RB25Det Question - Nissan 240SX Forums
S14 240SX (95-98) Technical Questions Specifically for ALL S14's. (Including 200SX's & Silvia's)
post #1 of 7 Old 08-26-2007, 04:26 PM Thread Starter
sr20det66's Avatar
sr20det66 is on a distinguished road
Points: 2,530, Level: 30
Points: 2,530, Level: 30 Points: 2,530, Level: 30 Points: 2,530, Level: 30
Angry RB25Det Question
ok i have a question i have a rx25det stock and i want to know the maximum amout of hp the stock motor can take and the maximum amount of boost it xan take of coarse i will get wider pipes for intercooler and exhaust and that about it i want to put a garret gt4094r with a .95 turbo housing will that work and boost about 20 psi
sr20det66 is offline
post #2 of 7 Old 08-26-2007, 06:11 PM
sandreezy is on a distinguished road
i think it can handle 300-350 on stock internals and max safe boost would be around 14
buut im sure im wrong so someone correct me
sandreezy is offline
post #3 of 7 Old 08-27-2007, 12:08 PM
rhyderofthastor is on a distinguished road
from what I remember, the highest safe numbers a stock bottom end rb25det would be 450-500, anything after that is a gamble because of the ring-landings. Max boost on a stock rb25 turbo is 14psi, but even at that the turbo's been known to blow because of the ceramic wheel's inability to withstand higher boost. keep a stock turbo at 12 to be safe. As for the aftermarket turbo... make sure you have all the proper supporting mods like injectors, engine management, etc. and have replaced the basic parts that came on the motor (i.e. water pump, belts, oil pump, etc.) before you upgrade the turbo.
rhyderofthastor is offline
post #4 of 7 Old 08-27-2007, 12:09 PM
300Plus.net is on a distinguished road
you should do alot more searching before cranking the power... but I've scene an RB25 on bone stock internals even the original head gasket and timing belt put down 587hp. Have the dyno sheet to prove. he held the record with highest stock rb25 horsepower for awhile and was beat by a stock rb25 with a shot of NOS that put down like 605 I think...
the 587hp run was at 21 psi I think...
300Plus.net is offline
post #5 of 7 Old 08-27-2007, 12:39 PM
wheresthaboost?'s Avatar
wheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthywheresthaboost? The posts made by this user are trust worthy
Points: 450,851,617, Level: 100
Points: 450,851,617, Level: 100 Points: 450,851,617, Level: 100 Points: 450,851,617, Level: 100
lol
why even post if you're sure you're wrong
you see 500+ hp on stock internal rb's every once in a while but the question is how long will they last..
20 psi aint bad.
RB25 S13 Coupe
wheresthaboost? is offline
post #6 of 7 Old 08-27-2007, 06:49 PM Thread Starter
sr20det66's Avatar
ok guys thanx for the feedback now is the head okay for boost at ariund 15-18 psi with aftermarket turbo i will change the things metioned b4 to new ones if i can find it
post #7 of 7 Old 08-29-2007, 01:46 AM
painsylvio is on a distinguished road
Unhappy Help!!!!
i have a small question to ask you cause you are very helpful, ok you know that the rb25det come with stock 370cc fuel injectors right,if you increase the boost to 13psi or 14psi on the stock turbo, do you also have to increase fuel psi to get hp or onces you increase the boost you will automaticly get hp, also does this work with every car with turbo??? please help
painsylvio is offline
RB25DET Install Question. Chaos The Xile General Tech 4 11-12-2005 02:41 AM
MAF question rb25det 240z4u RB Tech 8 01-31-2005 10:45 AM
Rb25det turbo question? spoolrb25 RB Tech 16 11-21-2004 03:24 PM
R33/R34 RB25DET question? Darkwun RB Tech 5 11-12-2003 09:14 AM
The unanswered rb25det question... mmdb RB Tech 9 05-02-2003 11:34 AM
