DIY: ITB's for your KA24DE - Nissan 240SX Forums
Go Back   Nissan 240SX Forums > Nissan 240SX Technical Section > Resource Center
Resource Center For all DIY Write-Up's, FAQ's & Product Reviews.
240SXForums.com is the premier Nissan 240sx Forum on the internet. Registered Users do not see the above ads.
LinkBack (35) Thread Tools
Old 06-16-2005, 04:05 AM   35 links from elsewhere to this Post. Click to view. #1 (permalink)
pandas14 is on a distinguished road
Just recently got this project running, so I might as well do a writeup.
Here goes.
Intake mani and TB's
First, get some 01' or higher Suzuki GSXR 1000 or 750 Throttle Bodies.
Then get an extra intake mani.
Cut the runners off approximately 6" from the head flange.
Go to Home Depot and get some rubber plumbing couplers. They're about $5 a piece with clamps.
Clamp the Mani and TB's together to yield this...
And with the couplers trimmed down, and the velocity stacks on...
Now make 2 brackets that brace the TB's to the mani, for extra strength.
I used 3/4" by 3/16" steel. You can find this at Home Depot. Bolted one end to the TB's and the other slips under the mounting point for the PCV rail. Make one per side. Should look something like this...
Now make a bracket for the throttle cable to slip into. I used 1 1/2" angle iron. This can also be found at Home Depot. Make it to bolt onto the mounting surface that the EGR used to sit on.
Get a SOHC throttle cable. The DOHC one is wayyyy too long. The SOHC cable is too long too, but better than the DOHC one. The end of the Nissan throttle cable that slips onto the throttle wheel fits in the Suzuki throttle wheel perfectly.
get two air boxes from a 01' and up GSXR 750. These have the shortest velocity stacks. Each airbox has two short stacks, and two long ones. Once you have 2 boxes, you will have two full sets of velocity stacks to help you achieve the best powerband down the road.
That's it for the manifold part of things.
Now the fuel management.
I chose to use a MegaSquirt (MS) because of price, and because, well, I love DIY stuff as you can probably see. haha
Get your board and bags of components all lined up like so...
Build the stimulator first. This will help you learn how to make proper solder joints befor you start soldering the actual MS together. The stimulator hooks up to Megasquirt and stimulates the MS such that it thinks it is running an engine. What this does is allow you to make sure all of your MS is built and running correctly before trying to start the car with it. It also allows you to download new codes to the CPU chip as you see fit, without having to have the MS in the car. Very trick.
Follow the MegaManual at www.megasquirt.info and you will end up with this...
Now build the pigtail for the wiring harness...
and here's a better pic of how many wires there are. This is the entire engine harness. Stock one gets removed completely.
that's basically it for the MS.
Now for the ignition setup.
I chose to run a distributorless system off of early 90's Ford Escorts. This system uses a trigger wheel that is mounted to the crank pulley to fire the ignition instead of a gear driven distributor. This has many advantages, the first of which being that it is more accurate than the stock distributor. It also gives full control of the ignition timing.
from left to righ in the pic below, we have the EDIS module, the VR sensor (reads the trigger wheel on the crank pulley) and the Coil.
Here is a picture of the spark plug wires modified to fit down the spark plug holes in the valve cover. the boot that connects to the plugs has about a 30 degree bend in them so I bent them back straight, and trimmed the boots until they slid down into the holes in the valve cover.
Next, you have to get a trigger wheel made. I have a friend who is a CNC machinist, so he made one for me, as well as prepping the crank pulley for the wheel.
And the wheel fit onto the pulley looks like so...
Now make a bracket to mount the VR sensor onto. I put mine where the A/C compressor used to be. just some more of the angle Iron used before, long enough to mount the sensor on, facing the crank pulley.
Next, make a block off plate for the hole that the distributor used to occupy. I made mine big enough to mount the new coil to, as that is as far as the plug wires would reach. Just simple 1/8" thick steel. when finished it looks like this bolted to the engine, with the new coil mounted on it.
On a side note, here is the stock KA24DE timing map I scaled down. I have used it and it works great.
Putting it all together.
Now pull off your stock intake mani, and take out your engine harness. You will no longer need either of these. bolt the new mani onto the engine, it should look something like this...
You can also see in those pics the wiring harness was finished. It's simply following the diagram, running each wire to each sensor.
the only things that were not on the diagrams were the tach signal, water temp gauge and the switched ignition power supply. the Tach signal was cake, run a wire from the Clean Tach Out pin on the EDIS module to the Tach input on the back of the gauge cluster. That's it. Speedo will still work. Run a wire from the second temp sensor in the intake mani to the coolant temp input on the back of the gauge cluster. that's all for that. And the B/R wire coming from the igntion switch on the steering column needs to be tapped into to get switched power to MS, and the ignition components.
However, the wiring diagram for the ignition is slightly off. the polarity of the VR sensor wires is opposite than in the diagrams, so wire that up accordingly.
I used the stock injectors for now, but I have some SR injectors lying around waiting to go in. Stock injectors will be enough for now.
for the brake booster, I used the stock PCV rail, and ran one line from its output to the brake booster. Has worked great. I also Tee'd a 1/4" vacuum line out of this line, on it's way to the booster, for the fuel pressure regulator. Before doing any of this, I measured the vacuum in this line, and in the rest of the intake mani under all braking conditions, and the booster did not affect the vacuum in the engine. This being so, it is safe, and fine to run the vacuum for the FPR from the brake booster vacuum line.
the TB's come from the factory with a vacuum line from each port Tee'd into one. this is used for the map sensor. Simply run a line from this to MS. the MAP sensor is inside the MS box.
Then swap out the throttle cables, and hook the SOHC one up.
Finally, plug the EGR hole in your header.
If I recall correctly, this is about it for what I did on this whole project to get it running. for the specifics of the MS building and whatnot, and the ignition specifics and diagrams, visit www.msefi.com and www.megasquirt.info.
I specifically did not go into extensive detail in these areas because it is covered very well at those two sites.
So finally start it up and get it idling correctly. Do this by adjusting the screw that adjusts how far open the throttle plates are at "closed" so it has an idle speed you like, and adjusting the fuel amount in the MS. You can then get your own wideband to tune it, or take it to someone. Wichever's clever.
After tuning it, GO DRIVE IT! Don't forget to give yourself a pat on the back too!
Please forgive me if I have forgotten anything, it is a very long project, there is so much to do. I may have left a few small details out, but this is the major stuff.
Driving impressions
I don't have it tuned very well yet, but I can tell you that throttle response is immediate. The engine also revs up MUCH quicker. It does not feel like the lunky old KA. It's a whole new engine. This definately made it come alive. It is, of course MUCh louder also. It no longer sounds like a KA. Sounds way more pissed, like an engine with 2x the displacement.No dyno slips yet, but once I get one, I will be certain to post it up, as well as a video/soundclip.
Cheers
Scott Slater
pandas14 is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 11:02 AM   #2 (permalink)
Fidelity101's Avatar
Fidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthy
Points: 948,461,230, Level: 100
Points: 948,461,230, Level: 100 Points: 948,461,230, Level: 100 Points: 948,461,230, Level: 100
Activity: 13%
hothothothothot
My Rx-7 Vids
Fidelity101 is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 11:48 AM   #3 (permalink)
TurboDreams954 is on a distinguished road
sick i was waiting for you to finish it!
TurboDreams954 is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 11:53 AM   #4 (permalink)
sdtouge is an unknown quantity at this poINT
sick i think your gonna win makes me wanna do this to a ka lol.
hunters aim is boostaddict14 talk to him
8==========D~
sdtouge is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 12:23 PM   #5 (permalink)
Banned by Moderators
Revolution240sx's Avatar
Revolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthyRevolution240sx The posts made by this user are trust worthy
NICE. you win teh prize :O
Revolution240sx is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 03:06 PM   #6 (permalink)
mnkypsycho is on a distinguished road
can we get some sound clips or videos?
mnkypsycho is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 03:27 PM   #7 (permalink)
sidewayz240sx's Avatar
sidewayz240sx is on a distinguished road
Points: 7,067, Level: 55
Points: 7,067, Level: 55 Points: 7,067, Level: 55 Points: 7,067, Level: 55
very nice write up, how much did the whole thing cost? i also think u should get some sound clips
sidewayz240sx is offline   Reply With Quote Quick reply to this message
Old 06-16-2005, 08:39 PM   #8 (permalink)
I've got one sound clip, but my camera sucks horribly, so it sounds awful. I'll get a better sound clip when it's all tuned. Shouldn't be too long, my WB 02 should get here any day.
Total cost is somewhere around $950-1000 with the wideband oxygen sensor, all gaskets, orings etc...
Old 06-16-2005, 09:18 PM   #9 (permalink)
cervasa's Avatar
cervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthycervasa The posts made by this user are trust worthy
Points: 621,972,185, Level: 100
Points: 621,972,185, Level: 100 Points: 621,972,185, Level: 100 Points: 621,972,185, Level: 100
wow thats sick i want to see a dyno chart when you have one
my build thread
http://www.240sxforums.com/forums/sh...09#post1139909
Chuki fan club #24
cervasa is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 12:24 PM   #10 (permalink)
Drifteador is on a distinguished road
winner!! doesn't get any more dyi
I'd also like to see a dyno. and btw thanks for the timing map. I've been looking for something like that
Drifteador is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 12:40 PM   #11 (permalink)
ruthlesstyper's Avatar
ruthlesstyper is on a distinguished road
hey can u give us a proce listing ?
My 89 Fastback
ruthlesstyper is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 01:35 PM   #12 (permalink)
Points: 2,042,315,427, Level: 100
Points: 2,042,315,427, Level: 100 Points: 2,042,315,427, Level: 100 Points: 2,042,315,427, Level: 100
Activity: 52%
Activity: 52% Activity: 52% Activity: 52%
Damn thats hawt
Scoot is online now   Reply With Quote Quick reply to this message
Old 06-17-2005, 01:58 PM   #13 (permalink)
Price breakdown...
MegaSquirt: 187
Serial cable: 25
Throttle Bodies: 155
Intake mani: 25
Velocity stacks: 60
Throttle cable: 25
SR injectors: Free! (thanks Jordan!!!)
Wire for harness: 10
Plug Wires: 25
EDIS stuff: 55
Trigger wheel CNC and crank pulley machining: 100
WB 02: 194
Misc hardware/metal: 20
couplers: 20
Intake mani gasket: 16
Injector o rings: 10
Total: $927
So I guess it's under what I had expected. So in the end you have ITB's, a standalone, and wideband oxygen sensor for about $900 and if you sell the stock parts, well under that.
Old 06-17-2005, 02:05 PM   #14 (permalink)
Activity: 13%
now carb that ka!
My Rx-7 Vids
Old 06-17-2005, 02:10 PM   #15 (permalink)
jhcrazyboi is on a distinguished road
HOlY S@$#@.....O GOD OF THE KA
jhcrazyboi is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 02:23 PM   #16 (permalink)
uno
uno's Avatar
uno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud ofuno has much to be proud of
nice writeup man, good job.
1993 240sx w/CA18DET + Boltons *Gone*
1999 Z28 A4 w/ Catback, SLP Lid, K&N
2004 RX8 Auto Stock *Gone thankfully
2003 Mach 1 M5 w/ exhaust
1993 Integra LS 5 speed Stock , gas saver
uno is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 02:50 PM   #17 (permalink)
reefer1114's Avatar
reefer1114 is on a distinguished road
simply WOW!
reefer1114 is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 02:54 PM   #18 (permalink)
SLO-S13
Dark-Hawk's Avatar
Dark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthyDark-Hawk The posts made by this user are trust worthy
Points: 50,893, Level: 100
Points: 50,893, Level: 100 Points: 50,893, Level: 100 Points: 50,893, Level: 100
Very nice write up, definitley would like to hear some sound clips of this thing in action!
90 240SX - Dead 07.04.06
92 240SX HB Base - Gone
95 240SX
Dark-Hawk is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 02:59 PM   #19 (permalink)
Activity: 52%
What is the diameter of the TB's?
Would a Hayabusa TB fit?
Old 06-17-2005, 03:29 PM   #20 (permalink)
The throttle plate diameter is 42mm.
stock runner ID is 44-45mm
I've heard Hyabusa TB's are 46mm, but I'm not sure about that. I'm also not sure about the spacing between the TB's.
One thing to remember is that with a larger throttle plate diameter, you have a potential for more absolute HP, but throttle response will decline. Also, there is a TP diameter that is optimal for each engine, and anything bigger will just have adverse affects. However, since ITB's on KA's is a very new thing with not much testing, nobody knows what the optimum throttle plate diameter is. It very well could be larger than 42mm, or it could be smaller. Nobody knows. More than likely tho, it is larger than 42mm, but not by much.
Also, about carbs. Both carbs and ITB's make a bunch more power than stock, and yield much better throttle response. However, the powerband with carbs is narrower and more peaky, so that's why ITB's were my choice.
Old 06-17-2005, 06:23 PM   #21 (permalink)
s134's Avatar
s134 is on a distinguished road
very inspiring
http://www.driftgirl.org/
deal with it BITCH oh waaa tisK tisk
s134 is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 06:34 PM   #22 (permalink)
Dori_Dori is on a distinguished road
i must hear this
Dori_Dori is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 08:59 PM   #23 (permalink)
Breezy is on a distinguished road
Points: 6,602, Level: 53
Points: 6,602, Level: 53 Points: 6,602, Level: 53 Points: 6,602, Level: 53
holy crap man. you are my new hero. wow. seriously, wow good job. i think you'll definetly win. the diy contest and my vote for the most awesome diy i think i've ever seen. props to you.
Breezy is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 09:12 PM   #24 (permalink)
xDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthyxDRFTurR1D3x The posts made by this user are trust worthy
Points: 11,975,938, Level: 100
Points: 11,975,938, Level: 100 Points: 11,975,938, Level: 100 Points: 11,975,938, Level: 100
do you need the plumbing ?? could you not jsut weld the tbs to the mani???
xDRFTurR1D3x is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 10:55 PM   #25 (permalink)
speed1100blue is on a distinguished road
im really thinking about doing this setup. i have a few tech questions though. I can build the ITB setup( i think) my main question is the ecu. How hard was that to build and how does it all go together does the MS completly replace your ecu, and what about the MAF and other stuff like that, and do i have to run a distrubuter setup like yours or can i use my existing setup. I know a lot of questions but i really what to do this setup.
speed1100blue is offline   Reply With Quote Quick reply to this message
If you do not want to register, fill this field only and the name will be used as user name for your post.
LinkBack to this Thread: http://www.240sxforums.com/forums/resource-center/58363-diy-itbs-your-ka24de.html
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 10-11-2009 11:20 AM
240sx bible This thread Refback 09-06-2009 12:30 PM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 09-05-2009 02:29 AM
240sx bible This thread Refback 08-29-2009 05:18 PM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 08-20-2009 01:13 PM
The 240sx Bible - 502StreetScene This thread Refback 08-09-2009 11:56 AM
www.ka-t.org :: View topic - Individual Throttle Bodies? This thread Refback 06-24-2009 01:05 AM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 06-22-2009 04:36 AM
IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - The Ultimate 240SX Bible This thread Refback 05-23-2009 11:56 PM
IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - The Ultimate 240SX Bible This thread Refback 05-20-2009 09:45 PM
IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - The Ultimate 240SX Bible This thread Refback 05-20-2009 03:30 PM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 03-26-2009 03:51 PM
Ultimate 240sx Bible Vol 1 - Toronto Nissan Club This thread Refback 03-02-2009 12:12 AM
double intake question - Nissan Forums: Nissan Altima Forum This thread Refback 02-28-2009 07:50 PM
Random 240sx Information and Part Numbers - Import FanatiX Car Club This thread Refback 02-26-2009 07:22 PM
240SX Forums This thread Refback 02-25-2009 05:08 AM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 02-17-2009 01:17 AM
ITB Issues - Lift me up or beat me down - Tampa Racing This thread Refback 02-14-2009 12:16 PM
NODrFt - The 240sx Bible - Answers to almost ALL 240sx questions This thread Refback 01-30-2009 05:42 PM
240SX Bible - 240Atlanta.com This thread Refback 01-12-2009 08:04 PM
Ultimate Write Up - NV240SX.ORG - Forums - v2.0 This thread Refback 01-05-2009 09:35 PM
Ultimiate 240SX Bible from KA-T.org - for all 240 noobs ;) - .:: Midwest Streets ::. This thread Refback 01-02-2009 07:04 PM
*Ultimate 240sx Bible Volume 1.* - Toronto Nissan Club This thread Refback 12-21-2008 01:46 AM
KA24E High-compression N/A build - 240Atlanta.com This thread Refback 11-30-2008 01:53 PM
KA24E High-compression N/A build - 240Atlanta.com This thread Refback 11-30-2008 01:50 PM
Nissan 240sx This thread Refback 11-15-2008 01:47 AM
WinnipegHeights.com - Ultimate 240SX Bible Vol. 1 This thread Refback 11-13-2008 01:18 AM
The Ultimate 240SX Bible Volume 1 - Pennsylvania Nissan Owners Club Forum This thread Refback 10-16-2008 03:21 AM
The Ultimate 240SX Bible - StreetUnitForum.com This thread Refback 10-14-2008 11:25 PM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 10-11-2008 02:52 PM
TunerFriends - tuner enthusiast community - Ultimate 240sx guide (aka The Bible) This thread Refback 10-05-2008 08:27 PM
240sx bible - Tampa Racing This thread Refback 10-03-2008 11:47 PM
NODrFt - The 240sx Bible - Answers to almost ALL 240sx questions This thread Refback 10-02-2008 06:51 PM
The Ultimate 240SX Bible Volume 1 - Pennsylvania Nissan Owners Club Forum This thread Refback 10-02-2008 04:38 AM
www.ka-t.org :: View topic - The Ultimate 240SX Bible Volume 1 This thread Refback 09-30-2008 07:21 PM
Do KA24DE ITB's exists...? nismostyle240 KA24DE & KA24E 9 05-29-2005 11:28 AM
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
