*ca18det Faq*
36K views 1 reply 2 participants last post by  WeldingHank
*ca18det Faq* updated 3/16
Basic Info
Displacement - 1809cc
Bore - 83mm
Stroke - 83.6mm
Compression - 9.5:1(DE) 8.5:1(DET)
Horsepower - 135 HP @6400RPM(DE) 175 HP @6400RPM(DET)
Torque - 115 ft/lbs @5200(DE) 166 ft/lbs @4000(DET)
Tune up stats
Timing marks -The six marks on the crank pulley read clockwise are -5, 0, 5, 10, 15 and 20 degrees respectively.
Timing - 15*BTDC(DE(T))
Idle speed - This is set via a valve solenoid on the intake manifold. In the center of the plenum aiming to the front is a valve with a gold cylinder with a plug on it. Unplug it and adjust the idle speed with the 10mm bolt on the back of the valve then plug it back in.
Idle speed - 800RPM(DE) 750RPM(DET)
Spark Plug - NGK PFR6A-11 or equivalent Gap - 1.1 mm
Fuel Injector - Top feed, 370cc
Oil filter - Fram 3682, 3614 or equivalent (4qts with these)
How to PROPERLY set the timing on the CA
-warm car up to NOT
-remove decorative coilpack cover
-remove the plug going to the coilpack on the #1 cylnder
-remove the 4 bolts holding the coilpack in place
-remove the coil pack
-get a spark plug wire
-attach one end to the spark plug
-remove the rubber boot on the coilpack
-using electrical tape, attach the other end of the plug wire to the coilpack
-plug the coilpack back in
-set coilpack someplace that allows the body of the unit to be grounded
-attach the inductive pick up to the plug wire
-attach positive and negative power leads to the battery
-start the car
-point timing light at the crank pully
-it should read at 15*BTDC
-if timing is incorrect loosen the 3 bolts that secure the CAS and adjust left/right until the timing is at 15*BTDC
-retighten the 3 bolts and recheck the timing
-turn off the car
-reinstall the coilpack, plug the coilpack in, and reinstall the decorative cover if desired
-enjoy your newly timed car!
*Important Facts*
- you can use any low imp. top feed injectors (dsm 440's will drop right in with the lower CA o rings
- stock bottom end has been proven to hold over 300hp with proper fuel management
- these engines are a minimum of 15yrs old, so expect some parts to be in need or replacement
- its not a bad idea to tear down the bottom end an inspect main and rod bearings
- install is almost identical to the sr, same with mods to the wiring harness
- head design is better than sr CA-8 port head /SR-4 port head
- KA clutch will bolt right in, one of the pins on the flywheel just needs to be pulled off with vise grips
- use ONLY the CA18ET water pump, the DE pump does not align correctly when the DET pully is used, unless you use the DE pump and the DE pully
- iron block and all forged internals
- lighter than the SR (44lbs)
- any KA radiator works perfectly
- s13 SR hot pipe will work for a fmic, but not smic
- SR downpipe works fine with the sr o2 housing
- SR t25's and t28's are both upgrades
- nismo sr/ka mounts will work but engine sits about an inch higher (nismo does make CA specific mounts, havent found them in the states tho)
- KA sohc maf works
- ca18et and ca20e bellhousings will bolt onto your ka tranny with no alignment probs, and youll have a longer 5th gear
- head bolts are a 10mm allen wrench
- oil filter is same as 240sx unit
- 3 wire universal o2 sensor works fine
- stock flywheel is 26.8 pounds
- flywheel bolts ARP #151-2801 (Ford Pinto 2000cc)
here are the colors and orders for the injector wires
Injector # 1 the closest to the Cas,
white/black
white
Injector #2
yellow/black
yellow
Injector #3
Green/black
green
Injector #4
blue/black
blue
OEM Parts
http://www.ca18det.org/parts.html
that site lists alot of good part numbers but basically the rwd det is the same as the fwd de that came in the 88 pulsar nx se, some parts can also be used off the 85 200sx with the ca18et
CA18DET Aftermarket Parts
raretrick
takakaira
Ebay CA parts
JGYcustoms CA spec clutch kits
Other useful links
http://www.impactblue.org/content/display.php?page=caref.efi_harness
http://srownersclub.com/faq/index.asp
CA fsm
credits to: WeldingHank, ca18det.org, sdtouge, mohnissan and of course me
Taken from CA18DET.org
If you are looking for parts, tell the autoparts store that you have an 88' Nissan Pulsar NX SE. It will be the correct part 99% of the time!
Oxygen Sensor CA18ET 200sx Bosch 13276 $47.99
Spark Plugs CA18ET* 200sx NGK PFR6A-11 $Varies
PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99
Thermostat CA18DE Pulsar NX 491-180 $4.99
Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89
Water Pump** CA18DE Pulsar NX B150-1350 $33.99
Upper Rad. Hose KA24DE 240SX L-564 $7.99
Lower Rad. Hose KA24DE 240SX M-563 $7.39
Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49
Alt Belt 4pk855 $9.99
PS Belt 4pk845 $8.99
AC Belt 4pk840 $8.99
* Exhaust side needed
** Includes Gasket
Other Spark Plug Options:
PFR6/BCPR6's for standard (gap of 1.1mm)
PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you)
BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level)
Oil filter 15208-H8911 Ryco Z386 or Ryco Z145A
Door bump rubbers 01658-J7000 (Skyline R31)
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces
Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head
Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner
Intake manifold gasket 14035-53J10 (SR20 all)
Turbo inlet flange gasket 14415-75F10 (200SX)
or 14415-17M00 (S13 all) The Aust 200SX one fits.
Turbo outlet flange gasket 14445-26E00 (S13 all)
Engine front oil seal 13042-42L00 (CA18 all)
Engine rear oil seal 12279-18V00 (CA18 all)
Oil pan seal front 11121-01F10 (CA18 all)
Oil pan seal rear 11121-01F15 (CA18 all)
Head gasket 11044-51E00 (CA18 all)
Head gasket 11044-50F00 (SR20) until 9/92
Head gasket 11044-50F01 (SR20) from 9/92 till 7/93
Head gasket 11044-50F10 (SR20) from7/93 onwards
Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits
Engine gasket kit 10101-56E25 (CA18DET)
Engine gasket kit 10101-50E25 (SR20DET)
Engine gasket kit 10101-51E26 (SR20D)
Flywheel Bolts 12315-55M00 $2.18
Valve grind gasket kit 11042-51E25 (CA18 all)
Valve grind gasket kit 11042-50F25 (SR20 all)
Fan belt 11720-V7301 (CA18 all) L = 855mm
Fan belt 11720-52F00 (SR20 all)
Compressor belt 11920-V7301 (CA18 all) also suits power steering pump
Compressor belt 11920-30R10 (SR20 all) also suits power steering pump
Water pump 21010-V5528 (CA18) until 8/90
Water pump 21010-V5529 (CA18) from 8/90
Water pump 21010-52F00 (SR20 all)
Thermostat 21200-V0201 (CA18 all) 82.0 C
Thermostat 21200-V0206 (CA18 all) 88.0 C
Thermostat 21200-53J00 (SR20 all)
Radiator cap 21430-01F01
Radiator hose - upper 21501-35F10 (CA18 all)
Radiator hose - lower 21503-35F00 (CA18 all)
Radiator hose - upper 21501-52F00 (SR20 all)
Radiator hose - lower 21503-52F00 (SR20 all)
Bonnet bump rubbers (large) 62840-D0100 (Skyline R31)
Engine coolant 10120-89904 Castrol
Dash switch back lights Nissan Aust, have similar types
$11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each
Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Wheel nut 62840-21001 (R31 Skyline)
Brake pads See service info page. Bendix and others.
heater hose w/valve part 02-0036 or p/n ch1649 same as 1988/90 holden commodore 3.8ltr
(needs to be cut slightly)
Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam.
Rear Dampers
( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb.
Approx $315 a pair.
Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 or Z201
Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1
Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
Spark plugs 22401-53J16 (PRF6B, SR20DET)
Crank angle sensor 23731-85M10 (CA18 all)
Crank angle sensor 23731-50F01 (SR20 all)
Coolant temp sensor 25080-89903 (S13 all)
Steering Rack Boot (LHS) 48203-10V25 (same as local 300ZX, mabey R32 also)
Oil pressure sender unit 25210 89920 (generic nissan??)
Oil pressure sender 25240-89920 (S13 all)
Cam shaft timing belt 13028-51E25
Cam belt idler bearing 30BD219DWAX
Cam belt tenioner bearing. 35BD219DWAX
Clutch Master Cylinder rebuild kit. PBR Aust. K8690 (contains pistons).
K7689X (rubber components only).
Clutch Slave Cylinder 3062069F03
S13 Main Handbook (English) Nissan Publication SM9E-OS13G0 $230 tax ex.
RS13 Service Manual, Main Issue (Japanese) Nissan A008009 $143 Tax Ex
SR20DET S13 Engine supplement Nissan A008011 $187 Tax Ex
SR20DET S13 Wiring supplement Nissan A108012
crank sprocket - 13021-D4200 - $29.26
woodruff key - 00926-51900 - $1.02
crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
Turbo Manifold gaskets -> head:
14036-D4201 (x2)
14036-D4202 (x2)
KA24 and CA18 use the same radiators (Unlike the SR) with both ports on the USDM passenger side
www.raretrick.com seems to carry quite a few CA products, including SAMCO CA18DET upper and lower radiator hoses as well as turbo hoses.
for the water pump, if you use a pulsar pump you need a FWD pulley. get a CA18ET (S12 200sx) if you want to use the stock pulley.
