Have some bad news, but not sure what happened!
I had put about 450 miles on my new motor build, 4 oil changes, 3 filters. Everything going great, running smooth, no problems/leaks/smoking at all. Even did a few mountain road drifts, and everything seemed great. Car has a really good amount of power and I love it.
I attended my first drift event this past weekend and it all went downhill. Car was running great in the morning before my first run, then I did a burnout to warm my tires, and did one drift run (on course less than one minute, varying RPMs through the course), and once it was done the car wanted to almost die, and was smoking. Found out it was burning coolant, and a lot of it. After a minute or two of smoking, it stopped, so I ran the car again. Again, perfect run, car felt great, but afterwards it was smoking, even more this time. so I pulled around to my truck, let it sit at idle, and it was burning coolant just sitting there, and getting very hot (gauge read almost 250 degrees F with electric fans on). After about 15 or 20 minutes, I tried to start it again and it would not even turn over. Friend of mine said hydro-lock due to the coolant in the cylinder. I checked the radiator and it was very cold. Found out I burned almost a whole gallon of coolant.
I got it home, took the head off, and the head gasket (Cosworth) looked to be in great shape, no signs of damage. In fact, no signs of damage anywhere. I have no idea what it could be!!
I attached some pictures. Cylinder 4 was the only cylinder seeing coolant, and cylinder 1 was a bit oily. Have any thoughts on this?? I have a competition event in less than 3 weeks, so I want to get this sorted ASAP...
Setup:
Everything brand new, head and block fully cleaned/decked
CP Pistons, 90mm
Darton iron sleeves
Cosworth HG
ARP studs throughout
BC springs, valves, retainers
Tomei solid head setup with 270 cams
GT2871R on 15psi
Nistune tuning
anything else you need to know, just ask....
Setup:
CP Pistons, 90mm
Darton iron sleeves
Cosworth HG
GT2871R on 15psi
Nistune tuning
