Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > General Tech > Nissan 240SX F.A.Q
Nissan 240SX F.A.Q Useful links and information
Old 09-02-2004, 11:51 PM   #1 (permalink)
NebrS13 NebrS13 NebrS13 NebrS13 NebrS13 NebrS13 NebrS13 NebrS13 NebrS13 NebrS13 NebrS13
Maybe someone posted this SR/and OEM part numbers
KA24E Production 89'- 91'
KA24DE Production 91' - 98'
CA18DET Production 89' - 91'
SR20DET Production 91' - 98'
SR20DET US OEM replacement part number
Part USDM Part# (source car/motor)
Oil filter 15208-53J00 91-94 Sentra SE-R
Fuel Filter 16400-00002 1990-1996 300ZX TT
Upper injector o-ring 16618-53J00 7/95 and newer 300ZX TT (small/upper)
Lower injector o-ring 16618-10V05 7/95 and newer 300ZX TT (big/lower)
Flywheel bolts 12315-2J220 z32 TT
Front main seal 13510-53J00
13510-53J10(KA24E)
Rear main seal 12279-0m300 z32 tt
rocker arms 13257-53J03 (SE-R)
Water Pump (s13)21010-52F01 (JDM #)
(s14)21010-65F26 (JDM #)
Collector Intake Gasket 14032-52F00
Intake Manifold Gasket 14035-53J00
14035-53j10
Exhaust Manifold Gasket 14036-53J00
A.A.C. Valve Gasket 23785-50F00
CAS O-Ring 22131-50F00
Valve Seal 13207-D0111(Exhaust)
13207-D4201(Intake)
13207-84A00(Intake)
Throttle Body Gasket 16175-79S70(SE-R)
Oil Drain Washer 11026-01M02(SE-R)
Valve Cover Gasket(center) 13270-53J13(SE-R)
240sx OEM replacement part number
Part Part # (source car/motor)
tierodsleeves/Steering Boot 48203-10V25
Rear Tranny Seal 32136-U0100 (s13/14/CA/SR/KA)
Lower Shifter Boot 24216-V5000 (s13/14 ka/sr)
Fuel Pump cover O-ring 17342-01A00 (s13)
Coolant Resevior 21721-35f01 (s13)
High Pressure PS line w/ hardlline 49720 - 53F00 (s13 91-94)
Brake booster hose (3 pieces) 47471-40F00 (s13)
47478-03B00 (s13)
47474-40F00 (s13)
Pilot Bearing(pretty much for any modern Nissans) 32202-B9500 (Hitachi)
32202-3000 (Yashima)
OEM NISMO part number
Part Nismo Part # (source car/motor)
Nismo Rocker Arm Stoppers 13220-RR450
Nismo motor mounts(CA) (RH)11210-RS520 (LH)11220-RS520
Nismo motor mounts(SR) (RH)11210-RS540 (LH)11220-RS540
Nismo motor mounts(CA/SR/KA) 11320-RS541
Nismo power brace 54480-RSS30 (s13)
54480-RSS51 (s14)
Nismo slave cylinder 30620-RS520
Nismo clutch line 46211-RSS40 (SR)
46211-RS520 (CA)
Nismo steering rack bushing 54444-RS520 (RH s13/s14)
54445-RS520 (LH s13)
54445-RS540 (LH s14/r32/r33)
Nismo thermostat 21200-RS420
Nismo Radiator cap 21430-RS012
SR20DET OEM turbo Specs
S13 T-25 60 trim 56mm BCI-1 compressor 53.8mm 62 trim
T-25 turbine, .64 A/R turbine housing. Journal bearings.
S14 T-28 60 trim 60 mm BCI-1 compressor in T-04B housing, 62 trim 53.8mm
T-25 turbine. .64 A/R turbine housing. Ball bearing center section.
S15 T-28 60 trim 60 mm BCI-1 compressor in T-04B housing, 62 trim 53.8mm
Inco turbine .64 A/R turbine housing. Ball bearing center section.
*cast divider wall between turbine discharge and wastegate.
GTi-R T-28 60 trim 60 mm BCI-1 compressor in standard T-3 housing. 79 trim 53.8mm
Inco T-250 turbine wheel .86 A/R turbine housing. Journal bearings.
Engine Modifications
Exhaust System
Exhaust systems are chassis-specific irregardless of engine type. This means S14 exhausts fit both KA and SR engines, for example. The only exception to this rule is that S13 CA18DE(T) exhaust systems do not fit onto SR/KA S13 chassis.
Suspension Interchangeablity
S13/14 adjustable pillowball upper mounts are interchangeable.
S13/14 coilovers are not interchangeable.
S13/14 rear upper arms are interchangeable as long as they are adjustable.
S13/14 front strut tower bars are interchangeable if the length of the strut bar can be adjusted.
s13/14 Rear strut tower bars are not interchangeable.
Brake Info
Z32 Calipar size Year/model
30mm iron 92.5'-96'all models
26mm aluminum 90' non-turbo
30mm aluminum 91-92.5 all models
For more detailed pictures and info of the Z32 4 piston caliper, please see this site written by Asad Aboobaker
Parts needed for the z32 brake upgrade (front)
z32 Calipers - can be located at various junkyards (rebuild is highly recommended)
Rotor - make sure you get the correct rotor for the calipers - if your 240sx is 4lug the rotors will need to be drill 4x114.3
Custom Brake Lines - many 240sx related store will carry them ie. srswap.com, pdm-racing.com, clearcorners.com
Brake Pads - use an oem shim kit
brake fluid
Q45 Calipar size Year/model
n/a n/a
no info at the current time
Wheel and Offset
*Clearance of wheels for Z32 brake upgrade is entirely dependent on wheel spoke AND wheel design, NOT on offset of wheel.
-Wheel width/offset needed for clearance of coilovers is as follows (disregarding brake clearance):
Width Offset
6" +54 or lower
6.5" +45 or lower
7" +40 or lower
7.5" +34 or lower
8" +30 or lower
8.5" +24 or lower
9" +20 or lower
*these numbers are for the fronts only
Note that this does not take into account variations in offset calculation by manufacturer, or tire sidewall bulge. This list also does not take into account differences in design of coilovers (esp. lower brackets on coilover kits which can cause changes in wheel clearance issues). This list also only applies to the FRONT WHEELS and is intended as a GUIDE for reference.
The LARGEST wheels that will fit the front of a S13/14 with stock fenders is 9" wide. The rear can take up to 10.5" wide with a very specific offset AND must dial in negative camber. To fit large wheels one must use negative camber to ensure proper fender clearance.
Wheel BackSpacing v. Offset
Back Space
Wheel Width 3.25"
3.5"
3.75"
4"
4.25"
4.5"
4.75"
5"
5.25"
5.5"
5.75"
6"
5.5"
0 6 12 19 25 32 38 44 51 57 63 69
6"
-6.4 0 6 12 19 25 32 38 44 51 57 63
6.5"
-12 -6 0 6 12 19 25 32 38 44 51 57
7" -19 -12 -6 0 6 12 19 25 32 38 44 51
8" -32 -25 -19 -12 -6 0 6 12 19 25 32 38
8.5" -38 -32 -25 -19 -12 -6 0 6 12 19 25 32
9" -44 -38 -32 -25 -19 -12 -6 0 6 12 19 25
9.5" -51 -44 -38 -32 -25 -19 -12 -6 0 6 12 19
10" -57 -51 -44 -38 -32 -25 -19 -12 -6 0 6 12
10.5" -63 -57 -51 -44 -38 -32 -25 -19 -12 -6 0 6
11" -69 -63 -57 -51 -44 -38 -32 -25 -19 -12 -6 0
12" -69 -63 -57 -51 -44 -38 -32 -25 -19 -6
Hub Size Info
Chassis Hub Bolt Size
S13 front 30mm
S14front 32mm
s13/14 rear 36mm
5lug conversion
Chassis Parts need for conversion
S13 S14SE/Z32nonturbo rear hubs
Option 1) JDM aftermarket front S13 5 lug hubs Option 2) S14 SE front hubs + S14 spindle + S14 ball joint w/LCA (and redrilling of strut for larger strut bolt).
S14 S14 SE front hubs and S14SE/Z32nonturbo rear hubs.
Interior Interchangability
S13/14/15 front seats are interchangeable without any modification.
R32/33/34 front Skyline seats fit S13/14 with a minor modification to one of the mounting holes.
Transmission/Differential
-For Kaaz/Nismo LSD, VLSD output shafts are required. You need two of the following: LSD output shaft 38220-52F01
-Short shifters are interchangeable b/w S13/14 KA transmission and S13/14 SR transmission.
NebrS13 is offline   Reply With Quote
Old 09-03-2004, 05:39 PM   #2 (permalink)
evilimport's Avatar
evilimport is on a distinguished road
this should be in the FAQ section.....Good stuff Nebrs13, thanks for posting this.
SHIFT_ Motors SR20DET
You douche bags bring your A-game?
evilimport is offline   Reply With Quote
Old 07-07-2009, 10:44 PM   #3 (permalink)
just found-- for a quick fix on output shaft seal --
national seals -- part number at O'reillys is 3771 - inner and outer length is the same as a sr- its just not as deep
also have ran a Ngk BR5 plug - same as a sentra ser - cant remember but i may be running a .030 - .o28 which is a 30 gap i believe
Old 07-07-2009, 11:37 PM   #4 (permalink)
Gestapo [MOD]
DrDubbleB's Avatar
DrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthyDrDubbleB The posts made by this user are trust worthy
Points: 245,181,169, Level: 100
Points: 245,181,169, Level: 100 Points: 245,181,169, Level: 100 Points: 245,181,169, Level: 100
Moving to FAQ - thanks for posting it.
DrDubbleB is offline   Reply With Quote
What is this part on the KE24E?? Pic. Prelude Guy KA24DE/T and KA24E 3 08-16-2004 09:56 AM
SR20DET Factory Turbo Part Numbers Joel 180 SR20DET Engines 1 07-07-2004 08:06 PM
eurospec headlamps part# confirmed? mk20116 General Tech 2 06-03-2004 03:25 AM
Mustang in a ditch, part 2 James Off Topic Chat 16 03-29-2004 10:55 PM
Part Numbers sil8ty SR20DET Engines 0 01-02-2003 08:40 PM
