Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > General Tech > Nissan 240SX F.A.Q
Nissan 240SX F.A.Q Useful links and information
LinkBack (24) Thread Tools
Old 09-13-2002, 06:52 PM   24 links from elsewhere to this Post. Click to view. #1 (permalink)
Neo
Forum Founder
Neo's Avatar
Neo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthyNeo The posts made by this user are trust worthy
Points: 2,147,568,980, Level: 100
Points: 2,147,568,980, Level: 100 Points: 2,147,568,980, Level: 100 Points: 2,147,568,980, Level: 100
Post SR20DET ECU wiring diagram.
SR20DET wiring ECU pins and description of wire colors
1 - Coil Pack 1 Output (Via power transistor Unit) - Red White
2 - Coil Pack 2 Output (Via power transistor Unit) - Red Yellow
3 - Tachometer signal output - Yellow Red
4 - ECCS Relay - Red Black
5 - Ignition Pulse Monitor (For Trip Comp ?)
6 - Ignition Signal Ground - Black
7 - RX data (Signal from Nissan Consult hand terminal) - Green Black
8 - Coil Pack 3 Output (Via power transistor Unit) - Red White
9 - Coil Pack 4 Output (Via power transistor Unit) - Red White
10 -
11 -
12 - A/T signal DT3 (autotrans gear select ?)
13 - Ignition Signal Ground - Black
14 - CLK clock (timing signal) - Green White
15 - TX data (signal to Nissan Consult hand terminal) - Green
16 - MAFS signal input ( Mass Air Flow Sensor ) - White
17 - MAFS ground - Black
18 - Water Temp Sensor input - Blue Brown
19 - Oxyen Sensor input (O2) - White
20 - TPS input (throttle postion sensor) - White
21 - Sensor ground - Black
22 - CAS 180deg signal (Crank angle sensor) - White
23 - CHK check (check start) ? - Green Red
24 - Monitor check Lamp (red) (fault code lamp output)
25 - Exhaust over temp warning lamp output - Orange
26 - Exhaust temp sensor inout (Behind the Cat) - Blue Yellow
27 - Detonation sensorinput (knock sensor) - White
28 - TPS for A/T (kick down switch)
29 - Sensor ground - Black
30 - CAS 180deg signal (crank angle sensor) - White
31 - CAS 1deg signal (crank angle sensor) - Black
32 - Speed sensor input - Yellow Green
33 -
34 - Start signal (from ignition switch) - Orange
35 - A/T neutral switch input - Green Orange
36 - IGN (ignition ON, from ignition switch) - Black Red
37 - TPS power output (power to throttle position sensor) - Light Green Red
38 - ECCS power - Black White
39 - ECCS ground - Black
40 - CAS 1 deg signal (crank angle sensor) - Red Black
41 - A/C on input (Air Con ON from A/C panel) - Blue Green
42 - A/T signal DT1 (auto trans gear select ?)
43 - Power steering switch (speed proportional control output) - Purple White
44 - A/T signal DT1 (auto trans gear select ?)
45 - Ambient air tamp sensor input - Blue White
46 - ECCS backup power - Red
47 - ECCS power - Black White
48 - ECCS ground - Black
101 - Injector No. 1 drive output - White Black
102 - EAI control solenoid output (egr valve control ?) - Orange Black
103 - Injector No.3 drive output - Green Black
104 - Fuel pump relay output - Black Purple
105 - Fuel pressure control module - Red White
106 - A/C on output (Air conditioner on relay signal) - Green Black
107 - Injector ground - Black
108 - Injector ground - Black
109 - Reverse electrical flow return circuit (alternator fail input) - Red
110 - Injector No. 2 drive output - Yellow Black
111 - Turbo boost pressure control solenoid (over boost cut ?) - Orange Black
112 - Injector No. 4 drive output - Blue Black
113 - AAC valve control (Auxiliary Air Control, Idle speed control) - Light Blue
114 -
115 -
116 - Injector ground - Black
Neo is offline   Reply With Quote
Old 03-07-2006, 08:00 PM   #2 (permalink)
Lazymofo is on a distinguished road
can someone correct this?
Lazymofo is offline   Reply With Quote
Old 03-14-2006, 03:04 PM   #3 (permalink)
i figured it out
8 - Coil Pack 3 Output (Via power transistor Unit) - Red green
9 - Coil Pack 4 Output (Via power transistor Unit) - Red blue
Old 03-15-2006, 06:18 AM   #4 (permalink)
nrg
nrg is on a distinguished road
um.. which sr20det?
nrg is offline   Reply With Quote
Old 03-22-2007, 09:20 PM   #5 (permalink)
tofuman is on a distinguished road
I have a 1995 240 with a sr20det red top engine swap and everything is working fine, but the speedometer is not functioning right. when im going 40 it says im going 80 and so on. the speed is always doubled. the trip odometer goes really fast as well.
tofuman is offline   Reply With Quote
Old 03-30-2007, 12:45 AM   #6 (permalink)
conrad1017 is on a distinguished road
your probably using a s13 us or jdm speedo sensor the s14 usdm will give u a good reading
conrad1017 is offline   Reply With Quote
Old 03-30-2007, 12:49 AM   #7 (permalink)
ur probably using a s13 speedo if u use a s14 u wont get doubled readings
LinkBack to this Thread: http://www.240sxforums.com/forums/nissan-240sx-f-q/433-sr20det-ecu-wiring-diagram.html
Random 240sx Information and Part Numbers - Import FanatiX Car Club This thread Refback 09-24-2009 09:45 AM
The 240sx Bible - 502StreetScene This thread Refback 09-21-2009 04:26 PM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 09-18-2009 08:46 PM
240sx bible This thread Refback 08-25-2009 06:05 PM
Nissan 200SX Club - South Africa :: View topic - 200sx bible! This thread Refback 08-18-2009 02:41 AM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 06-05-2009 12:20 AM
IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - The Ultimate 240SX Bible This thread Refback 05-23-2009 11:58 PM
IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - The Ultimate 240SX Bible This thread Refback 05-22-2009 04:29 PM
IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - The Ultimate 240SX Bible This thread Refback 05-20-2009 04:26 PM
Proyecto 240sx Drift - PáÈina 12 - VelocidadMaxima.com This thread Refback 04-22-2009 03:45 PM
a/f ratio gauge - Zilvia.net Forums This thread Refback 02-01-2009 01:59 PM
Nissan 240 SX This thread Refback 12-16-2008 02:42 PM
Ultimate Write Up - NV240SX.ORG - Forums - v2.0 This thread Refback 11-18-2008 11:12 AM
Nissan 240sx This thread Refback 11-15-2008 01:38 AM
The Ultimate 240SX Bible Volume 1 - CentexRacingScene.com - Central Texas Auto Forums This thread Refback 10-25-2008 04:57 PM
240sx bible - Tampa Racing This thread Refback 10-22-2008 04:55 PM
240SX Bible - 240Atlanta.com This thread Refback 10-16-2008 03:41 PM
Ultimate 240sx Bible Vol 1 - T This thread Refback 10-12-2008 01:10 AM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 10-09-2008 09:11 PM
WinnipegHeights.com - Ultimate 240SX Bible Vol. 1 This thread Refback 10-09-2008 12:17 AM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 10-05-2008 09:58 PM
TunerFriends - tuner enthusiast community - Ultimate 240sx guide (aka The Bible) This thread Refback 10-02-2008 11:46 PM
NODrFt - The 240sx Bible - Answers to almost ALL 240sx questions This thread Refback 10-01-2008 02:19 AM
The Ultimate 240SX Bible - StreetUnitForum.com This thread Refback 09-30-2008 04:34 PM
