o2 sensor wire colors and ecu pinout - Nissan 240SX Forums
post #1 of 6 Old 04-27-2008, 06:13 PM Thread Starter
4x4le's Avatar
4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy4x4le The posts made by this user are trust worthy
Points: 1,640,369,272, Level: 100
Points: 1,640,369,272, Level: 100 Points: 1,640,369,272, Level: 100 Points: 1,640,369,272, Level: 100
Activity: 7%
Activity: 7% Activity: 7% Activity: 7%
Well I think I have the wires colors figured out on the o2 sensor but I cant figure out which ones I need to hook up to the ecu. Im not getting any signal to the ecu from the o2 sensor and it has probably been that way since the swap was done. Anyways im wanting to hook it up but the pinout on the ecu is #19 o2 sensor input however I heard that the heater is also controlled from the ecu and I cant find the pinout for it. Is it called something that im just not associating with a sensor heater? I wouldnt think it would be that big of a deal considering it hasnt been hooked up this long and it will eventually get warm anyways, plus that part might actually be working and its just not reading because it isnt hooked up to the ecu. If anyone can help please do.
4x4le is offline
post #2 of 6 Old 04-27-2008, 09:08 PM Thread Starter
4x4le's Avatar
Activity: 7%
Humm, Where I looked it up on the net I believe the person that described the wires was wrong or something.
The wires I have are red, white, and black. hey, does anyone know which wire is for which? Coming off the 02 im having trouble finding out which wire does what and I dont want to hook it up wrong. I think the white is the heater + because I was getting a + signal of 12v when running, the other 2 wires are both getting a ground signal weather its running or not (which is why mine isnt working). I know 1 of them is supposed to be a ground all the time and that is cool, but the other one Im going to have to snip and run to the ecu. I have exhausted myself trying to search and look in my fsm but I cant come up with anything. I have a white wire, white is the heater im almost 100% and I have black and red. My guess would be red but if anyone can confirm I would be thankful! Im waiting for the car to cool off to try again (kinda close to the header and all)
4x4le is offline
post #3 of 6 Old 04-27-2008, 11:24 PM
if its a factory o2 sensor then lambda is white, +12v is red and black is ground.
Black hook up to a ground.
Red connects to pin 102 - EAI control solenoid output - Orange Black
White connects to pin 19 - Lambda - White
Pin 102 is connected to the ignition switch so its switched +12v with IGN
edit: youll need this too
Joel 180 is offline
post #4 of 6 Old 04-27-2008, 11:43 PM Thread Starter
4x4le's Avatar
Activity: 7%
its odd that im getting +12v from the clip that goes to the o2 sensor that will hook up to the white wire. If I were to unplug the clip i would think that the only difference would be that the heater wouldnt be hooked up, right? I think I might just hook the white wire up for tonigt, right to the ecu and have the plug unclipped. Ill try to get my ecu consulted to see if that hooked up the o2 and if it did Ill run the other wires properly. Hopefully there was no damage done to the 02 sensor from it being supplied with 12v where its supposed to be a signal wire.
Just another reason no one should trust jgy customs. Their wiring sucks.
4x4le is offline
post #5 of 6 Old 04-28-2008, 12:09 AM
yeah maybe your loom is ghettoed.
Do a multimeter continuity test from pin 19 to the white plug wire. Unplug the ecu first though.
It is an s13 sr right? cos s14 o2 pins is different (29 and 115) and uses a 2 wire sensor
Joel 180 is offline
post #6 of 6 Old 04-30-2008, 12:54 AM Thread Starter
4x4le's Avatar
Activity: 7%
Yea, its an s13. I think with your help I have it figured out although Ive yet to do what I think need done and hook up the consult to see what it says then.
Thanks for helping though. I seem to never get help when I ask.....
4x4le is offline
sr20det swap step by step? rexbo Nissan 240SX F.A.Q 20 09-06-2005 04:56 AM
pinout for the main ecu harness 95se5384 SR20DE & DET 3 01-17-2005 11:14 AM
Question about swapping blacktopowered3 S14 240SX (95-98) 7 08-19-2004 09:32 AM
Swap Guide!!! NyczDaLe SR20DE & DET 7 06-12-2004 04:41 PM
