sr20det sputtering when boosting - Nissan 240SX Forums
post #1 of 22 Old 05-29-2011, 06:34 PM Thread Starter
davidg01234 is on a distinguished road
Points: 1,759, Level: 24
Points: 1,759, Level: 24 Points: 1,759, Level: 24 Points: 1,759, Level: 24
my s13 sr redtop has been sputtering when i boost and feels like it hits a rev limiter when i step on it. but if i just give it half throttle it will go just fine but when i make the turbo spool it sputters. I cleaned the MAF with crc maf cleaner, put BCPR&ES NGK plugs and gapped them to 28, took off IACV and sprayed it out with carb and choke cleaner, put new 300zx fuel filter and also added a bottle of techron fuel system cleaner...I was running about 12psi on stock maf, injectors, and t25. now it wont boost past 9psi. Also i can air coming from the MBC when the car is idling. I have a HKS ssqv BOV that is ATM not recirculated could that have anything to do with it?
PLEASE PLEASE help!!!
EDIT: I have a walbro 255 fuel pump and FMIC
davidg01234 is offline
post #2 of 22 Old 05-29-2011, 07:11 PM
SRvertS13's Avatar
SRvertS13 is on a distinguished road
Points: 279, Level: 5
Points: 279, Level: 5 Points: 279, Level: 5 Points: 279, Level: 5
I am looking for help for the same problem with my black top. do the rpms drop when you come to stops? mine almost stalls sometimes. i was told i need to recirculate my hks bov, but i think ill try some of the things you did first.
I also have a 255 walbro
SRvertS13 is offline
post #3 of 22 Old 05-29-2011, 07:14 PM
SRvertS13's Avatar
i also can hear my bov leaking when i hit about 3k, the motor starts bogging at 35k.
post #4 of 22 Old 05-29-2011, 08:47 PM Thread Starter
yes mine does that too and yes it is because the BOV i already ordered a recirculation insert for mine
post #5 of 22 Old 05-29-2011, 11:05 PM
Cap'n Slow
RikRong's Avatar
Quoted: 14 Post(s)
RikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthyRikRong The posts made by this user are trust worthy
Points: 2,147,501,985, Level: 100
Points: 2,147,501,985, Level: 100 Points: 2,147,501,985, Level: 100 Points: 2,147,501,985, Level: 100
Activity: 28%
Activity: 28% Activity: 28% Activity: 28%
As for the spark plugs, I always ran BKR6EIX-7 or 8 in my two SR's. However, I think the spark plugs you have are okay, they're just the none iridium NGKs and meant for the SR. The other symptoms you are talking about, sputtering under boost, sounds like fuel cut. Do you have any kind of tune? The FMIC and boost controller might be enough to overload the ECU.
R. Long
Originally Posted by 4x4le View Post
yea, only it is meant to make the undead dead again
RikRong is offline
post #6 of 22 Old 05-30-2011, 12:18 AM
SRvertS13's Avatar
i found a kink in my fuel line right before the filter and it ran a lot better after i fixed it. still bogs though, im going to try the recirculation for the bov and see how it works out. thanks guys.
post #7 of 22 Old 05-30-2011, 12:23 AM Thread Starter
No I don't have any tune but I do have an apexi neo on the way. But either way I NEVER had this problem
post #8 of 22 Old 05-30-2011, 12:26 AM Thread Starter
yup
MAF + non circulated bov= problems. I can't wait for mine to come in
post #9 of 22 Old 05-30-2011, 10:55 AM Thread Starter
Anybody else have any idea?
post #10 of 22 Old 05-30-2011, 11:39 AM
SRvertS13's Avatar
anybody have any pics of what a recirculation kit should look like on an sr20det? i was thinking about making a homemade one for now, bad idea?
post #11 of 22 Old 05-30-2011, 11:45 AM Thread Starter
Just buy one. Its only about 20 bucks
post #12 of 22 Old 05-30-2011, 11:52 AM Thread Starter
All you gotta do is take a hose and run it from your bov and back into the turbo inlet pipe.
post #13 of 22 Old 05-30-2011, 02:47 PM
champ_6 is on a distinguished road
Points: 6,708, Level: 53
Points: 6,708, Level: 53 Points: 6,708, Level: 53 Points: 6,708, Level: 53
The HKS should not be leaking under boost even if it's not recirculated. Do a boost leak test.
champ_6 is offline
post #14 of 22 Old 05-30-2011, 06:33 PM Thread Starter
[QUOTE=champ_6;1634484]The HKS should not be leaking under boost even if it's not recirculated. Do a boost leak test.[/QU
Its not leaking? my turbo xs MBC is leaking when idling. but like i said MAF + ATM BOV will make it not run as it should because the maf can compensate for all the lost air that the bov releases
Also does anybody have a link or a good way to do a DIY boost leak test
post #15 of 22 Old 05-30-2011, 06:36 PM
Take the MBC out and see if your problem goes away. Yes the ATM BOV will cause it go rich for a moment while shifting but it will not cause the car to break up under full throttle
champ_6 is offline
post #16 of 22 Old 05-30-2011, 06:42 PM
IC Pipe Tester
champ_6 is offline
post #17 of 22 Old 05-30-2011, 06:47 PM Thread Starter
awesome thanks. also do you know if its normal to be able to hear air coming from the mbc when the car is just idling? If i turn the screw all the way in it wont do it but when i turn it out to turn up the boost i can hear it leaking at idle
post #18 of 22 Old 05-30-2011, 06:51 PM
Can't say that I've ever heard air at idle. Spray it with starting fluid and see if your engine revs up. If it does then you have a leak there
champ_6 is offline
post #19 of 22 Old 05-30-2011, 06:55 PM Thread Starter
ok ill give that a shot after i go to home depot to make my boost leak tester lol thanks
post #20 of 22 Old 06-06-2011, 02:28 PM
srs13lemy is on a distinguished road
Points: 108, Level: 2
Points: 108, Level: 2 Points: 108, Level: 2 Points: 108, Level: 2
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
iv been having the same issue with my sr.. i did a test on mine found 3 different leaks. the home depot leack tester works grate.
on mine: mbc, bov flange, and turbo hose are leaking. i get that stuttering when im coming to a stop but not at wot. my wot is good...
srs13lemy is offline
post #21 of 22 Old 06-06-2011, 04:02 PM
driftsyndicate's Avatar
driftsyndicate is on a distinguished road
Points: 2,690, Level: 31
Points: 2,690, Level: 31 Points: 2,690, Level: 31 Points: 2,690, Level: 31
leaking coupler
use hairspray on any leaky couplers
werks great
driftsyndicate is offline
post #22 of 22 Old 06-06-2011, 04:51 PM
SilverS13's Avatar
SilverS13 is on a distinguished road
Points: 5,100, Level: 45
Points: 5,100, Level: 45 Points: 5,100, Level: 45 Points: 5,100, Level: 45
Do you have a boost gauge? How much boost are you running? If you don't have one you can't tell how much boost you are running and you might be running too much causing boost cut. Check all vaccum lines and the the intercooler connections to make sure its not leaking from anywhere. When I first put on my s14 turbo the damn intercooler pipe blew off at only 10psi, I had to use T-clamps. Oh yeah one more thing, when was the last time the car had a tune up? One of these is bound to be the problem.
SilverS13 is offline
Boosting up my sr20det ??? Blaze89 General Tech 3 03-31-2010 12:19 PM
sr20det only boosting 6psi all of sudden...... -darren- SR20DE & DET 3 03-23-2006 12:47 PM
sr20det sputtering - vacum leak ? o2 sensor ? Twistex SR20DE & DET 3 02-10-2005 04:16 AM
Car Sputtering, Need Help r34silvia S13 240SX (89-94) 8 06-24-2004 12:57 AM
sr20det not boosting igotswansons SR20DE & DET 3 08-20-2003 05:58 PM
