Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > RB Engines
RB Engines Tuning guides, questions and recommendations
Old 11-18-2009, 11:44 PM   #1 (permalink)
cory_cnx is on a distinguished road
Points: 1,969, Level: 26
Points: 1,969, Level: 26 Points: 1,969, Level: 26 Points: 1,969, Level: 26
rb smoking a bit
my rb started to smoke but only smokes when i rev it (but only does it the first time that i rev if i rev again it wont throw any smoke).also when im driving it doesnt trow any smoke .btw the smoke smells like gas but its kind of white bluish
also i have few more question
my ecu have 2 led lights one green and the other one red .when i turn off the car these 2 lights stay on .when i turn on the car the green lights flahes ,is this normal .
thanks guys
cory_cnx is offline   Reply With Quote
Old 11-18-2009, 11:49 PM   #2 (permalink)
RoboNismo's Avatar
RoboNismo is on a distinguished road
Points: 961, Level: 16
Points: 961, Level: 16 Points: 961, Level: 16 Points: 961, Level: 16
uhhhhh that doesnt sound normal to me.. Anyone?
RoboNismo is offline   Reply With Quote
Old 11-19-2009, 12:48 AM   #3 (permalink)
Radianation's Avatar
Radianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthy
Points: 1,450,635,117, Level: 100
Points: 1,450,635,117, Level: 100 Points: 1,450,635,117, Level: 100 Points: 1,450,635,117, Level: 100
I don't know anything about the ecu codes. Typically the white smoke is coolant leaking into the engine and blue smoke is oil. Both could be because of bad gaskets and seals. When you rev the engine it probably builds up more pressure which causes those seals to leak more than under low load. It could be more prone to do this when it's cold because those seals might expand a bit when it gets hotter?
I'm just making a guess to help spark some ideas.
1996 S14 240sx se
RB25DET built (2.6 liter 2557.9cc)
Radianation is offline   Reply With Quote
Old 11-19-2009, 01:19 AM   #4 (permalink)
im just concern about the ecu .i turn off the car and they stay on am afraid its gonna kill my battery
Old 11-19-2009, 03:25 AM   #5 (permalink)
Can you plug it up and get a diagnostics run on the ECU to see what's causing those lights? I would have those same concerns about the lights. The drain is probably really small, but you never know.
1996 S14 240sx se
Old 11-19-2009, 12:31 PM   #6 (permalink)
GLUE is on a distinguished road
Points: 1,585, Level: 22
Points: 1,585, Level: 22 Points: 1,585, Level: 22 Points: 1,585, Level: 22
how come you do not check for codes from the ecu. I agree with Radianation some leak. that light will not kill your battery lol. check for codes!!!
GLUE is offline   Reply With Quote
Old 11-20-2009, 12:27 AM   #7 (permalink)
when i first did the swap the idle wouldnt go down.i removed the acc valve and the gasket broke .i couldnt find the gasket anywhere and i just put silicone gasket ,would this be the problem my idle its fine well sometime when i boost and brake hard my car tries to stall.thanks guys
also theres no oil in radiator and sometimes i can smell a lot of gas
Old 11-20-2009, 12:28 AM   #8 (permalink)
also i tried to check for codes and both lights blink at the same time
Old 11-20-2009, 02:04 AM   #9 (permalink)
I'm not sure exactly why there would be oil in your radiator?
1996 S14 240sx se
Old 11-29-2009, 05:28 PM   #10 (permalink)
WizardBlack is on a distinguished road
Points: 845, Level: 15
Points: 845, Level: 15 Points: 845, Level: 15 Points: 845, Level: 15
Oil in radiator is usually a BHG.
WizardBlack is offline   Reply With Quote
Old 12-09-2009, 11:18 AM   #11 (permalink)
blackproject18's Avatar
blackproject18 is on a distinguished road
Points: 1,626, Level: 23
Points: 1,626, Level: 23 Points: 1,626, Level: 23 Points: 1,626, Level: 23
Pull each plug one at a time and see what the end electrode, insulator, and the ground strap look like. See if there is oil on any of them... If so do a compression check to check the piston rings and also to see if the valves are properly seating, If that looks good then I would put my money on a set of valve seals... Post some pics of your plugs if you can, maybe I can help point you in the right direction.
ロビー ブランドソ
TG Touge Team Member #18.
450whp Rb25det build. No reserve!
Let the hacking and welding begin.
Rebuilding a Touge style EJ257 GC8.
Ae86 20v Swap in progress.
FR>FF !!!
Must... Beat... K-Cur's Black ACR SRT-4 STAGE 4!
現在、新しいガールフレンドの申し込みを受け入れます。
blackproject18 is offline   Reply With Quote
Old 01-07-2010, 02:02 AM   #12 (permalink)
ill take some tomorrow thanks
ECU smoking?! WTF! Tre4s13 Nissan S13 240SX (89-94) 18 11-13-2008 08:56 AM
need help, smoking agustin lopez Beginner’s Forum 5 07-07-2006 04:56 PM
Smoking!! SHIFT_style CA18DET Engines 11 10-29-2005 01:20 AM
Wtf is this guy smoking? evoflip Off Topic Chat 8 05-17-2005 04:51 PM
HELP! My ECU is smoking! jrou111 RB Engines 20 01-08-2005 06:06 PM
