Fuel pump relay = EGI pump? - Nissan 240SX Forums
post #1 of 6 Old 06-15-2005, 08:15 AM Thread Starter
siks13sr is on a distinguished road
is the egi pump actually the fuel pump relay? i cant seem to figure out which relay it is exactly...... also if it is... can you bipass it somehow?
i was driving my car the other day an i shut it off an went out later to go somewhere an the fuel pump (walbro) didnt come bak on...
im tryin to figure out if it is the relay, the fuel pump or the ecu... anyone that could help me would be greatly appreciated.
siks13sr is offline
post #2 of 6 Old 06-15-2005, 09:47 AM
DLSracing's Avatar
DLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant futureDLSracing has a brilliant future
Yes you can bypass it. On the relay it should be numbered you will want to wire the #3 and #5 terminals together. Now this is a high amp terminal so you need a pretty heft wire. Also did you check the fuel pump fues to see if it blew....
DLSracing is offline
post #3 of 6 Old 06-15-2005, 01:12 PM Thread Starter
yeah i checked all the wiring and the fuses... Thanks
siks13sr is offline
post #4 of 6 Old 06-15-2005, 01:19 PM Thread Starter
DLSracing, one more quick question... what do i do with the 1 and 2 wires?
siks13sr is offline
post #5 of 6 Old 06-15-2005, 05:10 PM Thread Starter
Anybody else know... i really need to get this done by tonight...
siks13sr is offline
post #6 of 6 Old 08-11-2011, 05:40 PM
Manubi is on a distinguished road
Points: 414, Level: 8
Points: 414, Level: 8 Points: 414, Level: 8 Points: 414, Level: 8
Exclamation EGI Problem
I know that you are sure of the EGI being the problem (and this tread is a lil old) but I had the same problem last week with my 92 S13 HB. It ended up just being a grounding issue, if you want to check it simply just hook up jumper cables to your car battery normally and then connect the other ground connector to the body of your car (if this dont work connect the ground to your engine) and try to start it. *** Warning *** DO NOT let the power cable connect with your car as this could cause cool but unwanted effects to your car.
If this works simply run a wire from your body to your engine (0" gauge should do it) and BAM! its fixed!! I hope this helps as it did for me! Saved me like $25 a EGI Relay!
Manubi is offline
Fuel Pump Relay TypeOne General Tech 1 12-20-2004 01:45 AM
fuel pump relay i think ? 95se5384 SR20DE & DET 2 09-19-2004 04:17 PM
fuel pump relay ruthlesstyper SR20DE & DET 1 05-01-2004 05:52 PM
sooo i was installing the fuel pump... OaklandAlive S13 240SX (89-94) 6 04-14-2004 11:29 AM
