Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > Installation Guides
Installation Guides **For install posts only**
LinkBack (2) Thread Tools
Old 10-06-2006, 06:16 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
dkdeleon's Avatar
dkdeleon is on a distinguished road
wiring a stanza electric dual fan in s13
First you have to remove mechanical fan and condensor fan. Then what i did was take my condisor fan motor(small electric fan in front of radiator) and replaced one of the dual fan motors with that motor, so that fan would connect to the factory wiring harness connector and will turn on when you turn the A/C (do not forget to connect the condensor fan connector together). On the stanza duel fan setup there are 4 wires, black,yellow,green and blue. the yellow and blue wires are for the 1st speed which is push and the black and green wires are for the 2nd speed which is pull. You want to use the black and green wires, you can tape off the other two wires you dont use. You run the green wire to a 12v ignition in the fuse box and ground the black wire. This will turn the fan on when you start the car and work in place of the belt driven fan which you should have already removed. Then you will notice that the dual fan shroud needs to be shaved down on the sides to fit behind the radiator, after you shave the sides down to fit install and zip tie or bolt the fan to the radiator. Then turn the ignition to the on position and see if the one fan come on and then start the car and turn on A/C and see if the other fan comes on. Then drive and take notice to the cooling gage and how it is cooling. also notice a little more power from no belt driven fan.
I'm a mushroom cloud lay'n mutha fvcka, muyha fvcka
dkdeleon is offline   Reply With Quote
Old 10-06-2006, 11:34 AM   #2 (permalink)
Maireeka's Avatar
Maireeka is on a distinguished road
Nice how to. Next time I see a stanza in the junkyard I'm for sure gonna jack the fans!
A couple of critiques: maybe you should put a few paragraphs in there, and a picture would be great.
Pignose fan club member #260
1989 240sx fastback. VLSD (yes!), Ka24e with 2.25" exhaust, cat delete, front & rear STB's.
Looking for a 5spd in good condition for cheap! PM me.
Maireeka is offline   Reply With Quote
Old 10-25-2006, 01:16 AM   #3 (permalink)
Mr.180sx's Avatar
Mr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthy
or you can hook up the fan to the same power source and run a ground wire from the fan into your car .. hook up that end to a switch and then run another wire from the switch back out to another ground that way you can control the fan whenever you want
ground---------------switch-----------ground
2005 Suzuki GSXR 750 Track/Stunt
2005 Yamaha R6 Track (Black , Tuned , & Modded)
69 Chevy Camaro (Street ) Running Restoration project
Mr.180sx is offline   Reply With Quote
Old 10-28-2006, 06:45 PM   #4 (permalink)
murphy's Avatar
murphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthy
ugh theres like 3 types of stanza fans, which year did you use?
murphy is offline   Reply With Quote
Old 10-28-2006, 08:41 PM   #5 (permalink)
rollin_240's Avatar
rollin_240 is on a distinguished road
Points: 2,823, Level: 32
Points: 2,823, Level: 32 Points: 2,823, Level: 32 Points: 2,823, Level: 32
im assuming he was refering to the fans from a ka24e powered stanza. i think like 90-92 or around those years
rollin_240 is offline   Reply With Quote
Old 11-05-2006, 07:56 AM   #6 (permalink)
slidingsky's Avatar
slidingsky is on a distinguished road
Points: 4,800, Level: 44
Points: 4,800, Level: 44 Points: 4,800, Level: 44 Points: 4,800, Level: 44
Yep any KA powered Sentra. Another thing to look at but dont hold me to it is the spacing where you bolt the fans to the radiator should be right about 16.5 inches. The reason im saying dont hold me to it is because I have a Skyline radiator. I have measured the stanza fan setup and it is right at 16.5 inches.
slidingsky is offline   Reply With Quote
Old 11-05-2006, 10:21 PM   #7 (permalink)
murphy's Avatar
any pics? im kind of confused when you said you replaced the motor
and does an 88 have the right fans?
they look like this:
Old 12-29-2006, 06:06 PM   #8 (permalink)
teknobuzz89's Avatar
teknobuzz89 is on a distinguished road
Is there a writeup on how to get them working with a temp. sensor? I dont want mine ghetto rigged like that because if i forget to turn them on, boom goes my ka.
teknobuzz89 is offline   Reply With Quote
Old 12-29-2006, 10:39 PM   #9 (permalink)
dkdeleon's Avatar
if you read the post it is not ghetto rigged. when I said that I replaced one of the sentra fan motors with the original fan motor that went to the condenser fan on my 240 was so I would not be ghetto fying the connections, it connected to the original connector on the harness which is run off of the temp sensor.
The way I have it hooked up is the cooling fan turns on when you start the motor and the condenser fan turns on when it reaches a certain temperature and when you turn off the motor the cooling fan turn off also, SO THERE IS NO MANUAL SWITCH THAT YOU HAVE TO REMEMBER TO TURN OFF. If you would have read the whole post you would have known that. I'm sorry if that sounds like im being an asshole, im not trying to be one I mean it in a joking manor. cool?
Murphy, The fan you have pictured is not the fan that I used. the fan I used has the same size fans on both sides. hope that helps if not just ask me what you need to know and I will be glad to help you anyway I can. thanks
Oh I forgot, the fans are from a 92 stanza
Old 12-29-2006, 10:48 PM   #10 (permalink)
dkdeleon's Avatar
Thats Stanza not a Sentra.
Old 12-29-2006, 10:50 PM   #11 (permalink)
Oh my bad. I actually thought it was fully manual. Comment retracted.
LinkBack to this Thread: http://www.240sxforums.com/forums/installation-guides/89590-wiring-stanza-electric-dual-fan-s13.html
Auto Enjoy -> S13 DUAL STANZA E-FAN INSTALL This thread Refback 09-28-2009 10:14 AM
S13 Dual Stanza E-fan Write Up - The Touge This thread Refback 08-05-2009 10:42 PM
parts parts parts and guitar amp! carofchoice For Sale and Wanted 13 09-10-2006 02:57 PM
electric fan in s13 q's 240sxka24de-t Beginner’s Forum 3 01-26-2006 10:03 PM
electric fans and clutch fan... sdtouge General Tech 7 08-16-2005 08:51 PM
Electric fan question (did search) my92nx2kt SR20DET Engines 5 06-26-2004 10:40 AM
S13's supposed to have an electric fan? Neil Nissan S13 240SX (89-94) 6 06-09-2004 01:55 AM
