Red 240Sx Build - Nissan 240SX Forums
Builds & Projects A Section for ALL Build threads or Projects for Both Chassis'.
 70Likes
post #1 of 253 Old 10-03-2015, 03:53 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
96Red240SX is on a distinguished road
Points: 2,078, Level: 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Activity: 83%
Activity: 83% Activity: 83% Activity: 83%
Red 240Sx Build
I know it may be a bit premature to start a build thread. However, I have already started ordering parts so as it sits right now I feel like it has already begun. When I do a build I go the more expensive route. I start replacing factory pieces that are broken and get the car running properly. After I get the car functional I begin the mods .
So here is a picture of the car. It's a bit rough but I think she has great potential.
Interior
Some of the damage I have spotted so far.
Notice how black the CMC fluid is. Ewwww
and finally the engine bay.
I ordered the following parts
  • Primary O2
  • Turn signal switch
  • SunRoof gasket
  • CMC
  • JDM mirrors
  • Door panels from ebay
  • e-brake sensor
  • Crank angel sensor
Once I get these new parts on and installed. I will clear all codes and take it out for another test drive. From this point I know I will have the following items to fix.
  • Front brakes
  • Struts / Springs
I have a clicking in the dash I am trying to figure out what it is. If anyone is in the VA area I can sms you the file I have from my iPhone. I recorded it. Very weird. None of my other 240's did this.
Sean
1996 240sx se
Last edited by 96Red240SX; 10-05-2015 at 11:17 AM. Reason: Updated my post with images.
96Red240SX is offline
post #2 of 253 Old 10-03-2015, 04:00 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
I removed this post. I found a place to host my images for the build process.
Sean
1996 240sx se
Last edited by 96Red240SX; 10-05-2015 at 10:50 AM. Reason: Removed google link for images.
post #3 of 253 Old 10-05-2015, 10:02 AM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
I called CarQuest today because waiting until Oct 16th seemed so unreasonable for an O2 sensor. I will have that today at 12pm. I am also thinking about spending my suspension money on my trans instead. Long story short I found a reasonable price tranny for my swap. So I want to snatch it up before it poofs. I am still looking for some place to host images other than photobucket.
Also all parts from Japan have been shipped. These include the following:
Door panels
Turn signal switch
Windshield wiper switch
JDM mirrors (folding)
Sean
1996 240sx se
post #4 of 253 Old 10-05-2015, 10:24 AM
collegekid's Avatar
Quoted: 64 Post(s)
collegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthy
Points: 429,507,583, Level: 100
Points: 429,507,583, Level: 100 Points: 429,507,583, Level: 100 Points: 429,507,583, Level: 100
Activity: 81%
Activity: 81% Activity: 81% Activity: 81%
Welcome to the forum
What cam angle sensor? Are you talking about the crank position sensor?
Our cars run off of a distributor and its probably much easier to just replace a distributor cap, wires and spark plugs than to mess with that. Just finish all the basic maintenance outlined in one of the stickied threads.
what is the extent of your mechanical abilities? What is wrong with the transmission? Whats wrong with the ebrake sensor? I've never heard of anyone replacing that and if that sensor is more than $50 I wouldnt even waste time on it.
-Just do the spark plugs wires and distributor cap
- if you are doing the clutch master you might as well get a stainless steel clutch line and a new slave and not need to mess with that again
-Good luck and God bless with the sunroof gasket. I had them cut out my sunroof and weld in sheet metal
An S14 transmission should go for around 150-250. I sold mine for $250 and I had everything on it still.
Decent coilover suspension should run you about 1000-1200
Stance, BC racing, Part shop max (what I have) are okay. Dont buy any of the cheap Tein suspension, Isis or Megan racing shit
Whatever coils you do get, dont slam your car to the ground
Definitely save up for suspension ASAP because driving a stick shift on blown struts is terrible. Driving a slammed ass 240 that you have to worry about even the smallest road bumps is horrifying as well
96Red240SX likes this.
96. Gonna do it right this time
collegekid is offline
post #5 of 253 Old 10-05-2015, 10:31 AM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
I'm doing a swap. I never stated which one. I'm not replacing the factory Nissan tranny.
There were two codes that popped when scanned the ECU.
1. Crank angle position sensor (on the trans)
2. O2 bank A.
This will be my third swapped 240 and I have decided to do something a bit different this time. I want to repair some of the mechanical defects before I get into the actual swap. For example:
1. Blown struts
2. Clanging while driving
3. Clicking in the dash
4. Turn signal is broken
5. CMC is shot
6. Front disks are warped
7. Determine which rear end was installed
8. Discover source of vibration
9. Repair CEL's
I must apologize. I got cam stuck in my head. It's Crank angle position sensor.
Sean
1996 240sx se
post #6 of 253 Old 10-05-2015, 03:34 PM
Quoted: 219 Post(s)
Points: 2,147,740,453, Level: 100
Points: 2,147,740,453, Level: 100 Points: 2,147,740,453, Level: 100 Points: 2,147,740,453, Level: 100
Activity: 99%
Wow that cars seen better days, can't wait to see the progress.
edit: someone moved it already lol. was gonna move it to the projects section.
post #7 of 253 Old 10-05-2015, 03:34 PM
Quoted: 219 Post(s)
Activity: 99%
post #8 of 253 Old 10-05-2015, 04:31 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Cool thanks. I am still getting use to the Site. I thought I was in the right area.
Sean
1996 240sx se
post #9 of 253 Old 10-05-2015, 11:32 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
**Update**
So I was out and about today and I like I said earlier I cancelled my order via advance Auto parts and went to car Quest. When I came home I took a deeper look at the car after I replaced the O2 sensor. Here is what I saw.
I found this vacuum line tapped (I literally mean tapped) to a small piece of dry rotted vacuum line.
I also found this dry rotted vacuum line that looks like coolant line and collapsed.
Finally, I also found this. I was a bit bummed about finding this.
So off to CarQuest I go again. I was going to take her out for a test drive when I realized she had only 1 Quart of oil left in her. Not good. So the following items where done today:
  • Oil and Oil filter changed
  • Spark plugs
  • Primary O2 sensor
  • 2 vacuum lines
Here is what the first vacuum line looked like when I was done.
Here is the upper vacuum line
When I was done with all that I swapped on half a set of rims and tires I had laying around. Here you can see the fronts
I cleared the codes and took her out for a spin. I was able to replicate the codes only drive about 3 miles the first time. So I took off down 17 and then came back. I was not able to replicate the code this time. Also I found I had a bit more more power. Something I was really surprised the vibration in the car has been really reduced. so I'm not sure if it was the blocked vacuum source or the rims or a combination of all the above.
My next tasks to tackle will be removing the tint from the back window. Also pulling the head unit. I can't seem to figure out how to change channels in the one that is in it now. I have a spare POS laying around I can use for now.
I can't put the rear tires on until I replace the rear struts. Sadly they are completely blown. I also noticed a clunking when shifting. I can't tell if it's pilot bearing or something else. I think I have a loose heat shield that is rattling.
I am very excited. Even though my struts are blown I had a nice fun little drive this evening. I really enjoyed it. I definitely feel I made the right choice returning to my Nissan roots.
I almost forgot. My CMC should be in tomorrow. I am not sure when my braided break lines will show up.
Sean
1996 240sx se
post #10 of 253 Old 10-06-2015, 04:11 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Red 240Sx Build
Crazy thing about spending money in a whirl wind type fashion is when you stop to do the accounting. You realize that you spent some money and that you have a bunch of parts coming. LoL, talk about pressure.
I know these are the unexciting mods / repairs but I have a bunch of stuff coming in shortly. Here is what I have:
  • Turn signal
  • Wiper switch
  • Door panels
  • CMC
  • JDM folding mirrors /w switch
  • Break light switch
  • Agency brake line upgrades
I think I ordered the wrong part. I needed the e-brake switch so the parking brake light shuts off. Sigh.
Tonight I am going to tackle the CMC and pealing the tint off the back window and removing the glue off the glass.
Sean
1996 240sx se
post #11 of 253 Old 10-06-2015, 07:29 PM
Quoted: 219 Post(s)
Activity: 99%
Man, is this saved currency or credit?
post #12 of 253 Old 10-06-2015, 07:32 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Saved currency
Sent from my iPhone using Tapatalk
Sean
1996 240sx se
post #13 of 253 Old 10-06-2015, 07:51 PM
Quoted: 219 Post(s)
Activity: 99%
Man I wish I could save that much lol.
post #14 of 253 Old 10-06-2015, 11:22 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
I had money saved for another project I had to dump
Sean
1996 240sx se
post #15 of 253 Old 10-07-2015, 12:24 AM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
I am tired. I will post my updates tomorrow morning. Very exciting night
Sean
1996 240sx se
post #16 of 253 Old 10-07-2015, 12:51 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Wink
**Update**
So tonight my focus was on replacing the CMC and pealing the tint out of the back window. However, things took a turn for the worse shortly after starting the CMC. Here is the first thing I ran into.
So I went below to drain the system and found this. I was not overly happy with this turn of events.
Remember how I have mentioned I have worked on 240's before? Well as I recalled I had to do the CMC in my 1993 240. I purchased a slave cylinder. I wonder if I still have it???
But are they compatible??
The 240 gods were smiling on me tonight. My last 240 was back in 2004. So to still have that laying around is really lucky for me.
Now it's time to take this..
and
I think tonight I will take the night off. I still need to adjust the clutch so that it engages / disengages in the middle of the peddle like I like it. Thursday I will start pealing out the Purple tint and removing the glue. The glue makes seeing out the rear window nearly impossible.
I know over the next couple of day I will start receiving parts from all over the world. You have to love ebay for connecting people.
Sean
1996 240sx se
post #17 of 253 Old 10-07-2015, 01:03 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Red face
Actually, there are folks out there that put down a lot more money than me. I had 600.00 bucks left over when purchasing the car. I tossed that into my primary account and started purchasing parts to fix things that were broken. I save a lot of money by installing my own stuff, do my own body work, welding, and assembly. Things like alignments I go to shops for and I use the same machine shop for my engine builds for hot tanking, planing, balancing and so on.
Once that money is gone it's back to saving and spending for me. With all the parts I got off ebay and the parts I purchased locally I might have 700.00 bucks in the car so far. Most expensive piece was the door panels.
All that being said. That is not the most expensive pieces to come.
  • Transmission 1,200.00
  • ECU 1,500.00
  • Rods 800.00
  • Pistons 800.00
  • rebuild kit 400.00
  • Coilovers 1,800.00
Non of this includes paint, prep work, motor assembly or anything else. It's a project car. So I have time to work on it and save up money.
Sean
1996 240sx se
post #18 of 253 Old 10-07-2015, 09:20 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Ok, I goofed up. I got the wrong switch. Does anyone know if I can swap the fog switch to the new unit???
Sean
1996 240sx se
post #19 of 253 Old 10-07-2015, 11:16 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Both switches are installed. I installed something tonight. Something else showed up but not sure what it is
Sean
1996 240sx se
post #20 of 253 Old 10-08-2015, 11:24 AM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Talking
Yea, I don't really do stance style drops. The roads in my area are not very accommodating for it either.I like some clearance between the bumper and the road so I don't have to worry about bottoming out or ripping body pieces off.
I am not really driving the 240 yet on a daily basis yet. I take it out every so often to test to see what all is still broken. Right now I have am just trying to get it to a point where it's stable enough I might be able to take it to a meet or something. Hang out.
As far as the struts go. I'm looking at the BC struts RE's I think. They are about 1800.00. We have summit point in West Va and I want to go up there and play at bit. So I am going to get some Nicer struts. I've been practicing on and off driving for the last 2 years. I am not ready yet for an event but definitely want to find a place where I can put in some practice time.
Sean
1996 240sx se
post #21 of 253 Old 10-08-2015, 11:28 AM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
The new switches are in. I am really happy about that. I had three boxes show up yesterday but I forgot to put the signature card in the mail box. So I will not be getting the third box today.
As it turns out the front head lights were not activating when the switch was turned on. I realized last night when I put in the new switch. I was wow it's so bright in here now. So it's a good thing I pulled the switch. I should have one more box coming today and on Friday. Tonight I would like to peal that tint out of the window.
Sean
1996 240sx se
post #22 of 253 Old 10-09-2015, 02:33 AM
Quoted: 219 Post(s)
Activity: 99%
Man what kind of ECU and Internals you buying?
The prices you posted are like twice of what even good stuff is lol.
post #23 of 253 Old 10-09-2015, 08:23 AM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
I am going full stand alone this time. So most likely AEM V2 because the 2JZ gets cranky when the weather changes. Now that I have said 2JZ you should be able to understand the other prices
Sean
1996 240sx se
post #24 of 253 Old 10-09-2015, 07:28 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
So I was finally able to pick up the box at the post office that required a signature. I got these.
I also started working on the tint. Anyone have any better ideas than a razor blade and lots of time???
I picked up this paint for the mirrors. This is a 2015 Nissan paint. Holy crap was it expensive. Sigh, nothing I like is ever cheap. Somebody teach me to have lower standards...Lmao.
Sean
1996 240sx se
post #25 of 253 Old 10-09-2015, 09:21 PM Thread Starter
96Red240SX's Avatar
Quoted: 101 Post(s)
Activity: 83%
Ok, I am seeking some advice. I need to seperate the cover of the mirror. My first instint is to cut the wires and solder them back together. But they had to have a way of assembling the damn thing so I am opening up for thoughts.
Sean
1996 240sx se
RED S13s!! Dark Red, Light Red, Kinda of Red! charmersfh S13 Media 13 07-23-2006 03:17 AM
