Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > KA24DE/T and KA24E
KA24DE/T and KA24E Tuning guides, questions and recommendations
Old 10-26-2008, 02:04 PM   #1 (permalink)
MX500's Avatar
MX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthyMX500 The posts made by this user are trust worthy
Points: 19,098,597, Level: 100
Points: 19,098,597, Level: 100 Points: 19,098,597, Level: 100 Points: 19,098,597, Level: 100
KA24E valvespring and cam upgrade?
I've seen the power potential of the KA24E engine series and have decided to go a different route tha most. I've chosen N/A for a couple reasons.
Number 1 is that I'm broke as a joke and will be modding my engine with the insurance money I could have otherwise used for a silvia conversion
Reason number 2 is that I don't want to reduce the amount of space in my engine bay that makes these cars so darn fun and easy to work on.
I'm planning on getting a custom camshaft made by O&J performance, does anyone here have experience with them? They have good customer service and have great prices (their prices are honest, not like those crazy asians trying to charge $500 for a camshaft).
I plan on getting somewhere in the range of .500-.520 lift at the valve and maybe 5-10 degrees more duration than stock. I really need this engine to pass smog though and I HATE rev-happy engines so that is my reason for the rather low duration.
Are there any aftermarket valvesprings available for the KA24E? I don't want to cause my stock valvesprings to coil bind and destroy my head (or atleast the rockers), I also don't want any valve float in the 6000-6500 RPM range. I will not raise my rev limiter so there shouldn't be too much risk of valve float.
Other plans for this engine "build"
Chipped ECU, preferably tuned for my custom camshaft and to keep EGR permanently closed and pollute like a mofo.
I plan to buy another intake manifold set from the junkyard and port match everything and clean up the casting flaws. I've ported motorcycle cylinder heads before and had GREAT results with just a little work removing the casting flaws and port matching the intake and exhaust.
Possibly buy another exhaust manifold and port match it so whatever gasket I choose to run, if a gasket is needed (probably fel-pro).
I may add a small (20-50 horsepower) shot of nitrous later down the line. I'd like to add power without adding an unsafe amount of strain on the engine.
I will not buy a previously designed camshaft, but you may show me links if you would like to help sway my camshaft design a bit. I've checked out the Nismo cams and PAECO cams and really don't like any of their grinds. They have far too much duration and never enough lift for my taste. I want an engine that has more midrange but doesn't lose the low end grunt that made me fall in love with my 240 in the first place.
Opinions?
I'm off for now.
#1
1990 240SX, KA24E, Tanabe Coilovers, Tein tension rods, K&N, 3" cat. hit by camaro, skidmarks from crash below.
#2
1990 240SX #2, 180SX bumper, tein springs, tokico blues. Killed by a Bronco.
#3 1989 Coupe, ST rear swaybar, Minilites, 60K coil, DIY ported polished head...
MX500 is offline   Reply With Quote
Old 10-26-2008, 03:29 PM   #2 (permalink)
mikethebiker's Avatar
mikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthy
Points: 820,676,664, Level: 100
Points: 820,676,664, Level: 100 Points: 820,676,664, Level: 100 Points: 820,676,664, Level: 100
this is my... "old testament" of motor bibles
My Home Page
Colt/PDM cams have a multiple grinds, with some not much high duration, over stock duration and some with very high duration, but i know they do custom grinds. the nice thing about their technology is that they have designed their lobes to have staggered opening on one of the intake valves, so as to still make the swirl effect, or the high velocity air movement needed for the low end you want. im sure if you wanted one of their lower duration cams, you could tell them you wante dmore lift, im sure they would accomodate..
Other than the cam, that website has the link to the company that sells their stiffer valve springs, with a part number.
Now dont go to the j/y my friend, check this stuff out first
http://www.xcessivemanufacturing.com...l?id=16&step=2
if your going n/a, i would totally go with some headers. the torque loss wont be noticable and one you get the cam, they would probably help
My Build:
http://www.240sxforums.com/forums/sh...ate+ka-e+build
S13 Is An Old Ass Piece Of Shit And Will Get Zero Girls Checkin You Out
mikethebiker is offline   Reply With Quote
Old 10-28-2008, 12:19 AM   #3 (permalink)
MX500's Avatar
Thats a pretty good deal for a custom intake manifold but I'll need to pass smog in CA (unless I register my car to a PO box in a non-smog county and have my mail forwarded to my real address).
Thanks Mike! It turns out I didn't have that injector... I saw it in the junkyard and forgot it while scavenging for other parts.
#1
#2
Old 04-07-2009, 04:51 AM   #4 (permalink)
Nemesis3888's Avatar
Nemesis3888 is on a distinguished road
Points: 402, Level: 8
Points: 402, Level: 8 Points: 402, Level: 8 Points: 402, Level: 8
here u go buddy heres a link that has KA24e camshafts cheep O & J Performance KA24E Stage 2 Camshaft Mech Lifters
Nemesis3888 is offline   Reply With Quote
Old 06-25-2009, 07:15 PM   #5 (permalink)
e-rock's Avatar
e-rock is on a distinguished road
Points: 107, Level: 2
Points: 107, Level: 2 Points: 107, Level: 2 Points: 107, Level: 2
Hey do any of you guys know how to adjust your rocker arms? I have a KA24E thats making a ticking noise cause two of the exhaust rocker arms have some play. Id like to get some asap before i blow somthing up haha
Just Pin it
e-rock is offline   Reply With Quote
Old 07-01-2009, 04:27 PM   #6 (permalink)
nothing will blow up and no you cant adjust them
My Build:
Old 07-01-2009, 04:33 PM   #7 (permalink)
Lucky13garage. is on a distinguished road
Points: 1,183, Level: 18
Points: 1,183, Level: 18 Points: 1,183, Level: 18 Points: 1,183, Level: 18
Don't you have to run a solid lifter conversion with those cams?
PFC #302
Single slammer love
Lucky13garage. is offline   Reply With Quote
Old 07-01-2009, 08:45 PM   #8 (permalink)
o&jperformance's Avatar
o&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthyo&jperformance The posts made by this user are trust worthy
Points: 178,140,407, Level: 100
Points: 178,140,407, Level: 100 Points: 178,140,407, Level: 100 Points: 178,140,407, Level: 100
Here are the camshafts that you could use with the hyd lifters.
http://estore.websitepros.com/1636426/Detail.bok?no=278 Stage 1 Hyd Lifters
http://estore.websitepros.com/1636426/Detail.bok?no=277 Stage 2 Hyd Lifters
http://www.ojperformance.com/
http://www.oandjperformance.com/
240SX Performance Parts,Turbocharger,Chassis and much more
http://www.myspace.com/oandjperformance
Facebook O&J Performance
o&jperformance is offline   Reply With Quote
Old 07-03-2009, 03:55 PM   #9 (permalink)
e-rock's Avatar
Alright i fixed my ticking problem but i undid a couple of the top camshaft lobe bolts and i dont know the torque setting. Does anyone know it? i did them back up and ran it but now its running ruff and bogging
Just Pin it
Old 04-16-2010, 10:17 AM   #10 (permalink)
nicklebagfarley's Avatar
nicklebagfarley is on a distinguished road
Points: 819, Level: 15
Points: 819, Level: 15 Points: 819, Level: 15 Points: 819, Level: 15
I know this is kind of an old thread but with the O&J Cam can i run that with all my OEM valvetrain and ecu and injectors? or is do those need to be upgraded?
nicklebagfarley is offline   Reply With Quote
Old 04-16-2010, 11:15 AM   #11 (permalink)
*ka24e*'s Avatar
Points: 789,348,498, Level: 100
Points: 789,348,498, Level: 100 Points: 789,348,498, Level: 100 Points: 789,348,498, Level: 100
Activity: 27%
Activity: 27% Activity: 27% Activity: 27%
You can use there hydraulic cams with everything else stock. To use the mechanical cams, your obviously going to need solid lifters.
240sx Factory Service Manuals
I'm looking for a PC (desktop, no laptops). If you have one on the cheap, or would like to trade for some parts PM me.
Originally Posted by jjaammeess View Post
a friend of mine has already blown 4 SR's and he advised me to go with the KA
*ka24e* is offline   Reply With Quote
Old 04-16-2010, 03:07 PM   #12 (permalink)
ok thank you thats what i needed to know
