How many hours to replace timing chain? - Nissan 240SX Forums
Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > KA24DE & KA24E
240SXForums.com is the premier Nissan 240sx Forum on the internet. Registered Users do not see the above ads.
Old 03-30-2004, 05:14 PM   #1 (permalink)
S13lover's Avatar
Location: Hagerstown, MD (Home) Williamsport, PA (College)
S13lover is on a distinguished road
This is for a DOHC and I am replacing the upper and lower tensioners, guides, gears (except idler), and chains. I have a lift, another guy to help me, and just about any tool you can think of.
6 hours?
Funny how my "truck" motor was in more cars than trucks.
S13lover is offline   Reply With Quote
Old 03-30-2004, 07:05 PM   #2 (permalink)
red240ne's Avatar
red240ne is on a distinguished road
You can do it in six hours. Make sure you put all of the bolts in labeled zip lock bags or something. As long as you're organized and know what you're doing, then you can do it in 6 hours.
curt
red240ne is offline   Reply With Quote
Old 03-30-2004, 11:18 PM   #3 (permalink)
S13lover's Avatar
I'm on a kinda tight schedule to do this so I just wanted to make sure that it could be done in under 9 hours. I was hoping for 6, thats why I asked. Now I just hope I don't run into any problems, or I won't make it home from college next week for Easter break.
Old 03-30-2004, 11:22 PM   #4 (permalink)
89-240sx's Avatar
89-240sx is on a distinguished road
Points: 4,854, Level: 44
Points: 4,854, Level: 44 Points: 4,854, Level: 44 Points: 4,854, Level: 44
i have a tool that you could change the timing chain in less that an hour. probable even less than a half hour if you race through it.
89-240sx is offline   Reply With Quote
Old 03-31-2004, 12:09 AM   #5 (permalink)
w1ngzer0 is on a distinguished road
ugh. I don't know if i could do this i was reading the manual and looks frustraiting... :/
also how do you time your engine and what is liquid gasket?
w1ngzer0 is offline   Reply With Quote
Old 03-31-2004, 07:59 AM   #6 (permalink)
2002whitewrx is on a distinguished road
It's not to hard I think there is like 5 timing marks altogether that have to be lined up and it's good to turn the engine over and watch the valves to make sure it's in time and you don't have a piston smack a valve. My head is ported like crazy so I could see in real well but you can use a feeler gauge. Liqued gasket is a gooey stuff you put on the gaskets to make sure they seal good. Here is a pic of my timing chain install.
2002whitewrx is offline   Reply With Quote
Old 03-31-2004, 10:32 AM   #7 (permalink)
red240ne's Avatar
LOL. ur a loser.
curt
Old 03-31-2004, 08:03 PM   #8 (permalink)
S13lover's Avatar
Maybe you have some rigged up tool you put together that gets the top chain off and on quickly, but I'm replacing everything for the upper and lower chains.
Old 03-31-2004, 09:17 PM   #9 (permalink)
cool but timing it is my main problem i have no idea what involves in timing the motor
Old 03-31-2004, 11:34 PM   #10 (permalink)
S13lover's Avatar
Timing the cams with the marks is no big deal. With the lower chain 2 of the links will be painted. Then on the crank gear and idler gear there will be a dot near the teeth of the gear. When the lower chain is placed on the gears, the dots on the gears must be next to the paint marks on the chain. For the upper chain there are 3 marks on the chain. These paint marks must line up with the dots on each of the cam gears as well as the idler gear. Now that all 5 dots on the gears are next to all five painted links the cams will be in proper timing with the crank shaft.
Old 04-01-2004, 06:08 PM   #11 (permalink)
Zilvia240sx's Avatar
Zilvia240sx is on a distinguished road
i had a mechanic do it it took him almost 2 weeks to do it
Zilvia240sx is offline   Reply With Quote
Old 04-01-2004, 08:44 PM   #12 (permalink)
ndnspongebob's Avatar
ndnspongebob is on a distinguished road
maybe a newbie question...but honestly....wuts the benefit of a timing chain over a timing belt?
ndnspongebob is offline   Reply With Quote
Old 04-01-2004, 09:04 PM   #13 (permalink)
see man cars run 2 different kinds systems. One is belt one is chain. The ka24 is ran by chain the CA18 is ran by belt i belieave.
they all controll the cams and crank working with each other..
Is that last part right?
Old 04-01-2004, 09:06 PM   #14 (permalink)
S13lover's Avatar
Belts and chains do the same thing. Chains just last a lot longer and don't stretch.
Old 04-01-2004, 09:32 PM   #15 (permalink)
so the ka24de engine already has a chain instead of a belt?
Old 04-01-2004, 10:30 PM   #16 (permalink)
phrozen is on a distinguished road
my timing chain has 206k miles on it and runs good, i need to take off the 2nd tensioner tho cuz its making a lil noise, but there is no play in the chain at all
my key to happiness
phrozen is offline   Reply With Quote
Old 04-01-2004, 10:35 PM   #17 (permalink)
LiquidCache's Avatar
LiquidCache is on a distinguished road
Six HOURS? Maybe half that time if you know what you're doing, and I'm hoping since you've got a lift and assuming a full garage (air tools, etc) you know what you're doing.
definitely not half an hour, lol.
S30 was sold
S14 was totalled
'89 Coupe is still alive.
LiquidCache is offline   Reply With Quote
Old 04-02-2004, 01:20 AM   #18 (permalink)
i have a problem w/ my 240 where whenever i press on the acclerator..i hear like a jingling sound.....could this b the timing chain?
Old 04-02-2004, 01:12 PM   #19 (permalink)
ryans13 is on a distinguished road
get liquid gasket and a new front crank seal, also get a old cap and cut a hole where number 1 is, itll make setting up timing alot easier...get a fsm, chilton sucks, its about 1/4 of the actaul fsm copied
ryans13 is offline   Reply With Quote
Old 04-02-2004, 01:33 PM   #20 (permalink)
the ka24de runs chain yes
Old 04-20-2004, 10:05 PM   #21 (permalink)
n2os14 is on a distinguished road
alldata says almost 18 hours to replace it. lol they must have chimps woring on the cars
n2os14 is offline   Reply With Quote
Old 04-21-2004, 08:13 AM   #22 (permalink)
shit it took me around 30 hours to take a block with pistons in it and put the head on and timing chain switch all accersories from the motor in the car to the other one and pull the engine and install the new one.
Old 04-22-2004, 06:51 PM   #23 (permalink)
took me close to 15. pretty easy engine to do.
S30 was sold
S14 was totalled
Old 04-23-2004, 03:32 AM   #24 (permalink)
masterbunta is on a distinguished road
correction, belts stretch and then break, chains stretch but never break....unless a foreign object gets caught in the gears. Chains typically jump timing if they get too loose, the gear rotates under the chain causing it to be a tooth off or more. The V8 Mercedes are bad about this.
Dennis G. Mertzanis
Cell: 404.642.2690
Dennis.Mertzanis@DGTrials.com
www.dgtrials.com
masterbunta is offline   Reply With Quote
How much to replace timing chain Chinktank S13 240SX (89-94) 15 10-31-2011 02:20 PM
timing chain guide replacement publicenemy137 S14 240SX (95-98) 20 10-18-2004 12:14 AM
Timing Chain noise after change w30post General Tech 3 07-01-2003 01:57 PM
Replacing Timing Chain unfrgivn S13 240SX (89-94) 5 01-29-2003 03:06 AM
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
