Can a fuel injector really sound like rod knock? - Nissan 240SX Forums
post #1 of 9 Old 08-25-2006, 09:50 PM Thread Starter
FI240SX's Avatar
FI240SX is on a distinguished road
My S13 redtop has a clicking/tapping sound coming from the upper area of the engine. The sound varies in loudness and isn't really based on how hard the engine has been running. I can drive it easy in the city and it could be really loud, or it might be relatively quiet after cruising at a constant 3,000 RPM. When I touch the #2 fuel injector I can almost feel where the sound is coming from. The other injectors don't do it as much. The sound goes right with the RPM; as the engine accelerates, the sound speeds up accordingly. Could the problem really be a bad fuel injector and not something more serious like rod knock or a bad head?
FI240SX is offline
post #2 of 9 Old 08-26-2006, 01:07 AM
Mr.180sx's Avatar
Mr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthyMr.180sx The posts made by this user are trust worthy
maybe you should clean your fuel injectors ... because it could just be dirty causing that cylinder to knock (not rod knock either)
2005 Suzuki GSXR 750 Track/Stunt
2005 Yamaha R6 Track (Black , Tuned , & Modded)
69 Chevy Camaro (Street ) Running Restoration project
Mr.180sx is offline
post #3 of 9 Old 08-26-2006, 02:01 PM
papaganoushh is on a distinguished road
check your valve clearance, you might want to do a valve adjustment
papaganoushh is offline
post #4 of 9 Old 08-26-2006, 04:38 PM
RuskeR's Avatar
RuskeR is on a distinguished road
Points: 16,046, Level: 81
Points: 16,046, Level: 81 Points: 16,046, Level: 81 Points: 16,046, Level: 81
No one in my area that I checked with could clean my stock 370's so I sent them off to deatschwerks.
http://www.deatschwerks.com/
RuskeR is offline
post #5 of 9 Old 08-26-2006, 07:24 PM
ThrowTail is on a distinguished road
Mine and my brothers sr20 makes the same noise from the injector. as so as my freinds s14
ThrowTail is offline
post #6 of 9 Old 08-27-2006, 01:47 AM
Dolby109 is on a distinguished road
Points: 9,802, Level: 66
Points: 9,802, Level: 66 Points: 9,802, Level: 66 Points: 9,802, Level: 66
Activity: 50%
Activity: 50% Activity: 50% Activity: 50%
My injectors makes a clicking noise but its nowhere near as loud as a rod knock, and cant be heard when the hood is closed, esp from inside the car.
If the knock does not get louder with throttle then it is likely top end related (which is better than bottom end).
Do you have an oil pressure guage? You might not be getting a lot of oil to the top end at low rpm. You should get a guage, or remove the valve cover and make sure oil is getting pumped on the cams when the engine is being turned over.
90 Nissan 240SX - SR20DET swap
Mods: Full rebuild with ARP head and rod bolts, 3" exhaust, K&N filter, E-fans, and a Walbro 255lph fuel pump.
Dolby109 is offline
post #7 of 9 Old 08-27-2006, 06:39 AM
Yea as dolby stated the injectors dont sound all that loud. but it makes a little tapping noise. Maybe post up a clip with the noise problem so that we can hear it. somone might be able to give you a better answer.
post #8 of 9 Old 08-29-2006, 02:33 PM
si2die4's Avatar
si2die4 is on a distinguished road
Points: 4,452, Level: 42
Points: 4,452, Level: 42 Points: 4,452, Level: 42 Points: 4,452, Level: 42
You cant do valve adjustments on SR's. They use hydraulic lifters that are self adjusting.
si2die4 is offline
post #9 of 9 Old 08-29-2006, 04:46 PM
IMAGOODDRIVER's Avatar
IMAGOODDRIVER is on a distinguished road
Points: 4,135, Level: 40
Points: 4,135, Level: 40 Points: 4,135, Level: 40 Points: 4,135, Level: 40
yes you can adjust the valve on sr either putting in thikcer shims of cutting the valve. but befor i start drifting off heres what you can do to make sure its your injectors and not sumtin else take a really long screw driver and touch the injector on one side and your ear on the other then you can hear if its the injector or if its sumtin else. be very careful doing this. dont use a short one and burn your fcking face off
IMAGOODDRIVER is offline
sr20det swap step by step? rexbo S13 240SX (89-94) 17 03-06-2012 12:41 AM
Well now I really believe the fuel pump is gone...let me know what you think MaStA S13 240SX (89-94) 3 05-01-2010 12:07 PM
Fuel Problem... Esone3 S13 240SX (89-94) 3 05-13-2009 09:30 AM
1990 240 fuel problem jztt S13 240SX (89-94) 4 07-30-2003 04:27 AM
RB engines, helpful Info / Glossary Shift-Down SR20DE & DET 10 06-09-2003 01:40 AM
