LinkBack (5) Thread Tools
Old 04-05-2008, 02:08 PM   #101 (permalink)
positron's Avatar
positron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthy
Points: 360,054,436, Level: 100
Points: 360,054,436, Level: 100 Points: 360,054,436, Level: 100 Points: 360,054,436, Level: 100
Originally Posted by sleeperhit View Post
Comming along well...perfectly.
Well done man, i'll stay tuned
Btw why havn't you ripped the post office a new one yet?
I called them and complained and they aren't going to do anything about it so I'll be shipping a box of battery acid, fireworks and gasoline next week....sons 'a b!^@&hes!!!! LOL!
"What it do!"
S13 KA24DE Engine Removal http://www.240sxforums.com/forums/do...e-removal.html
S13 SR20DET Prep http://www.240sxforums.com/forums/sr...0det-prep.html
positron is offline   Reply With Quote
Old 04-05-2008, 02:39 PM   #102 (permalink)
Mack Daddy
TomTomTuning's Avatar
TomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthyTomTomTuning The posts made by this user are trust worthy
Points: 842,842,097, Level: 100
Points: 842,842,097, Level: 100 Points: 842,842,097, Level: 100 Points: 842,842,097, Level: 100
This thread is awesome.
Glad to see some one paying attention to the very small details.
My Photography website
www.TomJanz.com
Myspace
TomTomTuning is offline   Reply With Quote
Old 04-08-2008, 11:22 PM   #103 (permalink)
positron's Avatar
Water Outlet
I got bored so I decided to replace the gasket on the water outlet today.
Tools needed:
Socket wrench
Socket extension
10mm socket
Liquid gasket
Razorblade
Absolutely unecessary but I have idle hands sometimes.
Water outlet.
10mm socket removes four bolts on the water outlet here.
Off.
Take a razorblade and remove all traces of the old gasket from the water outlet opening on the block...
and on the water outlet.
Take the liquid gasket and apply a continous bead around the outlet, re-install, place your bolts back on and torque to .64-.85ft.lbs. You can use your telekenetic abilities and torque something to .64ft.lbs....you could blow on something and torque it to .64ft.lbs!
"What it do!"
Old 04-09-2008, 02:17 PM   #104 (permalink)
Incompetent
rexbo's Avatar
Points: 19,989, Level: 89
Points: 19,989, Level: 89 Points: 19,989, Level: 89 Points: 19,989, Level: 89
OCD for the win
http://240sxforums.com/forums/showth...highlight=swap
http://www.kognitiondesign.com
rexbo is offline   Reply With Quote
Old 04-10-2008, 06:27 AM   #105 (permalink)
positron's Avatar
Originally Posted by rexbo View Post
OCD for the win
LOL!
"What it do!"
Old 04-10-2008, 03:48 PM   #106 (permalink)
positron's Avatar
Bolt Replacement
I replaced some of the OEM bolts on my engine with either new OEM or an equal grade parts store equivalent and I thought it might be useful for some people to know which sizes that I used and where to get them if they can't find any.
M8-1,25X30MM
I used these to replace the intake manifold bolts.
I also used one to replace the knock sensor bolt.
M6-1,0X20MM
I used these to replace the bolts for the coilpacks...
and the theromstat housing.
They can also be used to replace the four on the water outlet and the one for the dip stick tube.
M10-1,50X20MM
I used these for the motor mount brackets to the block.
M6-1,0X10MM
I used these for the small bolts on the fuel rail...
and the intake manifold runners.
You can also use one for the coolant bleed screw on the top of the water outlet.
M8-1,25X20MM
You can use these for the intake manifold support brackets...
you can also use them for the water pump...
the battery ground on the intake manifold, the two small bolts on the bottom of the alternator bracket...
mounting the coolant and water lines under the intake manifold to the block...
and for mounting the fuel rail back on the intake manifold.
M8-1,25
These washers are for the intake manifold.
Transmission mounting bracket bolts Part#:01125-S13002 I was missing one when I took out the KA.
Got these from Courtesy Nissan http://www.courtesyparts.com/betasit...1420_1425.html 11340A
Waterpump hardware from West Covina, pump bolts, pulley studs and nuts.
http://www.thenismoshop.com/ikorb.ph...tegory_id=1188
"What it do!"
Old 04-10-2008, 06:32 PM   #107 (permalink)
Points: 394,949,437, Level: 100
Points: 394,949,437, Level: 100 Points: 394,949,437, Level: 100 Points: 394,949,437, Level: 100
Activity: 14%
Activity: 14% Activity: 14% Activity: 14%
does it matter that the plating on the bolts is different?
Old 04-11-2008, 02:11 AM   #108 (permalink)
positron's Avatar
I thought that it would at first because the heads on the bolts are slightly larger than the OEM bolts but so far not in the least. The only one I have a problem replacing is the bolt for the speed sensor because the sensor has a hump that is practically touching the bolt head so you really need a bolt that has a very small head for that one.
"What it do!"
Old 04-11-2008, 03:34 PM   #109 (permalink)
93240marilyn's Avatar
93240marilyn is on a distinguished road
Points: 4,058, Level: 40
Points: 4,058, Level: 40 Points: 4,058, Level: 40 Points: 4,058, Level: 40
i thought the ka injectore were 250cc and the sr ones were 370 cc
93240marilyn is offline   Reply With Quote
Old 04-11-2008, 07:27 PM   #110 (permalink)
Syline is on a distinguished road
Points: 4,552, Level: 43
Points: 4,552, Level: 43 Points: 4,552, Level: 43 Points: 4,552, Level: 43
If you are using steel bolts then they should be cad plated to go into the aluminum. I would either go get some cad plated screws or put the ones you took out back in.
Syline is offline   Reply With Quote
Old 04-16-2008, 03:44 PM   #111 (permalink)
positron's Avatar
Turbo Manifold???
What kind of turbo manifold is everyone running? Originally I was going to go with the all-purpose $150 cheapy brand that is available everywhere but I started reading everywhere about them cracking 6 months down the line so let's just do it right from the get-go yes?! Right now I'm leaning towards the Tomei(a little pricey but), Ichiba, Peak Performance and I found one from DC Sports. HKS and JIC are definitely can't do's.
"What it do!"
Old 04-16-2008, 05:14 PM   #112 (permalink)
OpenThrottle's Avatar
Points: 574,627,366, Level: 100
Points: 574,627,366, Level: 100 Points: 574,627,366, Level: 100 Points: 574,627,366, Level: 100
if you can i would go with the Tomei unit, havent seen the Ichiba one, but when i got my megan the guy at heavy throttle told me that the Peak Performance and the Megan one are the same, i was originally gonna go with the peak performance one but heavythrottle said they were out so then the guy told me about the megan one.
OpenThrottle is offline   Reply With Quote
Old 04-16-2008, 07:27 PM   #113 (permalink)
I R Slacker's Avatar
I R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthyI R Slacker The posts made by this user are trust worthy
Points: 306,364,120, Level: 100
Points: 306,364,120, Level: 100 Points: 306,364,120, Level: 100 Points: 306,364,120, Level: 100
Awesome thread man! You're doing a good job. I am going to keep updated, I Want videos of when it fires the first time
* It's not turbo lag, it's fore play. *
* Positive Intake Manifold Pressure *
I R Slacker is offline   Reply With Quote
Old 04-17-2008, 07:43 AM   #114 (permalink)
positron's Avatar
Dude, I'm so back and forth on this issue. Yesterday afternoon I was all for the Tomei but after talking to some gearheads lastnight, they told me that for the kind of driving that I was planning to do the Tomei would be overkill and that I could get by with the Megan so now I'm back on that kick.
Originally Posted by I R Slackere View Post
Awesome thread man! You're doing a good job. I am going to keep updated, I Want videos of when it fires the first time.
Thanks and I will do that!
"What it do!"
Old 04-17-2008, 08:57 AM   #115 (permalink)
Car Crazy Curry's Avatar
Car Crazy Curry is an unknown quantity at this poINT
Points: 3,875, Level: 39
Points: 3,875, Level: 39 Points: 3,875, Level: 39 Points: 3,875, Level: 39
Where did you get the aluminum bushing? The S13 I just bought already has the engine out and the bottom half of the steering disconnected cuz the rednecks who pulled the motor out though you had to do that to get it out. So basically now would be the perfect time to do the bushing while I'm saving for my SR.
Car Crazy Curry is offline   Reply With Quote
Old 04-17-2008, 09:04 AM   #116 (permalink)
positron's Avatar
I think I got that bushing from Phase2motortrend if I remember correctly but you can get them almost anywhere S13 parts are sold these days.
"What it do!"
Old 04-17-2008, 11:32 AM   #117 (permalink)
Smokey902's Avatar
Smokey902 is on a distinguished road
ok i'm goin way back to the first page. but that mean green stuff is that safe for hoses and plastics???
btw way to fuckin go dude great great GREAT job on this
Smokey902 is offline   Reply With Quote
Old 04-17-2008, 12:00 PM   #118 (permalink)
positron's Avatar
Thanks, as far the Mean Green on hose and plastics, I used it to clean the dirty intercooler piping which is plastic, couplers, IACV hose, intake hoses and it didn't damage them in any way. It did get them very clean though.
"What it do!"
Old 04-17-2008, 06:27 PM   #119 (permalink)
Incompetent
rexbo's Avatar
My boss is running the tomei manifold and turbo elbow on his S14 SR and it sounds great, spools fast, is very compact and hasn't cracked, leaked or otherwise caused any issues so far.
No word on the megan one though!
Old 04-17-2008, 08:06 PM   #120 (permalink)
go with the megan mani and a tomei/greddy turbo outlet pipe. it will save you some money and the megan one isnt that bad, then when you have enough money saved up to fully build that oh-so-sexy engine of yours, then go all out (those are my plans, just gonna enjoy it until then)
Old 04-17-2008, 10:58 PM   #121 (permalink)
positron's Avatar
Thanks for the input rexbo.
Yeah, that did cross my mind...if I were to upgrade the turbo later on then would be the time to go all out!
"What it do!"
Old 04-19-2008, 03:16 PM   #122 (permalink)
positron's Avatar
Went to the junkyard today to help a friend pull the head off a 1st gen Integra and while we were at it I noticed a purple 2nd gen Altima sitting a couple of feet away. When we were done I went over and popped the hood, the radiator was gone but what did I find just sitting in the bay....
this set of Altima fans in great condition.
I'm not sure if this is the set that everyone uses but we tested them at the junkyard, they both run and I only paid $40 for them so if this is the correct set then I came out on top. If these are the right fans I'm gonna clean them up and sell the Permacool.
"What it do!"
Old 04-19-2008, 03:25 PM   #123 (permalink)
allntrlundrgrnd's Avatar
allntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthyallntrlundrgrnd The posts made by this user are trust worthy
Points: 1,824,154,050, Level: 100
Points: 1,824,154,050, Level: 100 Points: 1,824,154,050, Level: 100 Points: 1,824,154,050, Level: 100
Activity: 16%
Activity: 16% Activity: 16% Activity: 16%
nice find! whats the deal with the asymmetrical fans? the ka clutch fan is like that too.
Originally Posted by winkdogydog101 View Post
coilovers are for retards unless you have 400+whp
allntrlundrgrnd is online now   Reply With Quote
Old 04-19-2008, 03:30 PM   #124 (permalink)
positron's Avatar
Agreed! I noticed that also...what's up with that? Is it a air flow thing or something?
"What it do!"
Old 04-19-2008, 04:17 PM   #125 (permalink)
40 bucks dang thats not bad i gotta get me some. thats the last piece i need for my swap. nice find.
LinkBack to this Thread: http://www.240sxforums.com/forums/sr20det-engines/107130-my-s13-sr20det-prep.html
Bolt holding plate (oem NISSAN) - Miata Turbo Forum - Home of the turbo Mazda Miata. This thread Pingback 07-20-2009 05:14 PM
A32 Gauge cluster removal - Howto (lots of pics) - Maxima Forums This thread Refback 07-11-2009 01:11 PM
Marino's S13 This thread Refback 06-10-2009 09:54 PM
2000 Integra Motor Oil Weight, 2000 Infiniti I30 Manual, 2000 Isuzu Rodeo Hydraulic Clutch Bleeding - 1985Bmw This thread Refback 03-08-2009 04:32 AM
Nexopia This thread Refback 12-30-2008 06:27 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
s13 sr20det vs. s14 sr20det in s14? keioffice SR20DET Engines 14 01-13-2008 04:42 AM
FS: S13 parts and stuffs. You buy now kazuo For Sale and Wanted 4 04-06-2006 04:55 PM
s13 and s14 oem parts!! 180sxjdm For Sale and Wanted 5 01-30-2006 11:10 PM
s13 sr20det into a 95 240sx sr240-drifting SR20DET Engines 7 07-31-2005 07:13 PM
s13 sr20det mods list stealths13 SR20DET Engines 7 08-29-2004 06:29 AM
Nissan 240SX Forums Home Index - Nissan For Sale - Archive - Privacy Statement
