Coupe: The Scratch Build - Page 2 - Nissan 240SX Forums
Builds & Projects A Section for ALL Build threads or Projects for Both Chassis'.
 29Likes
post #26 of 88 Old 09-09-2016, 04:17 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
320MN240 is on a distinguished road
Points: 8,160, Level: 61
Points: 8,160, Level: 61 Points: 8,160, Level: 61 Points: 8,160, Level: 61
Activity: 22%
Activity: 22% Activity: 22% Activity: 22%
I didn't get a picture of it put in, nothing special really.
Every time I look at this thread I go outside and look at my car. Then I go to my room and pout. I'm so jealous lol
320MN240 is offline
post #27 of 88 Old 09-09-2016, 04:18 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Had to torch off an old bushing that was left on before putting the rear in.
320MN240 is offline
post #28 of 88 Old 09-09-2016, 04:19 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
This picture gets me excited. Hahah!
w0nderbr3ad and kperdue91 like this.
320MN240 is offline
post #29 of 88 Old 09-11-2016, 06:55 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
So, I was at Proving Grounds 2 this weekend. This made me REALLY want to finish this car right now. I have to "adult" for a while before I can really dig into it.
This progress is minor, but a step in the correct direction. Throughout the week I plan on getting more stuff off the parts car so I can get rid of it.
Pedal assemblies - piece of cake
Brake booster/master - pretty easy whith no dash or dash bar in it
Clutch master - easy
E-brake lever/lines - easy if I can get the lines to separate under the car
Tension rod brackets and mount hardware - The front bolts all broke off in the front of the core support, tension rod bolts are stuck so I can't get to the bolts above them... HUGE pita. The car is just rolling around with strut and lca holding the tires on(kinda wobbly)
Sway bar.... even though my plans require a new bigger/stiffer bar
I already sold the dash out of the parts car at PG2.
320MN240 is offline
post #30 of 88 Old 09-13-2016, 11:15 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Some progress stripping the parts car.
Pedal assemblies - DONE
Brake booster/master - DONE
Clutch master - DONE
E-brake lever/lines - DONE
Tension rod brackets and mount hardware - NOT DONE... haha
Sway bar - yea... nope
I also removed some of the wiring for the brake light switch, neutral switch, and corner lights. Figured this would be helpful when I go to wire up the lights for "functionality"
320MN240 is offline
post #31 of 88 Old 09-14-2016, 11:26 PM
w0nderbr3ad's Avatar
Quoted: 41 Post(s)
w0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthyw0nderbr3ad The posts made by this user are trust worthy
Points: 425,551,976, Level: 100
Points: 425,551,976, Level: 100 Points: 425,551,976, Level: 100 Points: 425,551,976, Level: 100
Activity: 99%
Real nice, keep up the momentum.
P.H.D member #64
1990 s13 fb
w0nderbr3ad is offline
post #32 of 88 Old 09-17-2016, 11:50 AM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
The joys of owning 25 year old cars in the midwest...
Tension rod bolt won't come out? Is the inner bushing spinning inside the torn up old rotten bushing?
Cut the bracket and tension rod loop, then burn the bushing off!!!
The Scratch Build is getting a power brace and adjustable rods anyway...
320MN240 is offline
post #33 of 88 Old 09-18-2016, 10:38 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Well, the parts car is gone, but not without drama. I won't get into much detail other than I ended up wasting 2 hours waiting around(mind you I was 3 hours from home). In the end, dude finally showed up.
320MN240 is offline
post #34 of 88 Old 09-19-2016, 11:55 AM
Quoted: 37 Post(s)
cdenny619 is on a distinguished road
Points: 909, Level: 16
Points: 909, Level: 16 Points: 909, Level: 16 Points: 909, Level: 16
Activity: 50%
Activity: 50% Activity: 50% Activity: 50%
Dont worry. i know the feeling. i just went to a n event yesterday and got to ride along with one of the guys. i need to finish my car now
cdenny619 is offline
post #35 of 88 Old 10-21-2016, 08:45 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Zero progress, but hoping to get rolling in the next month or so. I need to get my welder set up and a new compressor. The old single stage oil-less craftsman is giving up. It is 16 years old afterall.
320MN240 is offline
post #36 of 88 Old 11-03-2016, 06:22 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Caddy sold, hopefully that means progress. We'll see!
320MN240 is offline
post #37 of 88 Old 11-25-2016, 10:48 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Ordered some necessary equipment. Need to get a few more things and get my new welder set up.
320MN240 is offline
post #38 of 88 Old 11-30-2016, 08:36 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Some tools came in today. Minor things ordered on Thanksgiving/Black Friday.
One more big item I'm still waiting for.
320MN240 is offline
post #39 of 88 Old 12-09-2016, 04:50 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Slow going. Trying to get some stuff together.
-Picked up the other Sparco
-another tool has arrived, but need to make something at work for it.
Updates soon I hope.
320MN240 is offline
post #40 of 88 Old 12-09-2016, 06:47 PM
collegekid's Avatar
Quoted: 71 Post(s)
collegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthycollegekid The posts made by this user are trust worthy
Points: 429,508,014, Level: 100
Points: 429,508,014, Level: 100 Points: 429,508,014, Level: 100 Points: 429,508,014, Level: 100
Activity: 99%
What was wrong with the hatch shell?
96. Gonna do it right this time
collegekid is offline
post #41 of 88 Old 12-09-2016, 07:13 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Nothing. I like coupes more. The hatch shell will probably go up for sale next fall
320MN240 is offline
post #42 of 88 Old 12-16-2016, 08:25 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Update...
Got the cart I made for my welder home.
Also got my JD2 Model 3 assembled and put on the rolling stand. I spent the extra cash on the Swag Offroad air over hydraulic bracket and got the HF 8 ton.
It's about to go down! 5 days of work next week, then 9 days off to hopefully knock out the cage. We'll see what happens.
320MN240 is offline
post #43 of 88 Old 12-20-2016, 03:06 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Cage mount plates. I made the a-pillar boxes ahead of time since they will only need minor trimming. They have been welded since this picture.
Some of the other plates are good as is, but most will need shaping and trimming.
w0nderbr3ad and RikRong like this.
320MN240 is offline
post #44 of 88 Old 12-23-2016, 09:54 AM
FormulaDz92's Avatar
Quoted: 15 Post(s)
FormulaDz92 is on a distinguished road
Points: 4,349, Level: 41
Points: 4,349, Level: 41 Points: 4,349, Level: 41 Points: 4,349, Level: 41
Activity: 77%
Activity: 77% Activity: 77% Activity: 77%
Good stuff! Glad to see your making progress.
320MN240 likes this.
'89 Nissan 240sx Hatch: KA24DE Swap, 2.25" Exhaust, Short Shifter, Eibach Sportline Springs, SPEC Stage 2+ Clutch and Pressure Plate, LED Cluster Lights, PRIME Wheels, EBC Pads w/Dimpled + Slotted Rotors, '98 Trans.
'94 Jeep Cherokee: 2-3.25" Raked Lift, 31" Tires, HID Headlights
FormulaDz92 is offline
post #45 of 88 Old 12-25-2016, 11:33 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Start working on this tomorrow. I need to clean the boxes of parts out of it first. I may do some seam welding of the chassis. Not entirely sure yet. The sound deadening is still in the car so I'll have to work around it where I can and just take out what's immediately necessary. I'll do the rest when I can get a hold of some dry ice.
320MN240 is offline
post #46 of 88 Old 12-27-2016, 11:40 AM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Bending, trimming, and laying out main hoop mounts.
320MN240 is offline
post #47 of 88 Old 12-27-2016, 11:42 AM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Cleaned off the rest of the sound deadening and took the paint off down to bare metal. Tacked the main hoop base plates in. I intentionally left small gaps. This will allow for 100% CJP (complete joint penetration).
320MN240 is offline
post #48 of 88 Old 12-27-2016, 11:43 AM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Not sure if I'll weld these first, or move on to the rear strut mounts. I have some trimming to do to be able to access these the way I want.
320MN240 is offline
post #49 of 88 Old 12-27-2016, 03:01 PM Thread Starter
320MN240's Avatar
Quoted: 213 Post(s)
Activity: 22%
Decided to move onto the rear first before welding.
Started trimming some of the divider between cockpit and trunk, but had to stop. I need a hole saw for my mounts, and I have to do some adulting. I'll get back out there this evening.
320MN240 is offline
post #50 of 88 Old 12-27-2016, 03:53 PM
Quoted: 230 Post(s)
Points: 2,147,744,183, Level: 100
Points: 2,147,744,183, Level: 100 Points: 2,147,744,183, Level: 100 Points: 2,147,744,183, Level: 100
Activity: 42%
Activity: 42% Activity: 42% Activity: 42%
Haven't been in here in a while. Looks like your putting a cage in?
im new here and got my first 240 and doing my first complete build from scratch justd Beginnerís Forum 28 12-13-2009 11:57 PM
How to start off from scratch? rexkwondo Beginnerís Forum 5 06-13-2005 07:23 PM
scratch and sniff AMD 240 Off Topic Chat 12 05-16-2005 03:29 AM
Singh's squish-bang Scratch sleepyRPS13 General Tech 6 08-19-2004 11:14 AM
Scratch Remover? aznham Off Topic Chat 10 02-03-2003 12:06 AM
