Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > CA18DET Engines
CA18DET Engines Tuning guides, questions and recommendations
Old 02-23-2008, 02:31 AM   #1 (permalink)
akstreet_racer's Avatar
akstreet_racer is on a distinguished road
CA18DET swap
iv been hearing diffrent things about this now. what year for s13s is better for the swap with ps and ac issues? iv heard 89 90s then iv heard 91 93s so can someone please help i wanna get my project rolling.thanks
1993 240sx hatchback..
akstreet_racer is offline   Reply With Quote
Old 02-23-2008, 07:14 AM   #2 (permalink)
CA18DETswap's Avatar
CA18DETswap is on a distinguished road
Points: 2,767, Level: 32
Points: 2,767, Level: 32 Points: 2,767, Level: 32 Points: 2,767, Level: 32
Well when I did mine I pulled all the a/c stuff out. I didn't have to modify the p/s at all and mine was a 91.
CA18DETswap is offline   Reply With Quote
Old 02-23-2008, 11:41 AM   #3 (permalink)
AFSil80's Avatar
AFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthyAFSil80 The posts made by this user are trust worthy
Points: 627,337,600, Level: 100
Points: 627,337,600, Level: 100 Points: 627,337,600, Level: 100 Points: 627,337,600, Level: 100
91 if you want powersteering.
The A/C high pressure line from the KA24DE fits, low pressure does not. Flare is too big.
I'm not sure if SOHC lines will work since they require 2 bolts per line.
-Peter -91 240SX, CA18, 17x9/18x9 Nismo GT2's, Silvia front...T04E upgrade in progress...
BYAH
Originally Posted by fonix36 View Post
AFSil80 you are the first person on internet to piss me off. good fucking job
AFSil80 is offline   Reply With Quote
Old 02-23-2008, 03:52 PM   #4 (permalink)
ok thanks i have a 93 right now. just making sure thats all.
Old 02-23-2008, 07:47 PM   #5 (permalink)
You'll also have to get a SOHC throttle cable if you didn't know that yet.
Old 02-23-2008, 10:37 PM   #6 (permalink)
AFSil80's Avatar
^ Damn, forgot that one, haha.
I'm trying to think if there's anything else.
Stock radiator will work...someone else chime in, haha...you've got the right gauge cluster.
You must also swap over the KA 5-speed tranny sensors (including speed) in order for them to work.
EDIT: And by 'work' I mean, read properly.
BYAH
Old 02-24-2008, 11:34 PM   #7 (permalink)
AFSil80's Avatar
Another:
You'll need to extend the starter wire, or splice/solder the one from the KA24DE and use that plug.
I chose the latter, because I hate butt connectors. I solder everything I can, unless the position sucks.
BYAH
Old 03-26-2008, 09:37 PM   #8 (permalink)
JBHELL is on a distinguished road
Points: 1,105, Level: 18
Points: 1,105, Level: 18 Points: 1,105, Level: 18 Points: 1,105, Level: 18
I Was Wondering What Driveshaft Would You Need For The CA? Would The Automatic Driveshaft work? Thanks Let LMK
JBHELL is offline   Reply With Quote
Old 03-27-2008, 09:41 PM   #9 (permalink)
IWantRWD's Avatar
IWantRWD is on a distinguished road
Points: 3,099, Level: 34
Points: 3,099, Level: 34 Points: 3,099, Level: 34 Points: 3,099, Level: 34
when i did the CA swap i used the stock DOHC everything. The throttle cable i just pushed in the holder and put a couple zip ties around it, or you can custom make one, either will work.
Im not sure if i used the DOHC or CA lower harness because i had to splice the trans sensor plug into the fusebox plug because they were 2 female plugs..
Chuki fan club member #23
92 black hatch, The Stripper
IWantRWD is offline   Reply With Quote
Old 03-27-2008, 10:26 PM   #10 (permalink)
articzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthyarticzap The posts made by this user are trust worthy
If I'm not mistaken, only the 5 speed drive shaft will work.
1990 240SX
300 whp CA18 Coming Soon
articzap is offline   Reply With Quote
Old 01-13-2010, 08:31 PM   #11 (permalink)
corrigan989 is on a distinguished road
Points: 40, Level: 1
Points: 40, Level: 1 Points: 40, Level: 1 Points: 40, Level: 1
im looking at getting a 240 soon. i dont want an n/a motor and im deciding if i want to do a sr20 or ca18 tubo. i wanted to know do both motors just bolt in using stock mounts and crossmembers, also if i bought a swap online and it comes wth an uncut wire harness would that include both upper and lower
thanks for any info
corrigan989 is offline   Reply With Quote
Old 01-14-2010, 05:02 PM   #12 (permalink)
Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19 Pharaoh19
corrigan989 just for future reference this is usually a FAQ in every section. Try reading the FAQs about the Sr20 and CA18 or use the "Search" button. I guarantee you'll get results a lot faster if you search first.
Pharaoh19 is offline   Reply With Quote
Swap Question, should i upgrade my turbo now? or later? S13ontap SR20DET Engines 11 11-28-2007 12:33 PM
CA18DET SWAP questions?? fastezz SR20DET Engines 4 04-27-2004 09:06 PM
KA24DE swap, and swap again jake_s14 KA24DE/T and KA24E 7 07-01-2003 10:16 AM
CA18DET swap Nismo241 SR20DET Engines 2 01-02-2003 10:44 AM
Nissan 240SX Forums Home Index - Nissan For Sale - Archive - Privacy Statement
