Removing shifter, c-ring removal tool? Please help :) - Nissan 240SX Forums
post #1 of 14 Old 05-27-2005, 01:47 PM Thread Starter
K-1
K-1's Avatar
K-1 is on a distinguished road
I tried, and could not use any of the available needle nose pliers I could find to remove the damn C-ring.
I went and bought the closest thing I could find to a C-Ring tool, a snap-ring tool. Way too flimsy for the C-Ring, just lost the grip every time I'd try to pull it up + out.
I tried using multiple screwdrivers, and I can't do it.
I just need to replace that inner shifter boot, it's busted open, and my car smells like tranny fluid, lol.
Where can I find a tool that is designed to remove this C-Ring? Is it a special dealership tool, or a generic tool? Would NAPA or Sears have it, cause autozone doesn't. Has anyone found one online? Thanks for any advice...
K-1 is offline
post #2 of 14 Old 05-27-2005, 04:07 PM
ZeroBladeImpact's Avatar
ZeroBladeImpact is on a distinguished road
There are two types of ring removes. inner and outter... you just have to find the one that closes teh c-ring up. I know I had to do it myself.. try sears or even bug teh snap-on man if all else fails.
ZeroBladeImpact is offline
post #3 of 14 Old 05-27-2005, 04:31 PM Thread Starter
K-1
K-1's Avatar
Ill swing by sears, see what they can do.
Thanks.
K-1 is offline
post #4 of 14 Old 05-27-2005, 09:04 PM
ConceptS14's Avatar
ConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthyConceptS14 The posts made by this user are trust worthy
Points: 682,366,731, Level: 100
Points: 682,366,731, Level: 100 Points: 682,366,731, Level: 100 Points: 682,366,731, Level: 100
i got it with needle nose pliers.
ConceptS14 is offline
post #5 of 14 Old 05-27-2005, 10:34 PM
wussmonster's Avatar
wussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthywussmonster The posts made by this user are trust worthy
Points: 214,762,908, Level: 100
Points: 214,762,908, Level: 100 Points: 214,762,908, Level: 100 Points: 214,762,908, Level: 100
^^ so did i
check it --------->
**computer consultant**
sdtouge: windows 2000 is missing or corrupt it says
sdtouge: i think its frmo too much porn?
sdtouge: it wont start lol
wussmonster is offline
post #6 of 14 Old 05-27-2005, 11:25 PM
Revolution240sx
Guest
Posts: n/a
Quoted: Post(s)
my regular needle nose pliers didn't fit, but i have a smaller pair, too... small needle nose pliers should be able to do it, and if you're going to buy a tool anyway, might as well buy something you'd use more often than a c-ring remover.
post #7 of 14 Old 05-28-2005, 12:00 AM
Xracer's Avatar
Xracer is on a distinguished road
Points: 77,273, Level: 100
Points: 77,273, Level: 100 Points: 77,273, Level: 100 Points: 77,273, Level: 100
lol, take 2 crew drivers and insert it into the slots, pry it together and pop the first one out. second one sildes right out after that.
^^highlight it^^
Xracer is offline
post #8 of 14 Old 05-28-2005, 12:46 AM
Drift_Stylez is on a distinguished road
i used a flathead.. only took a few mins
Drift_Stylez is offline
post #9 of 14 Old 05-28-2005, 01:47 AM Thread Starter
K-1
K-1's Avatar
I'll try to buy some smaller needle noses, and if I can't get it with that, I'll try to find a C-ring tool.
I don't know why I had such a problem with mine, if you guys got it out with screwdrivers in a few minutes...
Thanks for the advice everyone, hopefully my car will smell fresh and clean soon
K-1 is offline
post #10 of 14 Old 05-28-2005, 01:55 AM
sleepyRPS13's Avatar
sleepyRPS13 is on a distinguished road
flathead is the best to use, especially when removing it.
23#PFC
INSOMNIA
sleepyRPS13 is offline
post #11 of 14 Old 05-29-2005, 03:54 PM Thread Starter
K-1
K-1's Avatar
I got everything taken care of. Thanks for the advice everyone.
K-1 is offline
post #12 of 14 Old 05-29-2005, 04:30 PM
what did you end up using?
post #13 of 14 Old 05-30-2005, 02:08 AM
amaroy is on a distinguished road
yeah i used 2 flathead screwdrivers, it took about 10 minutes. I thought my screwdrivers were about to break.
amaroy is offline
post #14 of 14 Old 05-30-2005, 04:58 PM Thread Starter
K-1
K-1's Avatar
Some needle nose pliers, and 2 screwdrivers. Still took me almost 15 minutes to take it out, and another 15 minutes to put the c-ring back in.
If I was doing this task alot, I'd buy the tool Nissan expects it's tech to use, but for a 1 time removal, just try everything else you can think of.
K-1 is offline
C's short shifter help Nines RB Tech 5 04-07-2005 12:19 AM
What's a good spyware removal tool? D1GP Off Topic Chat 2 04-03-2004 04:50 AM
Removing Shifter off Tranny........ JEWELL S13 240SX (89-94) 9 02-27-2004 04:14 PM
