SR20: fuel filter/lines/rail/injectors? problem 89 s13 redtop *videos* - Nissan 240SX Forums
post #1 of 9 Old 06-29-2013, 07:30 PM Thread Starter
Ajd
Ajd's Avatar
Ajd is on a distinguished road
Points: 139, Level: 2
Points: 139, Level: 2 Points: 139, Level: 2 Points: 139, Level: 2
Activity: 8%
Angry fuel filter/lines/rail/injectors? problem 89 s13 redtop *videos*
Started my car the other day and white smoke was coming out of the exhaust and the hood, smelled like gas, the next day (today) it didnt want to start, tried again, it started, no smoke, I noticed that the fuel filter is covered with gas on top (300zx fuel filter)... the fuel gauge (fuelab Fuel Pressure Regulator) was reading 40psi witch is connected to the fuel rail. I also noticed a buzzing noise that im pretty sure was coming from the fuel rail around that area, also 1500 idling and wideband reading rich.... Any help would be greatly appreciated
Redtop sr20det
s13 trans
r32 vlsd & axles with 4.41 gears
cometic metal head gasket
ARP head studs
Greddy rocker arm stoppers
Walbro 255lph
Enjuku racing hotpipe
jdy underdrive crank pulley
B&M short shifter
RS-R gt2 magic cat-back exhaust
Greddy turbo outlet pipe
TiAL bov
cat-delete pipe
Spec stage 2 clutch
Electric slim fan
Garrett gt2871r turbo
740cc injectors, top feed w/ fuel rail
Greddy intake manifold
AEM EMS w/ trigger wheel/disk - map based
top fuel oil catch can
Ajd is offline
post #2 of 9 Old 06-29-2013, 11:45 PM
angrychild1997's Avatar
Quoted: 5 Post(s)
angrychild1997 is on a distinguished road
Points: 1,899, Level: 25
Points: 1,899, Level: 25 Points: 1,899, Level: 25 Points: 1,899, Level: 25
Activity: 15%
Activity: 15% Activity: 15% Activity: 15%
stuck open injector? and did u check the fuel filter it self? it might be going bad
angrychild1997 is offline
post #3 of 9 Old 06-30-2013, 12:13 AM Thread Starter
Ajd
Ajd's Avatar
Activity: 8%
Changing fuel filter tomorrow with a 300zx (z32)
Ajd is offline
post #4 of 9 Old 06-30-2013, 01:26 AM
Quoted: 5 Post(s)
Activity: 15%
just out of curiosity why is your idle so high?
post #5 of 9 Old 06-30-2013, 02:19 PM Thread Starter
Ajd
Ajd's Avatar
Activity: 8%
No idea might be the tune could be the intake relay honesty I don't know much about what tune is set on the car but it was taken to king motorsports over here in new Berlin Wisconsin and everything checked out from the guy before me ...I called them the other day and they said they ran into some problems and won't take the car in ..they don't know anything about those cars they said... There a top rated shop then again they only deal with Honda and Acura motors...
Ajd is offline
post #6 of 9 Old 06-30-2013, 04:04 PM
Mikester's Avatar
Quoted: 2 Post(s)
Mikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthyMikester The posts made by this user are trust worthy
Points: 665,728,520, Level: 100
Points: 665,728,520, Level: 100 Points: 665,728,520, Level: 100 Points: 665,728,520, Level: 100
Your fuel pressure should be 33-34 w/vacuum, 43-44 without.
IN THE UNIVERSE, THERE ARE TWO CONSTANTS: Hydrogen and Stupidity
Mikester is offline
post #7 of 9 Old 07-01-2013, 11:33 PM
Quoted: 5 Post(s)
Activity: 15%
well then you definitely have some homework to do, start by trying to bring the idle down and from there see how the car reacts? if you where to ask me what the problem is i would start by checking those injectors including the o rings, they run stupid rich when their stuck open.
post #8 of 9 Old 07-13-2013, 04:44 PM Thread Starter
Ajd
Ajd's Avatar
Activity: 8%
How do you check them
Ajd is offline
post #9 of 9 Old 07-13-2013, 11:00 PM
duballstar's Avatar
Quoted: 14 Post(s)
duballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthyduballstar The posts made by this user are trust worthy
Points: 2,147,505,708, Level: 100
Points: 2,147,505,708, Level: 100 Points: 2,147,505,708, Level: 100 Points: 2,147,505,708, Level: 100
Activity: 11%
Definitely not a stuck open injector. It would be missing way more. Pull each injector off one by one and see if the idle changes on each one.
My guess is tuning and maintenance.
Has the gas built up on top of the filter again?
P . A . T . T .
duballstar is offline
Tags
fuel filter, fuel rail, idling, injectors, running rich
vaccum lines pretaining to fuel rail soonboosted240 S13 240SX (89-94) 0 06-14-2010 09:36 PM
