parts and step by step build
Ok i am going to give you a step by step list of what you need to do this. I assume you are going to be running a ka24DE. So heres what you do, go to sears first off and get a set of craftsman tools for like 120 bucks it will have 95% of what you need in there and whatever you dont you can get at like harbor freight or pepboys and stuff. As for buying a rebuild kit, yes ams makes a good kit but if it was me i would peice it together. Not for the fact that it would be cheaper but because maybe some stuff in the kit i dont like. Like calico coated bearings i am not a fan of more money for no gain. Just get the clevite bearings. They will do the job and last for a long long time.
Anyways heres a list of what my build is going to be, now keep in mind some of my stuff i am going to custom fabricate and also i used to work building race motors for midget dirt track cars so i have been through this multiple times and have experience fabricating stuff. Anything you can fabricate i would suggest doing it yourself.
KA-T Build Sheet
1. Cleveite Main & Rod Bearings- $75 (turbo240.com)
2. AMS Sportsman Series Rods- $395 (turbo240.com)
3. Arias 8.8:1 .020 over Piston Set- $449 (turbo240.com)
4. ARP Main Studs- $109 (turbo240.com)
5. ARP 11mm Head Studs- $111 (turbo240.com)
6. S14 Fel-Pro Gasket Kit - $125 (turbo240.com)
7. Crower Stage3 Cams- $350 (turbo240.com)
8. Supertech Dual Springs & Retainers- $375 (turbo240.com)
9. Supertech .7mm Oversize Inconel Exhaust Valves- $26 (turbo240.com)
10. Supertech .5mm Oversize Intake Valves- $19 (turbo240.com)
11. AMS Fuel System Kit w/ walbro fuel pump, liquid filled fp gauge, -6 SS line- $760 (turbo240.com)
12. Defi D-Series Temp Gauge- $140 (turbo240.com)
13. Defi D-Series Oil Pressure Gauge- $200 (turbo240.com)
14. Defi D-Series EGT Gauge- $200 (turbo240.com)
15. Defi D-Series A/F Gauge- $125 (turbo240.com)
16. Defi Blue Racer Boost Gauge- $200 (turbo240.com)
17. MSD SCI-L Ignition System- $250 (turbo240.com)
18. MSD Blaster Coil- $46 (turbo240.com)
19. NGK BKR7E Plugs- $12 (turbo240.com)
20. Plug Wires- $70 (turbo240.com)
21. Precision Turbo Intercooler- $450 (turbo240.com)
22. Tial 50.4mm Race BOV- $240 (turbo240.com)
23. Tial 38mm Wastegate- $259
24. AMS GT32/33 w/ external wastegate- $900 (turbo240.com)
25. O&J Performance Turbo Manifold- $600 (o&jperformance.com)
26. Calum Realtime ECU for S14- $375 (ka-t.org)
27. TunerProRT- $30 (google)
28. Nissan Data scan- $30 (google)
29. Calumsult- $free?
30. Competition Clutch Stage4- $395 (turbo240.com) or ACT 250mm clutch kit- $525 with Exedy 250mm chromoly flywheel- $495 (turbo240.com)
Make sure you send the pistons rods and crank out for a complete rotating assembly balancing should only run you between 80 and 150 bucks depending on the shop.
Now keep in mind not all of that stuff i listed is neccasary to have your motor boosted. But it is what i would recomend. Do it right the first time that way you dont have to pull the motor and build the bottom end when you feel that you need more power. Also with the rods you can get better ones but those ones will be more than enough for what would be a good power goal for you. The setup i have listed is capable of 400whp+ i would suggest getting a smaller turbo than the one listed such as a t28bb turbo off of an sr to start with unless you just want to go all out.
Keep in mind when your building the block this is what you need to do if you want it to come out the best it possibly can.
1. Tear the block down to a bare block
2. Send the block and head out to be machined (block will need to be bored .020 over and head should get port polish and port match, i would also send the intake with the head to get port matched to it. I would reccomend an aftermarket one as well)
3. When you get the block back inspect it and make sure that there are no sharp edges or burrs on the cylinders at the top (where the head sits) as it will cut the shit out of your hands when you try to put the pistons and rings in. If there are burrs get some 1000 grit or 800 grit WET SANDING PAPER and dunk it in wd40 and GENTLY take the burrs off. DO NOT HIT THE CYLINDER WALLS.
4. Thoroughly clean the cylinders with carb clean to get any chips or grime off of them and then spray them down with wd40 and wipe off the excess to keep them from rusting.
5. Take your arp main studs and install them I would put just a dab (about the size of a pencil erasor) on the threads inside the block that way when your running the studs through the torque cycles to stretch them they dont come out.
6. Torque cycle the studs. Do it in steps (the crank should not be in the block and neither should the bearings) Put the main caps on, put some arp moly lube on the nuts and studs and finger tighten all the nuts down. Torque all nuts to 30ft/lbs making sure to do it in one stroke with the torque wrench if you are using a wratcheting type as this will ensure accurate torque settings. Then torque them all to 60ft/lbs, then 75ft/lbs, then torque up to arp's recomended torque settings on the studs which if i remember correctly is like 85ft/lbs for the ka. Now loosen all the nuts and relube them. Now repeat the above process twice lubing the nuts both times. Now your studs have been torque cycled and stretched so that they will hold an accurate torque setting.
7. Now install your main bearings, lube them with some spray lube or the lube that comes with them, Torque all the caps up in steps to final torque setting that arp reccomends, get a micrometer and measure the diameter of the crank journals. Then use the micrometer to set a boregauge to the proper setting (i can go into that more with you later via email or pm) and check the clearances. I would ask ams what clearances they like to run on the crank. (it is possible you will need to get the block align honed but i am going off the assumption that everything is perfect for ease of explanation right now) Now install the crank and once again making sure you lube the nuts on the main studs torque them up in steps to final torque setting, make sure the crank spins freely but not too freely. Check for side to side and front to back play there should be just a skosh of play very little if any at all.
**NOTE: If you do not have a bore gauge go to your auto parts store and get some plastigauge with the right clearances to check these clearances (same thing for rods too)
8. Now for rods and rod bearings, (at this point you have also measure the journals that the rods go on as well with the micrometer and wrote the numbers down.) Set the bore gauge up to the numbers for each rod for each cylinder (it is going to change from rod to rod slightly) check the clearances and make sure the rods are in round (ams should have done this already with the rods that you order but just double check. Measure 4 times build once i always say)
9. Now start gapping your rings, on the ams website it tells you the clearances they like to run on the rings that come with the pistons you order.
10. Once your rings are gapped Install them on the piston with the correct spacing between the gaps.
11. Put the pistons on the rods.
12. Now get your ring compressor and slide the pistons down into the cylinders, put the bearings on and the rod caps and torque them to the provided specs.
13. Now moving on to the head, install your cams and torque the cam caps to FSM settings (Personally i would have the guy that ports and polishes the head install all teh springs retainers and lifters for you as it can get complicated)
14. Now put your head studs in with the dab of silicone again, and then drop the head on. Make sure you put the head gasket on first lol dont want to forget that. Then torque cycle the head studs the same way you did the main studs, making sure to use lube.
15. now slap the valve cover and oil pan on and your good to go just add fluids. Remember always double and triple check all your torque settings before you button the motor up.
Here is another link to a thread on ka-t.org that goes into more detail in some areas where i didn't. It took a long time to type this so I layed out a fairly detailed step by step process, anything that i didnt cover in much detail you will be able to get the info from this thread. If you have any questions at all feel free to pm me and i will try and answer them for you. But be specific as i dont want to type all this over again
Heres the link for the ka-t thread:
http://www.ka-t.org/forums/viewtopic.php?t=4156
Enjoy and let me know if you need more info on anything
