help me with my check engine lights - Nissan 240SX Forums
post #1 of 30 Old 12-01-2010, 10:29 PM Thread Starter
Future_RHD_SR20's Avatar
Future_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthyFuture_RHD_SR20 The posts made by this user are trust worthy
Points: 576,158,302, Level: 100
Points: 576,158,302, Level: 100 Points: 576,158,302, Level: 100 Points: 576,158,302, Level: 100
So i have five codes
Code 13- mass air flow sensor circut
Code 23-Idle switch (throttel valve switch) Signal circut open
Code 34- Knock sensor
Code 45- Injector fule leak
Code 51 Fule injector circut open
Okay so code 34 is obvious, swap out knock sensors and done deal
but what is all this circut bs????
and open circuts?
fule injector leak? that means open injector right? But how would i be able to find out which one? And how is the circut open? ugh im so lost
help me 240 genious'
Originally Posted by fonix36 View Post
Fuck you I'm not on welfare. I haven't been unemployed one second this year so suck on a dat one you fan boy bitch
Originally Posted by word sux View Post
sti - for the boy racer fan boy that wears fitted hats
Future_RHD_SR20 is offline
post #2 of 30 Old 12-02-2010, 12:02 AM
*ka24e*'s Avatar
Points: 2,147,503,903, Level: 100
Points: 2,147,503,903, Level: 100 Points: 2,147,503,903, Level: 100 Points: 2,147,503,903, Level: 100
Activity: 25%
The Cali KA24E had a knock sensor? That's the first I've ever heard of that.
Code 13- Make sure the MAFs plug is plug in, and make sure none of the wires are broken or corroded.
Code 23- The "Idle switch" is just another way of saying your TPS is bad or not plugged in.
Code 34- Like I said above, I've never heard of a KA24E with a knock sensor, but I would love to be proven wrong.
Code 45- Injector leak.... I'm guessing one is stuck open or is operating intermediately.
Code 51- I'm assuming this means a stuck injector. Ohm each injector. You'll know when you found a dead one, lol.
Real version, not the "Booty CD's" version.
*PM me if the link is down*
*ka24e* is offline
post #3 of 30 Old 12-02-2010, 11:43 AM Thread Starter
yeah i looked at autozone and no knock sensor for my single slammer. But why is ith throwing that code????????
and im buying all the parts listed for 50 shipped. Good deal no? even if i dont need all the stuff.
But eveerything is plugged in. What is my next step? Just replace them and call it a day?
post #4 of 30 Old 12-02-2010, 07:53 PM
*ka24e*'s Avatar
Activity: 25%
Are you sure its giving you code 34? Your buying a MAFs, TPS, an injector and I'm assuming o-rings for $50? That's a damn good deal, lol.
Oh, btw. I just double checked the codes. Code 13 is not the MAFs, its the CTS. Recheck the codes and see if you get a 34 again. My guess would be you got a 33 and just mistook it for a 34. 33 is the o2 sensor.
*ka24e* is offline
post #5 of 30 Old 12-03-2010, 02:12 AM Thread Starter
i watched and watched over and over. they are the right codes.
i think im getting the codes wrong, like a bad or wrong soruce
can you tell me what all five of the codes are?
Cause i just re did it and thoes are all the 5 codes im getting
thanks.. I knew you would be the only one on here helping fix my single slammer
post #6 of 30 Old 12-03-2010, 02:19 AM
*ka24e*'s Avatar
Activity: 25%
Your correct on all the codes except the Code 13, which is the Coolant Temp Sensor not the MAFs. What I would do first is make sure everything is plugged in. Make sure nothing accidentally came loose throwing a code. Once you do that, clear the ECU. Supposedly you can clear the codes just cycling from Mode 1, 2, 3, 4, 5 and back to Mode 1 but sometimes it doesn't work. I would disconnect the negative batt terminal, press the brake pedal a couple times and let it set for at least 5 minutes. This should clear your ECU of any fault codes.
After 5 min, reconnect the batt terminal and start the engine. Let it idle for 1 minute on the first start, don't rev it or anything. Go for a test drive and if the check engine light comes on, see what codes pop up.
*ka24e* is offline
post #7 of 30 Old 12-03-2010, 02:33 AM Thread Starter
maybe i have the wrong ecu in my car if its throwing that code for a sensor i dont have?
Well everysince i sea foamed my car the check engine light goes on and off daily. Like at least 5 times a day. Could that mean anything?
tomorrow ill get my dad to read the codes and see if he gets the same as me
post #8 of 30 Old 12-03-2010, 03:03 AM
*ka24e*'s Avatar
Activity: 25%
Just for reference, he's a list of SOHC ECU codes take directly from the FSM. I honestly have no idea how your getting 23, 34, and 51. Is it the stock ECU?
*ka24e* is offline
post #9 of 30 Old 12-04-2010, 02:21 AM Thread Starter
im thinking wrong ecu maybe?
i know its for a five speed cause i have a limiter and speed govener (not that id know, wink wink)
Cause i know the codes i wrote down have to be right. I watched them and played them back for ten minutes just to make sure
is there a difference in dual cam ecu's and single cams?
maybe i need a single cam ecu? How can you tell the difference?
post #10 of 30 Old 12-04-2010, 03:21 AM
*ka24e*'s Avatar
Activity: 25%
Use this. http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF
Look at the sticker on front and match the numbers to this chart. For example the ECU in the picture is a A11-B44-G70 and goes to a 91 Manual / Federal (non cali) 240sx KA24DE
*ka24e* is offline
post #11 of 30 Old 12-04-2010, 10:45 PM Thread Starter
there is sooo many lol
but that is going to help me alot. Im gonna check out tomorrow once the sun is out and its not cold
thanks again for always replying and helping
post #12 of 30 Old 12-05-2010, 02:02 AM
.SoCal-S13.'s Avatar
.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy.SoCal-S13. The posts made by this user are trust worthy
Points: 429,501,805, Level: 100
Points: 429,501,805, Level: 100 Points: 429,501,805, Level: 100 Points: 429,501,805, Level: 100
Activity: 28%
Activity: 28% Activity: 28% Activity: 28%
Fuel
Weld the diff. cut the springs. get a ton of drift spares. gas. money. practice event. and condoms for all the pussy you will get after
.SoCal-S13. is offline
post #13 of 30 Old 12-05-2010, 11:37 AM Thread Starter
i have a question.
what am i looking for? like which one. Cause on the chart there is like 30 for a single cam manule trans 90 240sx
post #14 of 30 Old 12-05-2010, 12:56 PM Thread Starter
okay we have a problem. I have the right ECU.
A11-B17 G13
guess i need to rewrite down the numbers
post #15 of 30 Old 12-05-2010, 06:58 PM
*ka24e*'s Avatar
Activity: 25%
I've heard you can swap a Federal ECU in place of your Cali ECU to eliminate the CEL..... Just saying, lol.
*ka24e* is offline
post #16 of 30 Old 12-06-2010, 01:42 AM Thread Starter
i was too busy to re write numbers but illl try to do it tomrrrow.
i want the CEL gone already.
Weird thing is that every since i sea foamed my car the check engine light comes on and off atleast 15 times a day (not exsaterating) depending on how much i drive it comes on and off
post #17 of 30 Old 12-06-2010, 04:28 AM
*ka24e*'s Avatar
Activity: 25%
Seafoam will cause CEL's sometimes. Imo, ATF cleans way better than seafoam, but will also kill your o2 sensor if you don't remove it before hand.
*ka24e* is offline
post #18 of 30 Old 12-06-2010, 12:14 PM Thread Starter
me and my dad are confused
here is a video
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid609.photobucket.co m%2Falbums%2Ftt179%2Fmalachi_is_supa_raw_yo%2F1206 000854.mp4">
post #19 of 30 Old 12-06-2010, 05:30 PM
*ka24e*'s Avatar
Activity: 25%
Video not embedded correctly. Just post the link up.
*ka24e* is offline
post #20 of 30 Old 12-08-2010, 12:54 AM Thread Starter
it was throwing codes like 03 and 05.
so i came up on a 90 5 speed ECU at the junk yard for the price of $free. Gonna swap that in and see what happens
post #21 of 30 Old 12-22-2010, 03:25 AM Thread Starter
So aft swaping ECUs. Getting code 55. Resting then i finally get a code that makes sense.
Code 32. Because before i ever sea foamed my car the light was constantly on. Now it goes on and off. So....How to fix this problem? I was thinking of just sea foaming again. But thats not good. But im going to the junk yard tommorrow. I know i need something to swap it out but idk what?
post #22 of 30 Old 12-23-2010, 02:58 AM
*ka24e*'s Avatar
Activity: 25%
With the engine running, reach behind the intake plenum and push the EGR diaphragm up (careful, it'll be hot if the engines warmed up). If the EGR is function correctly the engine will choke a little bit and start to stall. Also, make sure your EGR solenoid is plugged in, and check the vac lines as well. Here's a pic of the EGR solenoid.
*ka24e* is offline
post #23 of 30 Old 12-23-2010, 03:29 AM Thread Starter
Gotta try this out. Tomorrow is gonna be hectic but I'll try. If not. Sometime soon forsure. Thanks again kae
post #24 of 30 Old 12-23-2010, 05:23 AM
*ka24e*'s Avatar
Activity: 25%
Not a problem. If you need or can't find an EGR solenoid, I probably have several laying around.
*ka24e* is offline
post #25 of 30 Old 12-31-2010, 04:36 PM Thread Starter
everything is plugged in and nothing happenes when i push any of the lines, and none are cracked or anything. So do you think you could find me one sitting around?
How do i check my check engine light xllivillx Beginner’s Forum 1 07-11-2008 03:07 PM
S13 Lights Freaking? Check your tailights.. giant killer Resource Center 0 07-31-2006 07:39 PM
check engine light/engine diagnostics question ThomasK(Austin) RB Tech 1 11-23-2005 12:56 AM
Check Engine bukoone General Tech 1 03-04-2005 06:27 PM
Check out my custom tail lights [PICS] gogeeta13 S13 240SX (89-94) 43 10-17-2003 01:26 AM
