goes the problem car has trouble starting. The car will start with the help of giving it gas but when running the it idles from 400-1000 rpms and the whole car shakes. I've checked other threads and found alot of people haveing the same problems but never any solutions. The things I have done was checked the injectors one was a little off so I replaced it, I replaced the spark plugs and wires, replaced valve cover gasket, checked the temp sensor and the maf sensor. checked for vac leaks. The car is useing more gas than it should can go about 30 miles on a quarter tank nd the car has no mods. One problem I've seem to find is pulling the 4th plug on the injector has no effect to the engine doesn't idle higher and doesn't lose power. I unplugged the 3rd injector and hooked it to the 4th injector and still no change cause I do know the 3rd injector does fire due to unplugging it and the engine loses more power. The engine light hasn't come on so I have no clue any help would be appreciated...
60koriginal1993 is offline   Reply With Quote
Old 01-07-2009, 01:05 AM   #2 (permalink)
Registered User
UPDATE:
Checked MAF
Checked Vac Leaks
Checked Distributor
Checked Coolant Temp Sensor
New Injector
New Plugs
New Plug Wires
Compression:
1st- 140
2nd- 135
3rd- 140
4th- 125
Old 01-07-2009, 10:19 AM   #3 (permalink)
Bow
Registered User
Bow's Avatar
Bow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthyBow The posts made by this user are trust worthy
Points: 179,588,342, Level: 100
Points: 179,588,342, Level: 100 Points: 179,588,342, Level: 100 Points: 179,588,342, Level: 100
Activity: 23%
Activity: 23% Activity: 23% Activity: 23%
Originally Posted by 60koriginal1993 View Post
Compression:
1st- 140
2nd- 135
3rd- 140
4th- 125
Ouch
Well... besides the low compression on Cylinder 4...
Change the O2 sensor
And a silly question...
Do you have a Factory Service Manual for it?
Bow
S13 owner since 1997, E85 burner since June 2007
Notice: Reading the Factory Service Manual has been known to be educational and prevent the asking of retarded questions on public internet forums.
Bow is offline   Reply With Quote
Old 01-07-2009, 12:04 PM   #4 (permalink)
Registered User
yeah im changing the O2 sensor today and i'm running a full diagnostic today and yes I do have the factory service manual...
Old 01-08-2009, 09:59 AM   #5 (permalink)
Bow
Registered User
Bow's Avatar
Activity: 23%
rough idling is USUALLY:
Vacuum leak.
Bad Injector.
Leaking Injector lower O-ring seal.
If it still does it after the new O2, I'd inspect the Injector O-rings
Is it running Rich?
Smell gas out the tailpipe?
Remove your plugs, what do they look like?
Wet? White? Brown?
The rough idle is a bitch to chase down, you have to slowly eliminate things one by one...
Bow
Old 01-09-2009, 01:57 PM   #6 (permalink)
Registered User
yeah its running rich the exhaust smells like gas, i'm going to check the rings today.The only plug fowling out is number 4 and its brown every time. Hopefully ill chase it down soon sick of putting so much damn gas in the car
Old 01-09-2009, 11:43 PM   #7 (permalink)
Registered User
KA24det1d is on a distinguished road
have you checked your fuel pressure regulator?
KA24det1d is offline   Reply With Quote
Old 01-10-2009, 02:00 PM   #8 (permalink)
Registered User
not yet im doing a full check of everything today just been busy haven't had the time
Old 01-11-2009, 03:49 AM   #9 (permalink)
Registered User
UPDATE: I changed out the fourth injector again with another one car ran fine for about a day, but know its doing it again what could cause me to foul out an injector so fast?
Old 01-11-2009, 09:14 PM   #10 (permalink)
Registered User
bagnasco is on a distinguished road
Just a thought but it could be the idle control valve. Have you checked that yet?
bagnasco is offline   Reply With Quote
Old 01-19-2009, 02:02 PM   #11 (permalink)
Registered User
no haven't checked that yet kinda set the car on the back burner working on my twin turbo 300zx. Might put the Z motor in the 240 and put an rb26 in the 300z
LinkBack to this Thread: http://www.240sxforums.com/forums/beginner-s-forum/117816-rough-idleing.html
Digg - 240SX Rough Idleing... This thread Refback 01-11-2009 11:19 AM
SR20DET: Rough Idle, What the... Spooling Nismo SR20DET Engines 3 12-08-2008 11:09 AM
KA24E: rough warm idle on 89 SOHC 240Dan S13 240SX (89-94) 1 07-10-2008 10:02 PM
ROUGH idle, and wont rev past 2k cycotron KA24DE/T and KA24E 8 05-09-2007 07:08 PM
Runs rough at idle, no power up high? LiquidCache KA24DE/T and KA24E 1 04-23-2004 03:27 AM
HELP: 240 runnin rough AshNazg General Tech 5 11-26-2003 09:36 AM
Forum Stats
Members: 68,122
Threads: 102,759
Newest Member: alamorotary
Forum Sponsors
Latest Threads
Forum Sponsors
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright©2001-2007, DeeperImage, Inc™ | All Rights Reserved®
DeeperImage, Inc. and 240SXFORUMS.COM are in no way affiliated with Nissan Motors Co, Ltd. All Trademarks are property of their respective owners. 240SXFORUMS.COM is an enthusiast community for the Nissan 240SX.
