"air tight" upper radiator hose - Nissan 240SX Forums
post #1 of 15 Old 05-25-2007, 12:37 AM Thread Starter
blackrms13's Avatar
blackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthyblackrms13 The posts made by this user are trust worthy
Points: 1,561,599,261, Level: 100
Points: 1,561,599,261, Level: 100 Points: 1,561,599,261, Level: 100 Points: 1,561,599,261, Level: 100
so my car overheats every other month or so, normally i just bleed the system, and its fine
but this time i want to fix it, not just a temporary solution
when the car overheats, the hose is all squeezed up
but after i let it cool down, open up the cap, the hose goes back to normal
i dont notice this when the car is in "normal" condition
i duno if this help, but the lower radiator hose is cold after i have driven the car for a period of time
what could be wrong?
its a 91 hatch, stock KA if that makes a difference
blackrms13 is offline
post #2 of 15 Old 05-25-2007, 12:45 AM
stinky_180's Avatar
stinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthystinky_180 The posts made by this user are trust worthy
Points: 1,427,674,275, Level: 100
Points: 1,427,674,275, Level: 100 Points: 1,427,674,275, Level: 100 Points: 1,427,674,275, Level: 100
Activity: 11%
that is a very interesting problem of yours. i have never seen a radiator hose like that. is your thermostat in working order? whats the max psi on your radiator cap?
noobs click ->
Zenki REPRESENT!!!
RHS13: Back to wrenching! Now a happy owner of a Subaru WRX Wagon!!
Mountain Biking is AWESOME!
stinky_180 is offline
post #3 of 15 Old 05-25-2007, 01:16 AM Thread Starter
blackrms13's Avatar
the guy i bought the car off from said he replaced the thermostat, i hope he did put it in the right way...he has another s13 with RB...so i think he knows whats up and what not
as for the cap....let me go check
Edit
13lb and .9
post #4 of 15 Old 05-25-2007, 01:39 AM
nopistons93 is on a distinguished road
id say maybe time to replace the rad. sounds like its getting too filled with junk if your car is always over heating
nopistons93 is offline
post #5 of 15 Old 05-25-2007, 01:57 AM
bakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthybakgwailo The posts made by this user are trust worthy
Points: 193,315,743, Level: 100
Points: 193,315,743, Level: 100 Points: 193,315,743, Level: 100 Points: 193,315,743, Level: 100
is it leaking coolant ? could be the water pump going...
But, a new thermostat is like 5-10 bucks, might as well try it, or a new radiator cap.
bakgwailo is offline
post #6 of 15 Old 05-25-2007, 02:48 AM Thread Starter
blackrms13's Avatar
replace the radiator eh
supposedly there is alot of rust in it from what the previous owner said
its leaking oil...but not coolant, no milky oil
post #7 of 15 Old 05-25-2007, 03:25 AM
tallic_red240sx's Avatar
tallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthytallic_red240sx The posts made by this user are trust worthy
Points: 644,286,797, Level: 100
Points: 644,286,797, Level: 100 Points: 644,286,797, Level: 100 Points: 644,286,797, Level: 100
Activity: 18%
Activity: 18% Activity: 18% Activity: 18%
dude i had the same problem over the winter. the hose you have on there probably isn't the one intended. Go to autozone or whatever and get a new 240sx upper hose, believe me the hose is your issue.. I replaced my hose after i had your issue and haven't overheated since.. gl
tallic_red240sx is offline
post #8 of 15 Old 05-25-2007, 03:38 AM Thread Starter
blackrms13's Avatar
that could be a solution...
ill try that out
post #9 of 15 Old 05-25-2007, 04:13 AM
PacificKnight is on a distinguished road
Points: 2,894, Level: 32
Points: 2,894, Level: 32 Points: 2,894, Level: 32 Points: 2,894, Level: 32
yes get a hose! obviously that is part of your prob. Hoses are engineered to withstand certain pressures and what not. also since your pretty much stock, and your radiator isnt leaking, tak it to a radiator shop and have them flush it.
PacificKnight is offline
post #10 of 15 Old 05-25-2007, 08:57 AM
tyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthytyrodtom The posts made by this user are trust worthy
I've never seen a upper radiator hose do that, i've seen it happen to the lower hose when someone leaves the coil spring out of the hose. You could prevent this just by putting one of the springs that most lower hoses has in them. But you need to find out where the vacuum in your cooling system is coming from. Your radiator cap should relieve that vacuum, check or replace your cap. The collapsed hose isn't the problem, it's just a sign that your cooling system is losing water, then your radiator cap isn't relieving the vacuum that results from the lose of that coolant.
tyrodtom is offline
post #11 of 15 Old 05-26-2007, 04:11 PM
ChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthyChrisCheezer The posts made by this user are trust worthy
Points: 205,740,948, Level: 100
Points: 205,740,948, Level: 100 Points: 205,740,948, Level: 100 Points: 205,740,948, Level: 100
Yeah that Hose is DEAD!!
that hose died like 10k miles ago..
ChrisCheezer is offline
post #12 of 15 Old 05-26-2007, 11:25 PM
EviL inside's Avatar
EviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthyEviL inside The posts made by this user are trust worthy
Points: 187,597,652, Level: 100
Points: 187,597,652, Level: 100 Points: 187,597,652, Level: 100 Points: 187,597,652, Level: 100
i've seen that before, but only after the car had cooled down.
the tube to the overflow from the neck was plugged up. try blowing through the tube from the reservior end with the cap off,,and replace the cap with a new one. (cheapest and easiest things first)
EviL inside is offline
post #13 of 15 Old 05-27-2007, 10:43 AM
The hose is meant to withstand pressure, that's true, but any hose, new or old, of that diameter is going to get sucked together if there is a vacuum present. Don't just throw new parts at it, find out why there is a vacuum present in you cooling system, where does the coolant go. The collasped hose is the symptom, you need to find the problem.
tyrodtom is offline
post #14 of 15 Old 05-27-2007, 12:27 PM
dopeassjackson is on a distinguished road
you defenatly need a new T stat. if your lower hose is cold its not opening. its probaly in backwards or somthing
Tein S tech springs
stage 3 clutch (pro clutch)
ported head and secondaries removed
Z32 fuel filter
B&M short shifter
JGS motor mounts
dopeassjackson is offline
post #15 of 15 Old 05-27-2007, 01:57 PM
SkItzS13's Avatar
SkItzS13 is on a distinguished road
Points: 5,452, Level: 47
Points: 5,452, Level: 47 Points: 5,452, Level: 47 Points: 5,452, Level: 47
mine did this when i first got mine we replaced the hoses radiator water pump and the thermostat and then it still did it. we did a compression test it came out just fine. all mine was was an air pocket in the motor the radiator burped one good time and never had a problem after that. we let it run for about 10 min with out the radiator cap on and that seemed to fix the problem.
SkItzS13
1990 240SX Hatchback
SkItzS13 is offline
Upper Timing Chain Fix Photos PaulWard S13 240SX (89-94) 23 05-22-2009 02:39 PM
timing chain upper broke?? : ( I need SR20 S13 240SX (89-94) 74 10-30-2004 02:21 AM
Help... Upper Timing Cover. deathkeeper S13 240SX (89-94) 4 08-22-2004 11:00 PM
noise under the hood! szucceed General Tech 49 02-20-2004 01:13 PM
Tein Coilovers: With or W/O Upper Mounts? Jimmyg41 S14 240SX (95-98) 1 04-18-2003 12:06 AM
