Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > Nissan S13 240SX (89-94)
Nissan S13 240SX (89-94) Technical questions for all 1989, 1990, 1991, 1992, 1993 and 1994 Nissans
Old 02-05-2010, 03:37 PM   #1 (permalink)
whoareu is on a distinguished road
Points: 1,814, Level: 25
Points: 1,814, Level: 25 Points: 1,814, Level: 25 Points: 1,814, Level: 25
hooking up water temp?????
ok so ive hooked up my temp guage and im wondering if it is operateing corectly. with the ground hooked up it registers 100, and when the ground isnt hooked up it reads like 150. however the stack gauge reads it is overheating. i definatly dont think its overheating, but at the same time its scary. does the temp sender need to be grounded. its an autometer guage if that helps.
whoareu is offline   Reply With Quote
Old 02-05-2010, 06:40 PM   #2 (permalink)
wow, really, so no one has hooked up an autometer temp guage.
Old 02-07-2010, 03:09 AM   #3 (permalink)
92White240's Avatar
92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy92White240 The posts made by this user are trust worthy
Points: 87,300,758, Level: 100
Points: 87,300,758, Level: 100 Points: 87,300,758, Level: 100 Points: 87,300,758, Level: 100
150ºf or 150º celsius?
I think it may be celsius and that is quite hot. 150º celsius equals about 302º fahrenheit, I think.
Refuse to feed trolls!
92White240 is offline   Reply With Quote
Old 02-07-2010, 10:08 PM   #4 (permalink)
Points: 705,718,584, Level: 100
Points: 705,718,584, Level: 100 Points: 705,718,584, Level: 100 Points: 705,718,584, Level: 100
Activity: 12%
Activity: 12% Activity: 12% Activity: 12%
Have some patience.
Does it have its own sensor?
Old 02-08-2010, 12:24 PM   #5 (permalink)
ok so it doesnt say this in the intructions, but if you are using an adapter like i am (greddy water temp adapter in the upper rad hose) then the adapter must see a ground. and you can not just simply ground the sender. just a little fyi, as i know quite a few people with this problem. Apperantly the sender see's ground through the threads on the sender itself.
Old 02-08-2010, 12:37 PM   #6 (permalink)
carps13guy's Avatar
carps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthycarps13guy The posts made by this user are trust worthy
Points: 353,953,440, Level: 100
Points: 353,953,440, Level: 100 Points: 353,953,440, Level: 100 Points: 353,953,440, Level: 100
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
i installed a mechanical auto meter water temp gauge with their hose adapter kit. it had a screw and lead for a ground if it was a electronic guage.
http://www.240sxforums.com/forums/19...ld-thread.html
IF IT HAS TITS OR WHEELS IT WILL GIVE YOU PROBLEMS
carps13guy is offline   Reply With Quote
Old 02-08-2010, 07:48 PM   #7 (permalink)
Activity: 12%
Really? Never heard of the adapter needing a ground. Since temperature sensors arent powered...
Old 02-08-2010, 09:52 PM   #8 (permalink)
me neither, but aparently they do.
I need Rep...
1993 240sx convertable with an rb25v2 swapped by myself with help from several friends and the internet.
Old 02-09-2010, 05:27 PM   #9 (permalink)
Activity: 12%
says who? Mine worked just fine ungrounded
Old 02-10-2010, 07:55 AM   #10 (permalink)
ummm auto meter. where is your sender placed?
I need Rep...
Old 02-10-2010, 06:42 PM   #11 (permalink)
Activity: 12%
In a custom adapter in the top radiator hose.
Do you have this one? http://www.autometer.com/download_instruction/771d.pdf
It says to ground the temperature sensor module but says nothing about grounding the adapter or sensor itself.
FS: Defi BF Series 60mm Water Temp, Oil Temp, Oil Press + Control Unit II(Pic) jsp86 S13 Parts F/S 7 02-14-2009 03:09 AM
FS 3 SPi Gauge Set $40 - Boost, Water Temp, Oil Temp $40 -New TurboToyzz S14 Parts F/S 2 08-16-2007 04:59 PM
FS 3 SPi Gauge Set $40 - Boost, Water Temp, Oil Temp $40 -New TurboToyzz SR Parts F/S 4 04-01-2007 01:54 PM
FS 3 SPi Gauge Set $40 - Boost, Water Temp, Oil Temp $40 -New TurboToyzz S13 Parts F/S 1 03-24-2007 11:53 PM
water temp sensor robs240sx General Tech 5 06-14-2004 02:25 AM
