Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > Nissan S13 240SX (89-94)
Nissan S13 240SX (89-94) Technical questions for all 1989, 1990, 1991, 1992, 1993 and 1994 Nissans
Old 01-27-2010, 11:47 PM   #1 (permalink)
240sxhatch is on a distinguished road
Points: 945, Level: 16
Points: 945, Level: 16 Points: 945, Level: 16 Points: 945, Level: 16
Exclamation Need car doctors :/ 89 fastback
I use my 240sx as a DD.
I took the lady out to eat, everything was fine.
Stopped at Salvo on the way home to maybe find some salvo treasures (NO luck all they had was overpriced used furniture and grandma clothing that day).
Got in the 240 to drive from salvation army to home, and the car started up fine as usual, then died. Literally died after maybe 15 revolutions of being on.
Car Background:
-89 240sx KA24E
-Timing chain has maybe 3k on her.
-Cam pulley is 1k new.
-All fluid levels always at level
-New spark plugs
-Dist Cap is 800mi. new
Well, I always plan for the 240 to break, so my trunk is literally a tool arsenal.
In the salvation army parking lot,
1. I bust out my flashlight (it's nighttime) and check all kick panel and engine bay fuses. All ok.
2. Whipped out a screwdriver and opened up the fuel lines. Both squirted fuel.
3. Whipped out my sockets and tested spark while grounding the plug on the chassis. Spark A-OK.
4. Checked injector connectors, coolant sensor connectors and miscellaneous connectors. All connected and seem to be OK.
5. Unplugged MAF and tried starting her up. Nothing.
6. Don't know if it would make a difference but I tried unplugging the coolant temp sensor then starting it up. Nothing.
7. Took off the valve cover and checked the timing chain (one time the chain snapped on me). Chain was fine.
IMPORTANT POINTS
Now here's the deal. I am pretty good at listening, and know how normal sounding turning over sounds like. Everything sounds normal. No abnormal sounds while turning over, no low battery.
The car sounds like it gets a fire in here and there, just enough to get me a little excited every time. It might have a combustion or three when I first attempt to start the vehicle, then if I keep attempting to turn over all I get is the sound of turning over and no start up.
I'm trying to think of what this could be, and why the car decided to just die after it already ran fine and started fine and then died instantly with no weird sounds.
I already ruled out cap and rotor, because If those went out I believe that would be a little more progressive and not so sudden right? The cap is new.
Anybody have any ideas?
240sxhatch is offline   Reply With Quote
Old 01-28-2010, 10:57 AM   #2 (permalink)
*ka24e*'s Avatar
Points: 789,348,498, Level: 100
Points: 789,348,498, Level: 100 Points: 789,348,498, Level: 100 Points: 789,348,498, Level: 100
Activity: 27%
Activity: 27% Activity: 27% Activity: 27%
Listen for the fuel pump when the ignition is on. If you do not hear a buzzing sound in the trunk, with that on (no start, just ignition) than that's the problem.
I had a pump that would pump fine when it was cold, but after 2-3 min of driving it would stop pumping. If I let it cool off for a few minutes it started right back up.
240sx Factory Service Manuals
I'm looking for a PC (desktop, no laptops). If you have one on the cheap, or would like to trade for some parts PM me.
Originally Posted by jjaammeess View Post
a friend of mine has already blown 4 SR's and he advised me to go with the KA
*ka24e* is offline   Reply With Quote
Old 01-28-2010, 12:34 PM   #3 (permalink)
Issue is that as long as I've had the car, when it ran fine everytime- even with the trunk carpet removed and my ear by the pump I can't hear it. And that's when I knew it worked. LOL. I mean, in AC ignition position it pumps fuel as mentioned in the first post. I'm just dumbfounded as of now.
Old 01-28-2010, 12:48 PM   #4 (permalink)
werk4yas13 is on a distinguished road
Points: 653, Level: 13
Points: 653, Level: 13 Points: 653, Level: 13 Points: 653, Level: 13
im with the fuel pump on this one cuz i just had this problem and when i cheked the fuel line to see if it was pumpin fuel it filled the glass every time but when i cranked her up it would just spin cum to find out the fuel pump was clogged and had lost pressure ....i swapped it out with a walboro255 and its been a week and i havent had a problem since it also cleared up a idle issue i had
werk4yas13 is offline   Reply With Quote
Old 01-28-2010, 12:57 PM   #5 (permalink)
Hmm. Anybody have a spare fuel pump I can borrow!? lol I'll look into this fuel pump further
Old 01-29-2010, 11:42 AM   #6 (permalink)
*ka24e*'s Avatar
Activity: 27%
You should defiantly hear the pump with your head in the trunk. I can hear mine buzzing standing behind the car with it running. If you can, check fuel pressure.
Old 01-29-2010, 01:39 PM   #7 (permalink)
What should normal fuel pressure be between psi wise?
Old 01-29-2010, 02:01 PM   #8 (permalink)
*ka24e*'s Avatar
Activity: 27%
44 w/out vac, 34 w/ vac.
Old 01-30-2010, 08:11 PM   #9 (permalink)
ebinkerd is on a distinguished road
Points: 746, Level: 14
Points: 746, Level: 14 Points: 746, Level: 14 Points: 746, Level: 14
Guaranteed to be the fuel pump. Just get a walbro and call it a day
ebinkerd is offline   Reply With Quote
Old 02-08-2010, 06:59 PM   #10 (permalink)
Bad new bears, replaced fuel pump. No go. Any other ideas? I mean what would cause a car to suddenly shut off after a regular start up? ECU? Possibly the timing chain skipped a few teeth? Just throwing some ideas out there.
Old 02-08-2010, 07:48 PM   #11 (permalink)
*ka24e*'s Avatar
Activity: 27%
Hmm. Have you checked fuses? Check the ECU fuse. I blew and ECU fuse once (which somehow took the ECU with it) and it made the fuel pump stay on. When I turned the key, the pump would start and it would just keep pumping.
The SOHC's will run with 1 tooth retarded (it actually makes decent power up top too), but you could have jumped more.
Have you done a compression test yet? That would rule out the bent valves or jumped timing.
Old 02-08-2010, 08:06 PM   #12 (permalink)
Be nice, I'm new here!
dennis taylor is on a distinguished road
Points: 36, Level: 1
Points: 36, Level: 1 Points: 36, Level: 1 Points: 36, Level: 1
i'm not getting any fire to the cap
dennis taylor is offline   Reply With Quote
Old 02-08-2010, 08:08 PM   #13 (permalink)
*ka24e*'s Avatar
Activity: 27%
Check the ignition coil.
Old 02-08-2010, 08:10 PM   #14 (permalink)
Unhappy
my car wont crant and its not getting any fire to the rotor cap. i put new plugs in it last week, dennis taylor
Old 02-08-2010, 08:12 PM   #15 (permalink)
*ka24e*'s Avatar
Activity: 27%
Why are you posting this in 240sxhatch's thread? Make a new thread.
Old 02-08-2010, 08:21 PM   #16 (permalink)
thank you jessica
jessica im new at this, i dont no what a therad is ok dennis
Old 02-08-2010, 08:25 PM   #17 (permalink)
KAT0's Avatar
KAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthyKAT0 The posts made by this user are trust worthy
Points: 1,507,929,800, Level: 100
Points: 1,507,929,800, Level: 100 Points: 1,507,929,800, Level: 100 Points: 1,507,929,800, Level: 100
Activity: 44%
Activity: 44% Activity: 44% Activity: 44%
He's not Jessica. He's a guy who likes Jessica Alba.
When you go into the Beginner Forum, right about all the titles you can go into (a thread), you can see in the left "Post New Thread". There you'll be able to make your own.
S
emper Fidelis
KAT0 is offline   Reply With Quote
Old 02-08-2010, 08:56 PM   #18 (permalink)
I've been threadjacked My threads all messy now can a mod clean this up for me pretty please?
Ok, i'll check ECU fuse and update!
Old 02-08-2010, 09:03 PM   #19 (permalink)
KAT0's Avatar
Activity: 44%
Don't worry about it. Just keep the thread going. If he continues to post I'll take care of it. I have a feeling if I clean it up now he won't understand how to make a thread and continue what he's been doing.
S
emper Fidelis
Old 02-18-2010, 10:36 PM   #20 (permalink)
Well, I replaced Fuel pump, spark wires, and nothing.
I decided to put the car into TDC and remove the valve cover again. Yep, cam timing was off! I found out the right hand side timing chain guide (non-tensioner side) about broke all the way off! In turn that threw the cam timing off from the crank .
What's weird is that I JUST replaced that SAME guide, that broke a month prior .
I wonder why that same guide keeps breaking? Any ideas?
Old 03-15-2010, 03:18 PM   #21 (permalink)
anybody? I really don't want to replace the guide again if its just gonna break again!
Old 03-15-2010, 08:22 PM   #22 (permalink)
1337240's Avatar
1337240 is on a distinguished road
Points: 2,714, Level: 31
Points: 2,714, Level: 31 Points: 2,714, Level: 31 Points: 2,714, Level: 31
Activity: 7%
Activity: 7% Activity: 7% Activity: 7%
are you getting the guide from nissan??? if not thats the reason why...
1337240 is offline   Reply With Quote
Old 03-16-2010, 10:50 PM   #23 (permalink)
843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy843.240sx The posts made by this user are trust worthy
Points: 74,544,482, Level: 100
Points: 74,544,482, Level: 100 Points: 74,544,482, Level: 100 Points: 74,544,482, Level: 100
Here is some worse news for you... KA's are interference motors, if you skip a few teeth you can still funk up a valve or a piston. Not as bad as the chain snapping and then your piston royally having with way with your valves ass, but you would still probably have no compression due to the valves hanging open too long and not closing for combustion. The head needs to come off to check this out, not just the valve cover.
Oh and you might be able to turn the distributor some and see if it will at least start (run like crap) but if it does pop off, turn off the car immediately...
843.240sx is offline   Reply With Quote
Old 03-16-2010, 11:01 PM   #24 (permalink)
*ka24e*'s Avatar
Activity: 27%
True ^ You can run with one tooth advanced (yes, I've tried it) or retarded on the cam, but any more in either direction will will make contact. I seen a KA jump time and still run tho. The primary intake valve in the #1 cylinder was visible shorter than the other ones and that cylinder had zero compression, but he still drove it back home just fine, lol. (after resetting the timing of course)
We took the head off and found nice valve dents in all the pistons (had good compression in 2,3 and 4 tho), but the #1 took the biggest hit. Pull the valve cover off and remove the rocker shafts (doesn't need to be at TDC, all the valves will be closed). Make sure all the valves look even. If any valves are shorter than others, that's your bent valve.
Old 03-16-2010, 11:14 PM   #25 (permalink)
I was just going on the fact that the car wouldn't start. I didn't know that any more than one tooth and it would make contact, good info there.
But since it isn't turning over I am willing to bet its crunched valves in 2 cylinders.
KA24e, I've read some of your posts. You got some smarts.
Oh and about OP last question, no idea why the guild would break. I'd say leet240 hit it on the head. Get nissan only.
89 fastback parts/project car $350 OBO LongGrain Cars For Sale/Wanted 6 01-22-2007 11:56 PM
91 fastback california car, in INDIANA, no rust must look mdubyaftw Cars For Sale/Wanted 2 10-17-2006 02:56 PM
my new car, a 90 fastback achord Beginner’s Forum 13 05-13-2005 10:13 AM
fastback project race car kwkouki Nissan S13 240SX (89-94) 7 05-17-2004 08:14 PM
Any doctors or sons/daughter of doctor? Mafioso Off Topic Chat 10 03-23-2003 04:48 PM
