Sr20det Ecu Fault Codes
ECU fault codes
Long Flash - 0.6 seconds on (the first digit)
Short Flash - 0.3 seconds on (the second digit)
Long Gap - 2.1 seconds off (used between codes)
Short Gap - 0.9 seconds off (used between digits)
There are two digits in each code. Count the long flashes, then the short flashes (only count how many times the light is ON) and you'll have a 2 digit code. These codes are covered in the service manual.
Code Meaning
11 - Camshaft Position Sensor
12 - Air Flow Meter
13 - Coolant Temperature Sensor
14 - Vehicle Speed Sensor
21 - Ignition Signal
25 - IACV - AAC Valve
26 - Boost Pressure Sensor
31 - ECM Fault
32 - Exhaust Gas Recirculation System
33 - Front EGO Sensor (O2-1 Sensor)
34 - Knock Sensor
35 - EGR Temperature Sensor
36 - EGR BPT Valve
37 - Closed Loop System
41 - Intake Air Temperature Sensor
43 - Throttle Position Sensor
54 - Signal from Auto Transmission
55 - Other Malfunction. CONSULT Terminal Required
63 - Cylinder 6 Misfire (?)
64 - Cylinder 5 Misfire (?)
65 - Cylinder 4 Misfire
66 - Cylinder 3 Misfire
67 - Cylinder 2 Misfire
68 - Cylinder 1 Misfire
71 - Random Misfire
72 - TW Catalyst System
76 - Fuel Injection System
77 - Rear EGO Sensor (O2-2)
82 - Crank Position Sensor
84 - Automatic Transmission Diagnostic Comms Line
95 - Crank Position Cog
98 - Coolant Temperature Sensor
103 - Park/Neutral Switch
105 - EGR Solenoid
111 - Inhibitor Switch
112 - Automatic Transmission Speed Sensor
113 - Automatic Transmission 1st Signal
114 - Automatic Transmission 2nd Signal
115 - Automatic Transmission 3rd Signal
116 - Automatic Transmission 4th Signal
118 - Automatic Transmission Shift Solenoid Valve A
121 - Automatic Transmission Shift Solenoid Valve B
123 - Automatic Transmission Overrun Clutch Solenoid Valve
124 - Automatic Transmission TOR Conv Solenoid Valve
125 - Automatic Transmission Line Pressure Solenoid
126 - Automatic Transmission Throttle Position Sensor
127 - Automatic Transmission Engine Speed Signal
128 - Automatic Transmission Fluid Temperature Sensor
