RB25 Oil pressure gauge question! - Nissan 240SX Forums
RB Tech Technical Race Bred Chat from the RB20 to RB25, All the way to the RB26 Godzilla!
post #1 of 15 Old 06-30-2008, 02:08 AM Thread Starter
jaykeMURD is on a distinguished road
Points: 2,995, Level: 33
Points: 2,995, Level: 33 Points: 2,995, Level: 33 Points: 2,995, Level: 33
So I've just acquired a decent S14 with a S2 RB25DET. I love it!
I'm in the process of adding a few little things to monitor it, until I can pull the RB and rebuild it!
Anyhow, I'm unable to get under the car for the time being, so I need to know what I'd need to install an oil pressure gauge.
It will be electric, no mech gauges for me! I believe the threads on the block are 1/8 BNPT, correct?
I don't think theres anything out-of-the-ordinary with the oil system on this engine. No oil cooler or spacer or anything like that. So can I just get the proper adapter and thread it in place of the stock sending unit?
jaykeMURD is offline
post #2 of 15 Old 06-30-2008, 02:46 AM
Radianation's Avatar
Quoted: 2 Post(s)
Radianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthyRadianation The posts made by this user are trust worthy
Points: 1,819,209,560, Level: 100
Points: 1,819,209,560, Level: 100 Points: 1,819,209,560, Level: 100 Points: 1,819,209,560, Level: 100
The gauges usually come with the installation directions. I bought an oil pressure sensor from Megan and never hooked it up, but I recall having the manual in the box. BTW - I'm selling that unit if you're interested. =)
Original Owner 1996 S14 240sx SE RB25DET Built
Radianation is offline
post #3 of 15 Old 06-30-2008, 02:55 AM Thread Starter
Well, I already know what it takes to hook one up, I just need to know what exactly needs to be installed on the block....ie: thread size of oil pressure sending unit.
Thanks.
post #4 of 15 Old 06-30-2008, 02:56 AM
Quoted: 2 Post(s)
I don't know that answer. =(
post #5 of 15 Old 06-30-2008, 04:48 PM
DriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthyDriftX The posts made by this user are trust worthy
Points: 1,452,244,874, Level: 100
Points: 1,452,244,874, Level: 100 Points: 1,452,244,874, Level: 100 Points: 1,452,244,874, Level: 100
you should get a sandwich adapter so the oem oil pressure light works as well. then you can take it to autozone, find what thread it is and be done with it.
89 rb20 hatch - sold, 98 cobra - sold, 89 two tone sr20 coupe- sold, h22 eg hatch - sold and DEF not missed, 93 lx Built in every way - current dd, 88 trunk stang - drag whore.
DriftX is offline
post #6 of 15 Old 06-30-2008, 06:51 PM Thread Starter
That's kinda my last resort....I don't like sandwich adapters, seems they can mess with pressure. Then again, it'll be more reliable than a brass fitting threaded into the block, holding the sending unit/stock sensor.
post #7 of 15 Old 06-30-2008, 09:46 PM
Quoted: 2 Post(s)
I will probably be installing mine on Thursday afterall. If I learn anything I'll let you know.
post #8 of 15 Old 07-03-2008, 07:10 PM Thread Starter
I decided to go with a sandwich adapter too. Hopefully everything will work out.
RB25's use the same size oil fiilter as the stock KA dont they? Isn't it 3/4-16 thread?
post #9 of 15 Old 07-05-2008, 06:58 PM
The guy from RawBrokerage
Coolwhip's Avatar
Coolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthyCoolwhip The posts made by this user are trust worthy
Points: 514,602,200, Level: 100
Points: 514,602,200, Level: 100 Points: 514,602,200, Level: 100 Points: 514,602,200, Level: 100
correct
New & Used RB20, RB25, RB26, and RB30 Parts
Coolwhip is offline
post #10 of 15 Old 07-06-2008, 01:37 AM
DeclareYrWar's Avatar
DeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthyDeclareYrWar The posts made by this user are trust worthy
Points: 850,411,129, Level: 100
Points: 850,411,129, Level: 100 Points: 850,411,129, Level: 100 Points: 850,411,129, Level: 100
http://tunertoys.zoovy.com/product/O...al_Outlet.html there you guys go
'89 Lavender Frost Coupe W/RB20DET
HKS GT2535 turbo, 550cc injectors, Z32 MAF
SOLD
DeclareYrWar is offline
post #11 of 15 Old 07-20-2008, 10:18 PM Thread Starter
Ok, I went with the sandwich adapter, got everything installed....no leaks!
However, my gauge isn't working. It's a run-of-the-mill Autometer elec.pressure gauge and the needle never moves.
Got everything wired according to the basic instructions, but no go. The gauge is getting power, and it's grounded properly, so I'm left assuming the sender or gauge is bad.
Anyone know a way to test either out?
post #12 of 15 Old 06-18-2010, 08:31 PM
XLR8_S14's Avatar
XLR8_S14 is on a distinguished road
Points: 1,748, Level: 24
Points: 1,748, Level: 24 Points: 1,748, Level: 24 Points: 1,748, Level: 24
You could always jsut take the gauge back and say that it doesnt work. try another one out. or you could borrow someones gauge and check it out.
S14 . . . RB25DET
Hear my RB25det...
XLR8_S14 is offline
post #13 of 15 Old 04-17-2013, 01:22 PM
supersayianjim2's Avatar
supersayianjim2 is on a distinguished road
Points: 10,324, Level: 67
Points: 10,324, Level: 67 Points: 10,324, Level: 67 Points: 10,324, Level: 67
Activity: 87%
Activity: 87% Activity: 87% Activity: 87%
Originally Posted by DeclareYrWar View Post
Oil Take Off - Dual Outlet there you guys go
has anyone purchased one of these before??
-nissan s13 rb25det-350whp/308 tq- made on a shitty street tune
1994 sc400-1jz swapped hx40
1996 toyota corolla-mt5
"Technology is the only replacement for displacement."
-my rb build-
supersayianjim2 is offline
post #14 of 15 Old 06-04-2013, 01:09 PM
got_psi? is on a distinguished road
Points: 3,686, Level: 38
Points: 3,686, Level: 38 Points: 3,686, Level: 38 Points: 3,686, Level: 38
This is another option, Autometer makes a metric adapter for the sender:
Auto Meter
got_psi? is offline
post #15 of 15 Old 06-18-2013, 08:22 PM
Activity: 87%
you need a bspt port that goes to the block.
-my rb build-
Oil Pressure question... STARBUCKS SR20DE & DET 3 03-10-2006 01:06 PM
Oil pressure guage question Imjosh SR20DE & DET 3 02-19-2006 11:55 AM
Oil Pressure Question jedi_car_fan SR20DE & DET 1 10-14-2005 12:02 AM
rb25 w/ka harness oil pressure sending unit/speed sensor ? ThomasK(Austin) RB Tech 2 08-09-2004 09:15 PM
how to install oil pressure gauge TheSparo SR20DE & DET 8 11-02-2003 10:21 AM
