Jank Ass Walmart Wiring Harness - Nissan 240SX Forums
I.C.E. Audio, Video, Security & In Car Entertainment chat here.
post #1 of 13 Old 12-10-2005, 11:45 PM Thread Starter
Creizai's Avatar
Creizai is on a distinguished road
The only wiring harness I could find was as my friend calls it "The Jank Ass Walmart Harness". Anyway we've matched all the colors and did the ground to the bolt that holds the cd unit in place. It doesn't power on and we checked the fuses they are not blown.
I have an Alpine CDA-9847 and of course .. "Jank Ass Walmart"
Creizai is offline
post #2 of 13 Old 12-11-2005, 12:24 AM
WarX is on a distinguished road
The antenna is plugged in as well? By matchin up the colors, did you make sure all the wires were the same? some harnesses swap colors. Chances are they don't, but occasionally they do. White/Grey/Purple/Green are speakers...Orange Illumination. Red 12volt, Yellow Ignition. Blue Rem Turnon, Blue w/ stripe Power Antenna lead. Black Ground...obviously...Radio fuse isn't blown as well i'm assuming?
WarX is offline
post #3 of 13 Old 12-11-2005, 12:27 AM Thread Starter
Creizai's Avatar
Antenna is not plugged in because it needs an adapter or something. I am by passing all the other speaker wires since I'm going RCA to Amp then Amp to Speakers.
Creizai is offline
post #4 of 13 Old 12-11-2005, 11:27 AM
Fidelity101's Avatar
Fidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthy
Points: 948,461,230, Level: 100
Points: 948,461,230, Level: 100 Points: 948,461,230, Level: 100 Points: 948,461,230, Level: 100
Activity: 13%
the S13 antenna connection is a coax one, its got its own funky like 3 prong connector, its really shitty, I paid 12 bucks for the connector and i dont even use the radio.
Fidelity101 is offline
post #5 of 13 Old 12-11-2005, 04:49 PM
plv
plv is on a distinguished road
i didnt plug my antenna in and my JVC works fine, so that shouldnt be an issue.
plv is offline
post #6 of 13 Old 12-11-2005, 06:43 PM
dru
dru's Avatar
dru will become famous soon enough
Points: 13,172, Level: 74
Points: 13,172, Level: 74 Points: 13,172, Level: 74 Points: 13,172, Level: 74
Activity: 11%
try a different ground
1991 e30 - m52b28 - funz0rz
1989 e30 - m20b25 - DD
dru is offline
post #7 of 13 Old 12-11-2005, 08:07 PM Thread Starter
Creizai's Avatar
It was the Antenna, bought an adapter and it works now, but were having problems with the passenger side handle screw major. Oh well left side is going good though.
Creizai is offline
post #8 of 13 Old 12-12-2005, 12:15 AM
Same thing happened to my 01 Alty. It seems like alot of Nissans have issues with that. Antenna sometimes needs to be plugged in, it's another type of ground for the radio i'm assuming.
WarX is offline
post #9 of 13 Old 12-12-2005, 05:49 PM
dopeassjackson is on a distinguished road
the wallmart harnesses are just fine. its wires with a plastic connector how bad could they be. thats where i got mine from worked the first time i hooked her up. check your wire color.
yellow is the dimmer
red power and
black is ground
i had to make my own ground you might also. try touching the black wire to somthing metal on it car.
Tein S tech springs
stage 3 clutch (pro clutch)
ported head and secondaries removed
Z32 fuel filter
B&M short shifter
JGS motor mounts
dopeassjackson is offline
post #10 of 13 Old 12-17-2005, 12:14 PM
240z4u's Avatar
240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy240z4u The posts made by this user are trust worthy
Points: 955,906,832, Level: 100
Points: 955,906,832, Level: 100 Points: 955,906,832, Level: 100 Points: 955,906,832, Level: 100
The only reason it works with the antenna plugged in is because it grounded the deck. Get a better ground, grounding through antennas is jank in itself. you will have much better reliability if you do that.
Evan
240z4u is offline
post #11 of 13 Old 12-17-2005, 12:50 PM
uno
uno's Avatar
uno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud of
Evan
exactly my atenna is not plugged in on my panasonic and it's worked fine for 4 years now.
1993 240sx w/CA18DET + Boltons *Gone*
1999 Z28 A4 w/ Catback, SLP Lid, K&N
2004 RX8 Auto Stock *Gone thankfully
2003 Mach 1 M5 w/ exhaust
1993 Integra LS 5 speed Stock , gas saver
uno is offline
post #12 of 13 Old 12-26-2005, 08:47 PM
Activity: 13%
yeah i drove around with no stereo for like 4 months and that was hard but the attena wasnt in and it really didnt matter.
post #13 of 13 Old 12-27-2005, 12:45 AM
garbury is on a distinguished road
Points: 2,980, Level: 33
Points: 2,980, Level: 33 Points: 2,980, Level: 33 Points: 2,980, Level: 33
Mine wouldnt work because of a ground. Walmart sells some decent car audio stuff...Isn't the harness a scosche?
garbury is offline
Sr using KA24e wiring harness S14DRiFtMaTic SR20DE & DET 9 11-16-2012 09:54 PM
Wiring Harness under fender-How to move? rapanett S13 240SX (89-94) 10 02-27-2005 11:08 PM
help with wiring harness mrred2 S13 240SX (89-94) 0 02-03-2005 02:31 AM
quick Q!, wiring harness gbeto General Tech 4 09-12-2004 10:12 PM
SR20DET wiring harness HowdeeHo SR20DE & DET 5 10-08-2003 02:58 PM
