I just got my first 240 what should I do first - Page 5 - Nissan 240SX Forums
Beginnerís Forum **240SX 101. NO FLAMING ALLOWED**
post #101 of 195 Old 06-17-2012, 09:53 PM
PhantomSx is on a distinguished road
Points: 49, Level: 1
Points: 49, Level: 1 Points: 49, Level: 1 Points: 49, Level: 1
This is going in my book marks
PhantomSx is offline
post #102 of 195 Old 06-19-2012, 01:28 PM
s15love is on a distinguished road
Points: 710, Level: 14
Points: 710, Level: 14 Points: 710, Level: 14 Points: 710, Level: 14
so many things to do so lil time
s15love is offline
post #103 of 195 Old 07-02-2012, 12:37 AM
athomas936 is on a distinguished road
Points: 38, Level: 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Originally Posted by dropteam21 View Post
I was asked to do a rite up on how to do the self diagnosis on the ecu this is how to do it on the ka24e idk if its the same for the de. First thing you have to do is remove the passenger side kick panel. After you do that you need to unbolt the 2 10mm bolts that hold the ecu in place. Then flip the ecu around with out unplugging it.
Grab a peace of paper and pen you will need to rite down what codes pop up. Mark where the screw is with a grease pen or finger nail polish So it can be set back in the rite spot.
Put the key in and turn it but do not start the car. Now turn the adjustment screw on the ecu all the way clock wise the light will blink one time then 2 times then 3 times after 3 turn it back it is now in self diagnosis mode. The lights will start flashing the code. Red is for the first number green for the 2nd. If you have one code it will keep flashing the same one over and over if you have more than one it will keep going throw them one after the other.
so if its :red red red red---- green green green it is 43
The codes are:
11 Crank angle sensor circuit
12 Air flow meter circuit
13 Engine temperature sensor circuit
14 Vehicle speed sensor circuit
21 Ignition signal missing in primary coil
31 E.C.U. (E.C.C.S. control unit)
32* EGR function
33 Exhaust gas O2 sensor circuit
35* Exhaust gas temperature circuit
43 Throttle position sensor circuit
45* Injector leak
55 No malfunction
*California models only.
After you have written down the codes turn the car off turn the key back on this time let the light flash 4 times this will clear the codes. after that fix what needs to be fixed and re clear the codes.
Your done bolt ecu back up and put kick panel back on.
Very useful information.
BUMP
athomas936 is offline
post #104 of 195 Old 08-01-2012, 06:13 PM
Be nice, I'm new here!
bushygrunty is on a distinguished road
Points: 109, Level: 2
Points: 109, Level: 2 Points: 109, Level: 2 Points: 109, Level: 2
thanks! pictures helped alot
bushygrunty is offline
post #105 of 195 Old 09-21-2012, 03:34 PM
Sherman818 is on a distinguished road
Points: 37, Level: 1
Points: 37, Level: 1 Points: 37, Level: 1 Points: 37, Level: 1
Good info thanks
Sherman818 is offline
post #106 of 195 Old 09-28-2012, 03:34 PM
emcarlson4 is on a distinguished road
Points: 36, Level: 1
Points: 36, Level: 1 Points: 36, Level: 1 Points: 36, Level: 1
This thread is amazing! Thank you for this information, I will definitely be using this once I get my new car
emcarlson4 is offline
post #107 of 195 Old 10-14-2012, 03:52 AM
UR Krew's Avatar
UR Krew is on a distinguished road
Points: 61, Level: 1
Points: 61, Level: 1 Points: 61, Level: 1 Points: 61, Level: 1
Activity: 8%
nice pointers ill get on it,
UR Krew is offline
post #108 of 195 Old 11-17-2012, 02:53 AM
xxS14xx is on a distinguished road
Points: 212, Level: 4
Points: 212, Level: 4 Points: 212, Level: 4 Points: 212, Level: 4
This things should definetely be done. Never know if owners(last) ever treated them with proper maintnence. Nothing better than a HEALTHY MOTOR
xxS14xx is offline
post #109 of 195 Old 11-29-2012, 09:03 PM
hex13 is on a distinguished road
Points: 97, Level: 1
Points: 97, Level: 1 Points: 97, Level: 1 Points: 97, Level: 1
Nice work dude, this makes me want to do a couple of the things you mentioned! Thanks for the inspiration!
hex13 is offline
post #110 of 195 Old 12-04-2012, 08:45 AM
Vonviper is on a distinguished road
Points: 554, Level: 11
Points: 554, Level: 11 Points: 554, Level: 11 Points: 554, Level: 11
Activity: 8%
Great write ups on things to do first i've injoyed reading the posts, since the post seems to be still read if you dont mind i'll add my first item to must get was a solid one piece driveshaft mine was 370 bucks from "ShaftMasters" but worth every penny spent.. car shifts, drives, moves, so much better than the stock 4foot two pieces of crap that was weighing down my underbelly.. for what ever reason that was designed for isnt good enough that was just silly.. i know 250 - 450 bucks to shell out is alot but a center bearing can cost from 70 - 120$ plus its needs to be pressed on, Ujoint replacements dont quite fit right after factory non-servicable ones go bad. if your car is pretty sound and your looking for first performance upgrades hands down in my opnion the factory driveshaft has to get thrown off the cliff...
Vonviper is offline
post #111 of 195 Old 12-06-2012, 02:05 AM
dannyttran is on a distinguished road
Points: 32, Level: 1
Points: 32, Level: 1 Points: 32, Level: 1 Points: 32, Level: 1
inspiring.
dannyttran is offline
post #112 of 195 Old 12-09-2012, 10:51 PM Thread Starter
dropteam21's Avatar
dropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthydropteam21 The posts made by this user are trust worthy
Points: 139,259,868, Level: 100
Points: 139,259,868, Level: 100 Points: 139,259,868, Level: 100 Points: 139,259,868, Level: 100
wow its been a few years since i have been on the forum I got a honda shadow aero and that has become my new toy. its nice to see people still useing this info.
TEIN-KYB-PROTHANE-CLARION-BAZOOKA-NOS-ROCKFORD FOSGATE
SUN PRO-PILOT-NGK-STREET GLOW
dropteam21 is offline
post #113 of 195 Old 12-18-2012, 09:07 PM
Anthony wyres is on a distinguished road
Points: 42, Level: 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Activity: 7%
Activity: 7% Activity: 7% Activity: 7%
Very nice car
Anthony wyres is offline
post #114 of 195 Old 12-31-2012, 12:06 PM
IceCream's Avatar
IceCream IceCream IceCream IceCream IceCream IceCream IceCream IceCream IceCream IceCream IceCream
very nice helps alot to no the common matenience on a 240
IceCream is offline
post #115 of 195 Old 01-09-2013, 11:05 PM
Salty is on a distinguished road
Points: 35, Level: 1
Points: 35, Level: 1 Points: 35, Level: 1 Points: 35, Level: 1
Alot of useful information, thanks for the info
Salty is offline
post #116 of 195 Old 01-31-2013, 11:12 AM
dragginwagon is on a distinguished road
really good right up
dragginwagon is offline
post #117 of 195 Old 02-04-2013, 03:48 AM
MattLokes's Avatar
MattLokes is on a distinguished road
Points: 395, Level: 7
Points: 395, Level: 7 Points: 395, Level: 7 Points: 395, Level: 7
Great intro thread, good luck on your 240 man!
MattLokes is offline
post #118 of 195 Old 02-07-2013, 05:41 PM
azerathis is on a distinguished road
+1 don't forget the basics
azerathis is offline
post #119 of 195 Old 02-20-2013, 08:46 AM
davincent is on a distinguished road
metoo
METOO
that's a nice rite up but mine has 2 crappy pics lol that's got some good info. shit up until like 3 months ago I did not even know you could get a code off the ecu.
davincent is offline
post #120 of 195 Old 02-20-2013, 08:47 AM
yeah,me too
post #121 of 195 Old 02-20-2013, 09:10 PM
Noob_ is on a distinguished road
Points: 39, Level: 1
Points: 39, Level: 1 Points: 39, Level: 1 Points: 39, Level: 1
good info
Noob_ is offline
post #122 of 195 Old 02-22-2013, 03:14 AM
Jgz1994 is on a distinguished road
Nice work.
Jgz1994 is offline
post #123 of 195 Old 02-26-2013, 07:31 PM
sraha is on a distinguished road
Points: 79, Level: 1
Points: 79, Level: 1 Points: 79, Level: 1 Points: 79, Level: 1
nice write up
sraha is offline
post #124 of 195 Old 02-28-2013, 03:55 PM
word is on a distinguished road
Points: 202, Level: 4
Points: 202, Level: 4 Points: 202, Level: 4 Points: 202, Level: 4
this is definitely a lot of good information i will be looking into soon, but unfortunately i have inherited some bigger mechanical issues that will require attention before i can get to all this.. ((
word is offline
post #125 of 195 Old 03-01-2013, 11:32 PM
cabs13's Avatar
cabs13 is on a distinguished road
Points: 99, Level: 1
Points: 99, Level: 1 Points: 99, Level: 1 Points: 99, Level: 1
Activity: 15%
Activity: 15% Activity: 15% Activity: 15%
Nice write up, the pics are helpful.
cabs13 is offline
You may post new threads
