vibration in the rear (drive shaft problume?) - Nissan 240SX Forums
RB Tech Technical Race Bred Chat from the RB20 to RB25, All the way to the RB26 Godzilla!
post #1 of 11 Old 05-02-2006, 10:26 PM Thread Starter
XIONM7716 is on a distinguished road
I just recently finished my rb25det swap into a s14 using stock r33 crossmember and costum tranny braket. it pulls nice but vibrates violently at over 40mph. I know its not the wheels cause i balanced them my self. the angle for the drive looks perfict and the drive shaft is new. do you think the length of it is the problume. mine is 42.5 in. from ujoint to ujoint. thet gives it .5 in. of play. I do have a semi solid bushing for the tranny mount too. is that causing the vibration to travel to the car. any thing will help. Thanks
XIONM7716 is offline
post #2 of 11 Old 05-02-2006, 10:30 PM
murphy's Avatar
murphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthymurphy The posts made by this user are trust worthy
Points: 214,764,869, Level: 100
Points: 214,764,869, Level: 100 Points: 214,764,869, Level: 100 Points: 214,764,869, Level: 100
could be a driveshaft problem but it sounds like a wheel problem (are your wheels bent)?
murphy is offline
post #3 of 11 Old 05-02-2006, 11:22 PM
shockster0429's Avatar
shockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthyshockster0429 The posts made by this user are trust worthy
Points: 236,229,666, Level: 100
Points: 236,229,666, Level: 100 Points: 236,229,666, Level: 100 Points: 236,229,666, Level: 100
make sure shaft is securely locked down to the diff
i had this same issue
shockster0429 is offline
post #4 of 11 Old 05-02-2006, 11:54 PM Thread Starter
I dubbled check the rear fange
And the wheels Rolled fine on the balancer
post #5 of 11 Old 05-03-2006, 11:26 PM
hmm what vibrates exactly? the whole car? the steering wheel? like be a little more specific.
post #6 of 11 Old 05-04-2006, 12:47 PM Thread Starter
I put my car up on the lift last night and took of the rear wheels and drove it in 5th to 40mph When it was still up on the lift. and the thing was still vibrating (the whole car)I went under to listen with a sethascope and to feel where the vibrations are coming from. most if not all were coming from the rear end and my axles. I come to conclude that I broke somthing in my rear end or my axles are warped. They did look alittle lopsided. The vibration did not happen until my 2nd drive around the block when I wot through all first 3 gears.(when I first finished the swap)
post #7 of 11 Old 05-04-2006, 01:47 PM
DLSracing's Avatar
DLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant future
Hmm sounds interesting. It could be the wheel bearings are gone in the rear. When they go the rear end gets really loose. I doubt you warped the drivesharfts unless they were in bad shape already. Are you sure your driveshaft was balanced? if it wasn't then it will cause the same problem...
DLSracing is offline
post #8 of 11 Old 05-05-2006, 04:27 AM Thread Starter
I belive the shaft is balanced. there is a wiegth welded on it. Ann the place i took my shaves in is a reliable place. The wheel bearings are still good, no play in them or noise coming from them. I probubly broke some teeth in the dif or broke the bearings in the dif. it's still just a stock non lsd dif.
Thanks for all the help. If any one could think of any thing else I'll be more then happy to look in to it.
post #9 of 11 Old 05-05-2006, 08:54 AM
Carl H's Avatar
Carl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthy
Points: 430,735,932, Level: 100
Points: 430,735,932, Level: 100 Points: 430,735,932, Level: 100 Points: 430,735,932, Level: 100
i doubt you broke the ring gear, there have been plenty of cars running round on the factory rear end making 500+hp and not killing the diff, if anything you'll break the axels before you destroy a nissan rear end.
have you tried checking the tightness of the driveshaft bolts, even if they are slightly loose the vibrations will be insane.
Shift_BOOM. Damnit.
BlackBox Tuning Now offering wire harness conversions and tuned RB/KA ECU services.
PM for details.
Carl H is offline
post #10 of 11 Old 05-06-2006, 01:03 AM
Yellow4g63's Avatar
Yellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthyYellow4g63 The posts made by this user are trust worthy
Points: 2,147,496,502, Level: 100
Points: 2,147,496,502, Level: 100 Points: 2,147,496,502, Level: 100 Points: 2,147,496,502, Level: 100
Activity: 11%
Is the trans straight? I had a little problem with mine when I installed it. It was striaght so I would get this strange sound from the rear of the car. I didn't look from the top when I was adjusting the mount.
Yellow4g63 is offline
post #11 of 11 Old 05-06-2006, 04:41 AM
Mr.180sx's Avatar
Mr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthy
ladies like vibration in the rear
2005 Suzuki GSXR 750 Track/Stunt
2005 Yamaha R6 Track (Black , Tuned , & Modded)
69 Chevy Camaro (Street ) Running Restoration project
Mr.180sx is offline
Aluminum drive shaft 2.240s S13 240SX (89-94) 29 04-24-2006 02:56 AM
top hat drive shaft TonysS13 RB Tech 12 04-22-2006 07:32 AM
I need help .. Drive shaft Angelslide S13 240SX (89-94) 0 06-18-2005 05:36 PM
