Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > RB Engines
RB Engines Tuning guides, questions and recommendations
Old 02-07-2010, 04:42 PM   #1 (permalink)
XLR8_S14's Avatar
XLR8_S14 is on a distinguished road
Points: 1,748, Level: 24
Points: 1,748, Level: 24 Points: 1,748, Level: 24 Points: 1,748, Level: 24
Exclamation Broken Turbo Manifold Stud!!!
ok, so i was putting my turbo manifold back on my RB25 and the top left stud snapped off so deep there is no way I can grab it or anything. I tried to drill it out and put the EZ out stud remover in it, no way in hell its coming out, even the tip of the stud remover broke off inside of the bolt. So, does anyone have any ideas whatsoever? I'm not sure that I want to ignore it and just slap the manifold back up there, I would be afraid of it leaking...am i right?
HELP PLEASE!!!
S14 . . . RB25DET
Hear my RB25det... http://www.youtube.com/watch?v=AjgEECoeL2Y
XLR8_S14 is offline   Reply With Quote
Old 02-07-2010, 04:48 PM   #2 (permalink)
mikethebiker's Avatar
mikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthymikethebiker The posts made by this user are trust worthy
Points: 820,676,664, Level: 100
Points: 820,676,664, Level: 100 Points: 820,676,664, Level: 100 Points: 820,676,664, Level: 100
if its as deep as you say, then just put another stud in there. As long as you have the other bolts, the only purpose that bolt will have is mechanical compression, which it can do. so do it, other thing you could do is drill through the bottom of the flange, to the back of the bolt and get at it that way, but that depends on if you can get at it from the right angle
My Build:
http://www.240sxforums.com/forums/sh...ate+ka-e+build
S13 Is An Old Ass Piece Of Shit And Will Get Zero Girls Checkin You Out
mikethebiker is offline   Reply With Quote
Old 02-07-2010, 05:21 PM   #3 (permalink)
XLR8_S14's Avatar
well i took the manifold back off after i broke it and and there is definately no way that I can get another stud in there, i cant see any threads. So i guess it isnt that deep. but too deep to do anything with
S14 . . . RB25DET
Old 02-07-2010, 09:48 PM   #4 (permalink)
are you using a stud remover?
My Build:
Old 02-07-2010, 10:47 PM   #5 (permalink)
robbie2883 is on a distinguished road
Points: 1,188, Level: 18
Points: 1,188, Level: 18 Points: 1,188, Level: 18 Points: 1,188, Level: 18
you are referring to the stud in the head right? or on the manifold? either way the best thing you can do if you can't get it out with an extractor is to drill the hole completely out and use a heli-coil on the hole.
robbie2883 is offline   Reply With Quote
Old 02-08-2010, 01:40 AM   #6 (permalink)
240SxRaCeR69's Avatar
240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy240SxRaCeR69 The posts made by this user are trust worthy
Points: 420,968,686, Level: 100
Points: 420,968,686, Level: 100 Points: 420,968,686, Level: 100 Points: 420,968,686, Level: 100
I had 5 out of 12 broken studs on my motor. I took the head to a head repair shop here because I too broke a stud remover in the bolt and he used very small bits. Can't remember the type but he said he broke like 8 of them getting the one out with the broken EZ out. He ended up using a heli-coil on that one.
Check out my project http://240sxforums.com/forums/showthread.php?t=63769
240SxRaCeR69 is offline   Reply With Quote
Old 02-08-2010, 11:48 AM   #7 (permalink)
XLR8_S14's Avatar
yeah they are super weak. lol It is broken on the head side of it...
an yes i am using a stud remover...they same ones u posted a picture of...Is anyone running theirs without one of the studs in? What would happen if I did that?
It is the top left corner bolt....
S14 . . . RB25DET
Old 02-08-2010, 12:58 PM   #8 (permalink)
Is the motor in the car or out of the car? If it's still out of the car I would definitely recommend getting it fixed before putting it in. Wouldn't want to get it in there and running good only to have severe exhaust leaks. If the stud remover is broken in there then chances are you're going to have to use a heli-coil though. The guy at the shop where I took mine said he drilled a lot of holes around the stud remover until it was broken up around it so he could get it out.
Old 02-08-2010, 04:14 PM   #9 (permalink)
XLR8_S14's Avatar
it is out of the car, fortunately, but the only problem would be that I dont want to haul the whole engine down there, and IDK if i want to do the hassle of taking the head off. taht would suck
S14 . . . RB25DET
Old 02-08-2010, 07:55 PM   #10 (permalink)
if you run without the stud you will most likely end up with a warped manifold and a big exhaust leak. helicols are not hard to do, just make sure you drill straight
Old 02-08-2010, 08:40 PM   #11 (permalink)
I would agree. If you're worried about drilling straight try to get a drill block or something and use tape around the bit to make sure you don't drill too deep lol or check around locally to see if anyone could come to your garage and do it. Might have to pay them obviously, but I would feel a lot better about my motor getting it done right the first time.
Old 02-11-2010, 11:53 AM   #12 (permalink)
XLR8_S14's Avatar
yeah, i feel the same way, i dont want to do it half assed. u know
S14 . . . RB25DET
Old 02-20-2010, 12:24 AM   #13 (permalink)
XLR8_S14's Avatar
Sp this sucks, now I have to try and find a mechanic taht knows what they are doing and have this damn broken ass bolt taken out of my head. Anyone know of a place where I can get all brand new studs for my Exhaust mani.
S14 . . . RB25DET
Exhaust manifold broken stud 91jdm180sx SR20DET Engines 3 02-12-2009 08:39 PM
SR20DET: broken manifold stud still in head :( speedwrenchx10 SR20DET Engines 5 11-27-2008 09:56 PM
Broken Exhaust Stud shame_16 General Tech 1 09-23-2006 07:57 PM
Removing Broken Exhaust Manifold Stud stinky_180 General Tech 8 07-02-2006 11:13 PM
broken stud 240SeX Nissan S13 240SX (89-94) 2 10-16-2005 08:49 PM
