Car runs really crappy just read..... - Nissan 240SX Forums
post #1 of 14 Old 12-01-2004, 06:18 PM Thread Starter
Phenix's Avatar
Phenix is on a distinguished road
Ok my car about 3 weeks ago started staling every single time i stoped. Weather it be a stop sign, red light or traffic. That was 3 weeks ago, i was told it was my MAF so i got a new one. Mine is a 91 240 and the one i was sent was a 95 240 MAF. When i got it, it didnt fit, so i made it fit. With duck tape and zip ties i got it done. When i took it for a drive to see if it worked the car wouldnt rev past 3,000 RPM. But the thing is the old MAF worked sometimes, it would sometimes not rev past 3,000 and it would just sputter. Sometimes the old one worked fine except for the fact it would stall out every time i stoped. But the new one wont even go past 3000 RPM at all. So if ANYONE knows what is wrong with my car plz tell me I need and want to get it fixed....THANX!
91 240sx 5spd nothing special yet.(i hate how things cost money)
Phenix is offline
post #2 of 14 Old 12-01-2004, 06:22 PM
Fidelity101's Avatar
Fidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthyFidelity101 The posts made by this user are trust worthy
Points: 948,461,230, Level: 100
Points: 948,461,230, Level: 100 Points: 948,461,230, Level: 100 Points: 948,461,230, Level: 100
Activity: 13%
Do you have a new ECU?
thats been known to happen if you put in an auto ECU for a manual.
Fidelity101 is offline
post #3 of 14 Old 12-01-2004, 06:23 PM
musicmaniac's Avatar
musicmaniac is on a distinguished road
Points: 4,746, Level: 43
Points: 4,746, Level: 43 Points: 4,746, Level: 43 Points: 4,746, Level: 43
fuel pump?
dohc swap, 91+ front end, ractive seat and 4 pt harnesses ( 200 bucks brand new i couldnt resist), centerforce stage 2 clutch, need some susp work
musicmaniac is offline
post #4 of 14 Old 12-01-2004, 06:25 PM Thread Starter
Phenix's Avatar
I have manual ECU and as far i know its ok, Fuel pump i have no idea, ill take a look at it.
Phenix is offline
post #5 of 14 Old 12-01-2004, 06:35 PM
Shwag's Avatar
Shwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthyShwag The posts made by this user are trust worthy
Points: 103,789,393, Level: 100
Points: 103,789,393, Level: 100 Points: 103,789,393, Level: 100 Points: 103,789,393, Level: 100
The problem wasn't with the maf, its because things got dirty.
Clean out the throttle body with carb cleaner and clean/replace all the vaccuum lines.
Jesus, thats the first thing I read on this forum like 6 months ago, how everyone has problems with the engine stalling when you come to a stop.
Originally Posted by Johann Wolfgang von Goethe
None are more hopelessly enslaved than those who falsely believe they are free.
Shwag is offline
post #6 of 14 Old 12-01-2004, 09:33 PM Thread Starter
Phenix's Avatar
The throttle body is clean i clean it myslef like twice a week. The vaccuum lines i will look into. Thanx for all your feedback.
Phenix is offline
post #7 of 14 Old 12-02-2004, 02:34 AM
ShadyCajun's Avatar
ShadyCajun is on a distinguished road
Yeah, I think everyone has had that problem at one time or another (or WILL). There are a few things it could be though, not always just vacuum lines, etc.
I had the same problem when I joined the forum a few years ago, and after inspecting every vacuum line I could find, I did find a couple hoses that needed changing...helped the problem, but didn't fix it. It's not till it died an hour and a half away from home that I finally figured out it was the fuel pump. So these symptoms could very well be a dying fuel pump as musicmaniac suggested. Thankfully if it is, it's a VERY VERY simple affair to pop in a new (or working used) pump.
ShadyCajun is offline
post #8 of 14 Old 12-02-2004, 10:02 AM
Luv2Drift is on a distinguished road
Points: 4,243, Level: 41
Points: 4,243, Level: 41 Points: 4,243, Level: 41 Points: 4,243, Level: 41
fuel pump..
Luv2Drift is offline
post #9 of 14 Old 12-02-2004, 10:14 AM
RPS13DRFTR's Avatar
RPS13DRFTR is on a distinguished road
Points: 5,261, Level: 46
Points: 5,261, Level: 46 Points: 5,261, Level: 46 Points: 5,261, Level: 46
Sounds to me like a combination of 2 problems. IAC valve and fuel pump. IAC valve is causing you to stall at stops, and the fuel pump will not allow you to go into the higher rpm's. Once your fuel pump loses effeciency, it doesn't supply the needed pressure, thus in higher rpm's when more fuel is demanded it can't deliver due to lack of psi and leans out to the point of spitting and sputtering. The same thing happened to me dude, I just went to the junk yard and got another fuel pump outof an S14 and now it's a beast compared to the power it had b4 I replaced the pump.
Your motor is just chokin for fuel dude, and needs a new IAC valve.
Automotive Performance......My Antidrug
SHIFT_Bliss
Speed bumps suck
RPS13DRFTR is offline
post #10 of 14 Old 12-02-2004, 10:24 AM
Activity: 13%
I had a similar problem like that a few weeks ago, it would stall on a rare occasion when I would engine brake.
but are you running rich already?
because this was happening to me while I was running rich, until I blew my 2nd piston injector, but got that fixed and now no richness and no stall during engine brake.
because it was running rich and putting brake on the gas, I was putting to much force on it so it died, or something like that, but that wouldn't explain the not being able to rev past 3kprm.
post #11 of 14 Old 12-03-2004, 12:47 AM
eliterit is on a distinguished road
i had the same problem happen to me on my 93 se-r
it's a n/a sr20 but it turned out to be that the ground wire on my maf just needed to be regrounded
eliterit is offline
post #12 of 14 Old 12-03-2004, 01:49 AM
aznyo15 is on a distinguished road
Aren't the ecu's for the 91 auto and manual perfectly interchangable? I always thought they were basically the same unit except for the 5th gear sensor and fuel cut.
aznyo15 is offline
post #13 of 14 Old 12-03-2004, 01:55 AM
bouncin_180 is on a distinguished road
Points: 4,632, Level: 43
Points: 4,632, Level: 43 Points: 4,632, Level: 43 Points: 4,632, Level: 43
how about this ... when u got the 95 maf did it come wit a plug also? if not did u use yer old one? cause ya from what ive seen n heard the plugs aren't the same so ya. u should just got another 91-93 maf
bouncin_180 is offline
post #14 of 14 Old 12-03-2004, 11:09 AM
RPS13DRFTR's Avatar
Yeah they shouldn't be the same cause even though they might be the same motor, they have different engine managements....(obd-ll)....err whatever the hell you call it.
SHIFT_Bliss
Speed bumps suck
My car blew up ...... Hispanic panic General Tech 11 10-10-2004 09:25 AM
Car wont start w1Nd SR20DE & DET 17 09-10-2004 09:28 PM
Got arrested... again aznromeox Off Topic Chat 6 04-30-2003 02:38 PM
Major problem with my car Jasonrc S13 240SX (89-94) 3 12-13-2002 12:49 PM
