oil pump removal question? - Nissan 240SX Forums
RB Tech Technical Race Bred Chat from the RB20 to RB25, All the way to the RB26 Godzilla!
post #1 of 21 Old 02-27-2007, 08:32 PM Thread Starter
cruisnhard's Avatar
cruisnhard is on a distinguished road
Points: 4,789, Level: 44
Points: 4,789, Level: 44 Points: 4,789, Level: 44 Points: 4,789, Level: 44
How do I get the timing belt crank gear off.
Do I just need to pry on it a little bit or what. I am trying to put my new pump on and I can not get the old one off. Please help. I am trying to get the engine in and running by tomorrow evening. It is a RB20DET in case it is different.
cruisnhard is offline
post #2 of 21 Old 02-27-2007, 09:13 PM
protektuner is on a distinguished road
Points: 3,768, Level: 38
Points: 3,768, Level: 38 Points: 3,768, Level: 38 Points: 3,768, Level: 38
Mines on my rb25 slides easily off i dont know if it should be doing this but the one on my 20 is in there good but I suppose you can use a pry on it
protektuner is offline
post #3 of 21 Old 02-27-2007, 10:03 PM Thread Starter
cruisnhard's Avatar
I will try it.
post #4 of 21 Old 03-02-2007, 06:35 AM Thread Starter
cruisnhard's Avatar
CARL H on a thread in nico clucb said that nissan has a tool for this. Anyone know what it is called?
post #5 of 21 Old 03-02-2007, 10:54 PM
Carl H's Avatar
Carl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthyCarl H The posts made by this user are trust worthy
Points: 430,735,932, Level: 100
Points: 430,735,932, Level: 100 Points: 430,735,932, Level: 100 Points: 430,735,932, Level: 100
i found out the tool was a one off job...sucks because it works so well.
Shift_BOOM. Damnit.
BlackBox Tuning Now offering wire harness conversions and tuned RB/KA ECU services.
PM for details.
Carl H is offline
post #6 of 21 Old 03-04-2007, 05:45 PM Thread Starter
cruisnhard's Avatar
I may just try to make one anyways. thanks though.
post #7 of 21 Old 03-05-2007, 11:52 AM
JerryRigRB240's Avatar
JerryRigRB240 is on a distinguished road
Points: 7,673, Level: 58
Points: 7,673, Level: 58 Points: 7,673, Level: 58 Points: 7,673, Level: 58
Use a propane torch and heat the gear up... it should make removal a little easier.
1990 Red Coupe
RB20DET
2.2 CP Pistons
GT2530
JerryRigRB240 is offline
post #8 of 21 Old 03-05-2007, 02:22 PM
DLSracing's Avatar
DLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant future
There are a couple ways of removing the gear. The main difference is wether you need to keep the gear or not. If you need to keep the gear then heating like stated is about the only way. You can also try and make a puller. The second option is you drill several holes into the pulley on a verticle line. Then you take a punch or chisel and break the gear apart. The other method is to drill two holes about 1" deep into the top of the gear. You will then tap the holes and place two bolts into the holes. You can now use a puller to remove the gear. This method also ruins the gear so you will need another one...
DLSracing is offline
post #9 of 21 Old 03-06-2007, 06:17 PM
Carl H's Avatar
it should also be said that the rb series timing gear does not cross with ANY stateside motor...
Shift_BOOM. Damnit.
PM for details.
Carl H is offline
post #10 of 21 Old 03-07-2007, 12:13 PM
DLSracing's Avatar
Very true. You can get them from some of the Aussie sites. Last I checked they were running about $150 or so...
post #11 of 21 Old 03-07-2007, 04:07 PM
Sil240 is on a distinguished road
Well are you changing your oil pump??
You can ghetto beat it like I did.
Penetrating lube it like crazy, then beat the SHYT outta the back of the oil pump with a 2X4 and a rubber malet.
But then again my motor was on a engine stand.
Hope your's is too.
"The Strong Move Quiet, The Weak Start Riots"
Sil240 is offline
post #12 of 21 Old 03-07-2007, 09:38 PM Thread Starter
cruisnhard's Avatar
The motor is actually on jack stands. Not the safest, but my engine stand is in NC and I have not picked up another one. Also I am changing the pump as soon as I get the gear off. I think I am going to hook up the engine lift for more safety and hit it like Sil240 said. That way it has extra bracing. I also think I am going to attempt to make a removal tool and try to pull it off. hopefully I can get it off, because I really need this thing running. Everything else is ready so this is whats holding me up. Thanks for the comments and If I can make a tool I will post it up so others can make one too.
post #13 of 21 Old 03-07-2007, 10:03 PM
LongGrain is on a distinguished road
in for more replies
i tried to remove the oil pump on my CA by trying to scoot it off while scooting the sprocket off with it...yea that worked fine until my oil pump snapped into 3 pieces...one of those pieces is STILL stuck on my crank since i cant get the sprocket off...
LongGrain is offline
post #14 of 21 Old 03-08-2007, 08:59 AM
Carl H's Avatar
do not use the pump as a way to remove the sprocket, that is the worst idea evar...something bad will happen and if you dont have a replacement pump you will be sol.
the problem is that the gears are usualy rusted on and generaly need some persuasion to come off...try some pb blaster or some really hard core penetrating lubercant that eats rust.
when you finaly do get the sprocket off make sure to take some really fine sandpaper and smooth the rust down on the crank snout and use a bit of copper antiseize when you reassmeble the pump assmbly.
Shift_BOOM. Damnit.
PM for details.
Carl H is offline
post #15 of 21 Old 03-08-2007, 12:54 PM
It's definetly not the best way to get the sprocket off if your going to keep the pump.
But I was changing my pump and PB blaster and every other lube/anti-rust spray didn't do anything.
Mine was damn near fused on the crankshaft.
Since he's changing the pump if nothing else works go for it.
Just make sure it hit the pump equally and closest to the center.
Sil240 is offline
post #16 of 21 Old 03-08-2007, 04:56 PM Thread Starter
cruisnhard's Avatar
I am about ready to just try heating it up. It wont hurt the gear or crank will it. I know they get pretty warm when running.
post #17 of 21 Old 03-08-2007, 08:57 PM Thread Starter
cruisnhard's Avatar
one guy on skylinesaustralia forum drilled and tapped two small holes and used a puller. I am thinking of doing this, but I am afraid of ruining the gear. any thoughts.
post #18 of 21 Old 03-08-2007, 09:00 PM
DLSracing's Avatar
You can do that, but I feel it ruins the gear. I don't like the idea of drilling holes into something that rotates as fast as this part does. Plus the stress the gear takes is pretty high. I would replace it...
post #19 of 21 Old 03-08-2007, 09:29 PM Thread Starter
cruisnhard's Avatar
I am trying to find one. I am going to have to call the nissan dealership tomorrow to see if they have one. I am still going to try the heat thing.
post #20 of 21 Old 03-09-2007, 09:08 AM
Carl H's Avatar
it kinda late to say this but its a moot point to put a n1 pump on the car if the crank hasnt been collared.
Shift_BOOM. Damnit.
PM for details.
Carl H is offline
post #21 of 21 Old 03-11-2007, 10:48 PM Thread Starter
cruisnhard's Avatar
I just got the gear off. I had to shave some metal off of the gear puller so it could fit behind the gear. Also when I was pulling it off I broke a bolt on the puller. That should tell you how bad it was rusted on. I am going to clean the crankshaft and put the new oil pump on and hopefully have the motor in the car by tuesday. It was a BI*(h.
How To: Install Walbro Fuel Pump Scoot Resource Center 15 09-10-2010 10:56 AM
weak oil pump? cvhswrestler1 SR20DE & DET 8 03-16-2005 12:02 AM
Upgraded Oil Pump ???? Dhohn SR20DE & DET 9 01-18-2005 04:24 PM
Fuel pump question + a few others :) MaStA S13 240SX (89-94) 0 02-19-2003 06:59 PM
