Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > General Tech
General Tech For all general questions about 240SX
Closed Thread
Old 08-19-2005, 07:16 PM   #1 (permalink)
Drifternate is on a distinguished road
Wiring diagram for s14 stereo so i can tap into it for my boost gauge wiring
I need to know which wires to tap into for my greddy boost gauge. I need 12v power source, an ignition source, a parking light source, and a ground. Any suggestions? Thanks in advance!
Nate
Drifternate is offline
Old 08-19-2005, 09:34 PM   #2 (permalink)
Suck My Balls!
TwoFortySX's Avatar
TwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthyTwoFortySX The posts made by this user are trust worthy
Points: 1,846,294,978, Level: 100
Points: 1,846,294,978, Level: 100 Points: 1,846,294,978, Level: 100 Points: 1,846,294,978, Level: 100
Nate
i dont have a s14 FSM here at work but... if you have an aftermarket head unit then you can tap into those wires from the back of that which i do know off top of my head.
yellow is 12v constant
red is 12v switched
black is ground of course
and orange is the illumination or parking lights.
TwoFortySX is offline
Old 08-20-2005, 12:22 AM   #3 (permalink)
Sexual Banana's Avatar
Sexual Banana is on a distinguished road
Orange/green - Battery
Light blue - ACC/ignition
Red/light blue - Lighting switch
Red/yellow - Illumination
Ground - Anywhere metal! I think grey is the radio ground tho.
Thats for a 95 w/ cd player anyway...
Sexual Banana is offline
Old 08-20-2005, 02:26 AM   #4 (permalink)
honduh is on a distinguished road
this is straight from the12volt.com, best electrical forum on the net, also this is for a 98 240 so i'm not sure if all s14's are the same, but here ya go
Constant 12V+ White Ignition Switch Harness
Starter Black/Yellow Ignition Switch Harness
Ignition Black/Red Ignition Switch Harness
Ignition 2 White Ignition Switch Harness
Ignition 3 White Ignition Switch Harness
Accessory White/Blue Ignition Switch Harness
Tach Yellow/Red ECM in Passenger's Kick Panel, Position 3 in 120 Pin Connector
Neutral Safety Wire Orange/Yellow
Brake Switch Red/Green Brake Switch
Trunk Pin Red (-) Anti-Theft Module
Parking Lights Red/Blue Switch on Driver's Kick Panel
Head Lamp Red/Yellow L And Red/Blue R at Ignition Switch Harness
Factory Disarm Green/Yellow (-) Driver's Kick Panel
Door Trigger Red/White (-) Driver's Kick Panel
Door Lock Light Blue/White (-) Security Module Driver's Kick Panel
Door Unlock Brown (-) Pin 18 at Security Module
Horn Wire Green/White (-) Under DAS Driver's Side
Windows Down LF=Blue, RF=Red/Black
honduh is offline
Old 08-20-2005, 04:45 PM   #5 (permalink)
Talking
Thanks for all the help guys, Ill have it wired this afternoon so i can finally know if i have my wastegate working fine. And so I wont be scared to rev the shit out of it and who knows, there may be a high speed run in the works also. Anyways, thanks again.
Nate
Old 08-20-2005, 07:33 PM   #6 (permalink)
alkemyst's Avatar
alkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthyalkemyst The posts made by this user are trust worthy
Points: 202,568,649, Level: 100
Points: 202,568,649, Level: 100 Points: 202,568,649, Level: 100 Points: 202,568,649, Level: 100
S14 the parking lights are easy from the steering column...however there are two of them (one is the right headlight)...I believe the right for just the parking lights is the one is the one closest to the driver's door. If you need me too I can find out for you in a couple seconds.
Those wires in the kick panel are a bitch...they are like 40AWG and no slack (this is ideal from a factory perspective...low resistance). My door 'trigger' one got sheared in two by the previous owners T-Tap, which caused me BIG HEADACHES on my first alarm install. I had to pull the small junction box out, and tie in a new piece of wire. I had to tap it for my dome light supervision and door pin monitoring for my alarm.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit, I beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline
Old 04-21-2010, 02:42 AM   #7 (permalink)
240SX Newbie
Mechman is on a distinguished road
Points: 766, Level: 14
Points: 766, Level: 14 Points: 766, Level: 14 Points: 766, Level: 14
red is 12v switched
That would be hilarious is every time your sub hit, you wastegate opened.
Mechman is offline
Old 04-21-2010, 05:16 AM   #8 (permalink)
240SXForums Slut
240-kid's Avatar
240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy240-kid The posts made by this user are trust worthy
Points: 2,147,663,153, Level: 100
Points: 2,147,663,153, Level: 100 Points: 2,147,663,153, Level: 100 Points: 2,147,663,153, Level: 100
Activity: 92%
Activity: 92% Activity: 92% Activity: 92%
C'mon, 05'? Really...
Get your shit Straight!
240-kid is online now
Closed Thread
Stereo wiring diagram Nismo_S14ks Audio 0 09-15-2004 07:37 PM
Stereo wiring diagram Nismo_S14ks Audio 0 09-15-2004 07:36 PM
95 s14 stereo wiring diagram? Nismo_S14ks Audio 1 09-15-2004 09:31 AM
Gauge Issue CapnNismo Nissan S13 240SX (89-94) 14 07-22-2004 01:28 PM
stereo wiring diagram.. tufordee_essex Audio 6 09-17-2003 01:53 AM
