heater and a/c make car stall - Nissan 240SX Forums
post #1 of 12 Old 08-28-2006, 05:04 PM Thread Starter
andya32's Avatar
andya32 is on a distinguished road
Points: 2,784, Level: 32
Points: 2,784, Level: 32 Points: 2,784, Level: 32 Points: 2,784, Level: 32
Activity: 40%
Activity: 40% Activity: 40% Activity: 40%
I have a 91 240sx its pretty much stock. The problem is when my car is idleing and i turn the a/c or heat on i hear a horrible screeching noise and the car stalls. Also when im driving and turn the a/c or heat on i can feel the car lag a lot(probably makes noise too). whats wrong with my car?
andya32 is offline
post #2 of 12 Old 08-28-2006, 06:26 PM
LayNLow is on a distinguished road
Points: 3,510, Level: 37
Points: 3,510, Level: 37 Points: 3,510, Level: 37 Points: 3,510, Level: 37
does your ac actually work and blow cold air?
LayNLow is offline
post #3 of 12 Old 08-28-2006, 07:37 PM Thread Starter
andya32's Avatar
Activity: 40%
the ac does not blow cold air. but the heater will blow hot air when im driving but makes my car stall when i push in the clutch and let the rpms drop down to idle
andya32 is offline
post #4 of 12 Old 08-28-2006, 08:35 PM
tyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthy
Your a/c compressor is getting ready to lock up, or the relay that's supposed to increase idle rpm when you turn on the a/c isn't working. If you hear squeeling when you turn on the a/c, that's the belt slipping, trying to turn a compressor that's going bad.
tyrodtom is offline
post #5 of 12 Old 08-28-2006, 09:20 PM
exactly what i was thinking.
take your a/c belt off untill you replace it so you can still drive your car.
LayNLow is offline
post #6 of 12 Old 08-29-2006, 04:17 AM
ricebike's Avatar
ricebike is on a distinguished road
Points: 4,729, Level: 43
Points: 4,729, Level: 43 Points: 4,729, Level: 43 Points: 4,729, Level: 43
you've got a leak... w/ freon, the oil also goes out w/ it...
recharge the system w/ some oil charge as well as some freon & maybe you can still save the compressor...
ricebike is offline
post #7 of 12 Old 08-29-2006, 10:50 AM
diablo_cc's Avatar
diablo_cc is on a distinguished road
Points: 5,354, Level: 47
Points: 5,354, Level: 47 Points: 5,354, Level: 47 Points: 5,354, Level: 47
i have the same problem with the rpms dying when the a/c is on.
it also makes a weird clicking noise that corresponds with the rpms dropping and raising
wtf?
LNC#5
diablo_cc is offline
post #8 of 12 Old 08-29-2006, 12:54 PM
That clicking noise is probably the electric clutch on the ac compressor engaging and disengaging.
tyrodtom is offline
post #9 of 12 Old 08-30-2006, 08:07 AM
If you don't intend to fix your AC just unhook it, there's a connector right behind the ac clutch, unhook it, or take out the ac fuse.
tyrodtom is offline
post #10 of 12 Old 08-31-2006, 12:19 PM
diablo_cc's Avatar
yeah, if you look at the compressor while it's running, you can see where it stops engaging for a second, starts again, stops again, etc.
really annoying is what it is
LNC#5
post #11 of 12 Old 08-31-2006, 01:22 PM
Dolby109 is on a distinguished road
Points: 9,802, Level: 66
Points: 9,802, Level: 66 Points: 9,802, Level: 66 Points: 9,802, Level: 66
Activity: 50%
Activity: 50% Activity: 50% Activity: 50%
Or pull the AC out all together...it runs on its own belt.
Save some weight
90 Nissan 240SX - SR20DET swap
Mods: Full rebuild with ARP head and rod bolts, 3" exhaust, K&N filter, E-fans, and a Walbro 255lph fuel pump.
Dolby109 is offline
post #12 of 12 Old 08-31-2006, 01:28 PM
s13bdafocker's Avatar
s13bdafocker is a splendid one to beholds13bdafocker is a splendid one to beholds13bdafocker is a splendid one to beholds13bdafocker is a splendid one to beholds13bdafocker is a splendid one to beholds13bdafocker is a splendid one to behold
Points: 5,057, Level: 45
Points: 5,057, Level: 45 Points: 5,057, Level: 45 Points: 5,057, Level: 45
i had the same problem i just cut the ac belt off
s13bdafocker is offline
Nissan 240SX Recalls and TSB(All Years) Neo Nissan 240SX F.A.Q 4 06-05-2007 09:08 AM
Fuel mixture too rich? OaklandAlive S13 240SX (89-94) 2 03-29-2004 09:16 AM
You might own a dsm if... ASK3XD General Automotive 67 01-13-2004 02:51 PM
can u put a/c into a car that didnt have a/c? TheSparo S13 240SX (89-94) 4 02-12-2003 10:00 PM
