LinkBack (5) Thread Tools
Old 04-19-2008, 04:25 PM   #126 (permalink)
positron's Avatar
positron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthypositron The posts made by this user are trust worthy
Points: 360,054,436, Level: 100
Points: 360,054,436, Level: 100 Points: 360,054,436, Level: 100 Points: 360,054,436, Level: 100
I checked the other Altimas to see if there were more fans just in case some fellow swappers were interested but there weren't anymore.
"What it do!"
S13 KA24DE Engine Removal http://www.240sxforums.com/forums/do...e-removal.html
S13 SR20DET Prep http://www.240sxforums.com/forums/sr...0det-prep.html
positron is offline   Reply With Quote
Old 04-19-2008, 04:43 PM   #127 (permalink)
S13ontap's Avatar
S13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthyS13ontap The posts made by this user are trust worthy
Points: 431,383,509, Level: 100
Points: 431,383,509, Level: 100 Points: 431,383,509, Level: 100 Points: 431,383,509, Level: 100
you deserve a metal. this is beautiful and inspiring
I'd Rather Buy Parts, Than Eat.
1996 EK- J Swapped V6 Civic (Yeah, That's Right)
1991 S13 - T28 _ Always Broken (Built Blacktop Soon)
1994 EG- T35 B20, (Type-R head soon)
1998 S14 - VK56DE (SOLD INCOMPLETE) <-Gay
1990 R32 - Skyline GT-R - SOLD
S13ontap is offline   Reply With Quote
Old 04-20-2008, 05:37 AM   #128 (permalink)
positron's Avatar
Fan
I had originally bought a 14" Permacool fan that I planned to use for my swap but after doing some research and a stroke of luck, I was able to nab an Altima dual fan set-up instead.
Koyo rad, Altima fans and the Permacool.
The dual Altima fans cover the entire surface area of the radiator, as a matter of fact, they hang over a bit which is where you might run into a slight complication.
The Altima fans don't exactly line up with all the mounting points on the Koyo radiator so it doesn't sit flush against the rad. This is where you have to mod it for fitment. This is where I didn't want to go, if I have to mod this thing and couldn't do a clean job I was planning to just go with the Permacool setup or just wait and save for the Flex-a-lites which to my knowledge have no fitment issues.
The upper left mounting point fits perfectly, all I will need to do here is place a bolt to mount the fan to the Koyo.
The upper right mounting point does not line up, I also thought I might have to trim this off because of the radiator bracket but we'll get into that later.
The lower left mounting point does not line up with the bracket on the Koyo or sit flush either. It overlaps so the little tab just will not go into the slot as you can see here.
The lower right mounting point also does not line up or sit flush against the radiator.
As you can see here the fan is blocked by the lower radiator outlet and will need to be modded.
I figured the easiest way would just be to trim the plastic just enough to allow the fan to sit flush against the radiator, time to use the knife again.
I started with the lower left mounting point first.
I just sawed into it from all directions until it was loose enough to snap off.
This is how much I took off.
Next, I went to the lower right mounting point.
It's blocked by the lower radiator outlet...
and just needs a small wafer of a section trimmed off to allow the flushness.
Complete!
While I was at it I decided to mount the radiator brackets on because I was also worried that because the mounting points didn't line up then the rad brackets would also block the fan from sitting flush but they did not interfere at all.
As I said before the upper left mounting point lines up perfectly, you can bolt it in and the rad bracket does not interfere.
The upper right mounting point does not line up to where you can bolt it to the rad but it also does not interfere with flushness. The rad bracket can be mounted without any problem. You are left with this mounting point sticking out above the rad. You have the option to shave it off also since it's not needed but it's not necessary.
When I was done trimming the excess plastic off, I just took a sanding block and sanded the edges down smooth for a cleaner look.
With all the trimming done the fans now sit flush against the radiator. All I have to do now is get some of those ties that they use for mounting the rads and wire it up...
but before I did that I decided to break it down and clean it up first.
All you need is a 10mm socket. For the fans there is one 10mm nut holding them in.
And for the fan motors there are three 10mm bolts holding them in.
TO BE CONTINUED.....
"What it do!"
Old 04-26-2008, 08:13 AM   #129 (permalink)
positron's Avatar
Spark Plugs
I got a set of spark plugs in today, here's what I did.
Tools needed:
Socket wrench
Spark plug extension
16mm spark plug socket
10mm socket
Canned-air
Spark plug gapper
Before I got serious about doing a SR swap I called myself buying up parts for the intended swap even before getting the engine....big mistake. I did no research, didn't know exactly what I needed and wound up with a couple of useless parts so anyone who plans on doing this who doesn't have a good understanding of auto mechanics, aka "shadetree mechanic" like me, make sure you do your research so you don't waste time and money on parts that you don't need. Because of my impatience....
I now have two sets of plugs one of which is completely useless to me.
BKR6EIX Stock#:6418-stock boost. Heat range=6
BKR7EIX-Mild hp. Heat range=7
BKR8EIX-Heavily modified, high hp. Heat range=8
I'm planning to run a stock boost, stock engine setup so this is the set that I need. I got this set from FRSport.com and they come pre-gapped for a plug and play install.
This is the set that I bought before. Came to find out that they are not what I'll need and they are gapped to .040. BKR5EIX-11 Stock#:5464?????
Let's get started. Get a allen wrench to remove the spark plug/coil pack cover. There are six allen head bolts.
Use a 10mm socket or a screwdriver to remove the coilpack bolts from the valve cover.
Pull the coilpacks out one at a time. I think some people disconnect the harnesses from the coilpacks before pulling them.
You can see the plugs deep down in the block.
Take a can of compressed air and blow out the well to remove any debris that could get into the chamber once you take out your plugs.
16mm spark plug socket and spark plug extension.
Take your spark plug socket...
and place it in the well.
Remove the spark plug.
Pull it out. Remove all four plugs.
New plugs versus old plugs. I looked it up but I still can't judge the condition of these pulled plugs. From what I read they seem to be normal or maybe carbon fouled...I can't tell...anyone? Here's the breakdown.
NORMAL PLUG-Light tan or gray deposits on the firing tip.
CARBON FOULED PLUG-Identified by soft, sooty black deposits, may indicate an improperly tuned vehicle. Check the air cleaner, ignition components and engine control system.
PHYSICALLY DAMAGED PLUG-May be evidence of severe detonation in that cylinder. Continued detonation could not only damage that cylinder but the engine as well.
OIL FOULED PLUG-Indicates an engine with worn piston rings and or bad valve seals allowing excessive oil to enter the chamber.
EXTREMELY GAPPED DISTORTED PLUG-Has been left in the chamber for too long as indicated by an extreme gap. These could cause misfiring and stumbling accompanied by a noticeable lack of power.
Take the new plugs and insert it into the socket.
In order to avoid crossthreading them I seated them by hand instead of using the socket. You can feel when they are properly threaded better this way. Once you get them in, use the socket to tighten them.
Torque the plugs to 14-22ft.lbs.
Installed.
Install the other plugs the same way, reinstall your coilpacks and your spark plug/coil pack cover.
If you have to manually gap your plugs then you can do so with a spark plug gapping tool. You can get them at the parts store for like a buck.
Spark plug gapping tool...also useful to check gapping.
Like I said before, these came pre-gapped to .030 but I checked just in case and they were.
I thought it was cool that these old plugs were NISMO so I decided to keep them. I even cleaned one up and made a keychain out of it.
"What it do!"
Old 04-26-2008, 08:36 PM   #130 (permalink)
positron's Avatar
Altima Fan Modification w/Koyo Radiator
While I had my fans broken down into pieces I thought this would be the best time to experiment with the shroud and see how I could mount it best to the radiator. These modifications were made with the purpose of using the Altima fans on a Koyo Aluminum radiator. Keep in mind that this is a total ghetto-fab job. It works but don't look so good.
Tools needed:
10mm bolts
10mm nuts
Small metal bracket(about an inch in length)
Drill
Zipties
Knife/blade/razor
Sandpaper or a sanding block(medium grit)
I was able to nab a set of Altima fans for use in my swap but the problem is that they don't exactly mount up properly to the Koyo/SR swap unless you modify. Untouched, the fans only line up with the top left mounting point on the Koyo and even then they aren't flat against the rad because of being blocked by the lower portion of the fan shroud sitting on the lower rad outlet and the A/C condenser brackets. I already explained earlier what I had to modify on the lower portion of the fan shroud in order to get the fans to sit flush against the radiator so now I'll go into detail on what I did to get them properly mounted to the Koyo. I was originally just going to use the Permacool fan mounting kit that I had with the zipties but I was informed that because of the wieght of these fans, that would destroy the radiator fins. It's just too heavy to be mounted in that fashion, much heavier than the Permacool.
As you can see here the Altima fans cover the entire surface area of the radiator.
They even over lap a bit on the left....
and on the right side but that's not a problem.
Here are the four points of mounting that I used. This is the upper left side, this is the only mounting point that lined up to the rad mounts.
Just use one 10mm bolt and a small spacer if your bolt is too long to take out the slack.
For the upper left side the mounting point is about a half inch away from the mounting point so what I did was...
Take a one inch piece of metal and line it up to the rad mount and the fan mount...
mark two spots on it for where the holes need to be drilled like so...
and use a drill to make the holes in the metal. I went back and cut off the excess metal...well, I didn't actually cut it because I didn't have a tool so I just bent it back and forth with a set of pliers until it snapped off and then I sanded the edges smooth.
I was able to put the bracket on the rad and the fan mounts diagonally. I used a 10mm bolt and nut on the fan shroud and I used a 10mm bolt on the rad mount with a spacer for the slack.
Front shot.
Top shot. Like I said GHETTO FABULOUSNESS!!!! Bolts not threaded in all the way but that's because I'm not ready to mount it. I still have to put the fans and motors back in....but it works!
While I was doing this I ran into a small problem. The bolt didn't line up straight with the rad mount because the side of the mount on the fan shroud was in contact with the bolt head pushing it to the side.
This was easily fixed by just cutting a small wafer thin piece of plastic off the shroud here and sanding it down smooth thus giving the bolt head plenty of space to be threaded in to the rad. I still need to work on that because it just looks bad!
On the lower left side as I explained earlier in the thread, I just cut a small section off here and sanded it down to sit flush. This needs to be worked on too...even'er out!
And on the lower right side I cut a thin section off so the shroud could fit above the lower radiator outlet.
FOR MOUNTING THE BOTTOM OF THE FAN SHROUD I DID THE FOLLOWING.
Trusty zipties. I figured that since the top of the fan is bolted in nice and tight then I could get away with zips on the bottom.
I'm going to run two to three zipties per side throught the holes in the A/C condensor mounts on the bottom of the Koyo...
and around the fan shroud like so.
Tie them off and cut the excess.
I think that this could work unless the heat takes out the zipties so if anyone has another idea here let me know.
Before I put the fans and motors back into the shroud I decided to work on those cut spots, clean it some more and lay a coat of Krylon fusion on to give it a refresh look.
This stuff bonds pretty good to plastic but the extreme heat will soon take care of that yes....I gave it a shot! Now for the wiring and a fan controller.
TO BE CONTINUED
"What it do!"
Old 04-26-2008, 11:52 PM   #131 (permalink)
Syline is on a distinguished road
Points: 4,552, Level: 43
Points: 4,552, Level: 43 Points: 4,552, Level: 43 Points: 4,552, Level: 43
be very careful with that gapping tool on iridium plugs. That really is not the one that should be used.
Syline is offline   Reply With Quote
Old 04-28-2008, 02:27 AM   #132 (permalink)
positron's Avatar
Noted and thanks!
"What it do!"
Old 04-28-2008, 02:58 AM   #133 (permalink)
Doomie16 is on a distinguished road
i love this thread u know alot man and i def. will check up on this thread good job
Doomie16 is offline   Reply With Quote
Old 04-28-2008, 09:57 AM   #134 (permalink)
OpenThrottle's Avatar
Points: 574,627,757, Level: 100
Points: 574,627,757, Level: 100 Points: 574,627,757, Level: 100 Points: 574,627,757, Level: 100
nice positron keep up the good work
FairLady Z
OpenThrottle is offline   Reply With Quote
Old 04-28-2008, 06:34 PM   #135 (permalink)
Points: 705,718,584, Level: 100
Points: 705,718,584, Level: 100 Points: 705,718,584, Level: 100 Points: 705,718,584, Level: 100
Activity: 12%
Activity: 12% Activity: 12% Activity: 12%
please go and buy a dremel. You are doing all this meticulous work then hacking at plastic with a blunt pocket knife
Old 04-29-2008, 03:26 AM   #136 (permalink)
rexbo's Avatar
Points: 20,703, Level: 90
Points: 20,703, Level: 90 Points: 20,703, Level: 90 Points: 20,703, Level: 90
ahahahaha he's not allowed to have power tools after running naked with the angle grinder.
btw: cut your fingernails, the ladies don't dig the grease-filled crevices
http://240sxforums.com/forums/showth...highlight=swap
http://www.kognitiondesign.com
rexbo is offline   Reply With Quote
Old 04-29-2008, 06:33 AM   #137 (permalink)
positron's Avatar
LOL!
"What it do!"
Old 04-29-2008, 07:53 PM   #138 (permalink)
positron's Avatar
Clutch Pivot Ball...Problem?
I took the throwout bearing off my clutch today and when I removed the fork this came apart. I know nothing of the pivot ball so should I be worried here and what are my best options for a replacement? Will a KA24DE pivot ball work or should I just get one from SPL, Nismo, etc?
"What it do!"
Old 04-29-2008, 09:37 PM   #139 (permalink)
Modrified is on a distinguished road
it broke when you pulled the fork of? wow. just replace it. the spl or nismo are good options. i have the nismo pivot ball and i got it from here
Modrified is offline   Reply With Quote
Old 04-29-2008, 09:52 PM   #140 (permalink)
positron's Avatar
It must have already had a crack in it and been on it's way out so I guess I lucked out on that one so to speak.
"What it do!"
Old 04-29-2008, 10:38 PM   #141 (permalink)
it's a great thing that you didn't just swap everything in right of the bat to your car. lucky you. hehe. removing trannys are not something i look forward to if doing it under the car. haha.
Old 04-30-2008, 03:21 AM   #142 (permalink)
positron's Avatar
Transmission-Dust Collar
I got some parts in today for my transmission.
Tools needed:
Rubber mallet
Block of wood/small hammer
I read that you have to remove the SR dust collar and transfer a KA dust collar to the SR tranny in order to fit the OEM or aftermarket driveshafts on the SR transmission. I banged up my KA's dust collar trying to pry it off so I got a new one to replace it.
Transmission dust collar part#:32135-97L00.
They say use a block of wood but I didn't have one so I just used this small hammer and a rubber mallet. Place whatever you plan to use against the dust collar, whack it...
and it comes off like so.
The SR dust collar on the left is quite noticeably bigger than the KA dust collar on the right.
Wipe the area down.
Put your KA dust collar in and tap it in place.
And you are done.
"What it do!"
Old 04-30-2008, 03:22 AM   #143 (permalink)
positron's Avatar
Transmission-Clutch Slave Cylinder
I swapped out the clutch slave cylinder today. I also swapped out my torn slave cylinder dust collar.
Tools needed:
Socket wrench
12mm socket
14mm wrench
Slave cylinder dust collar Part#:30542-01S00.
Torn slave cylinder dust collar.
To remove it just grab a corner and pull.
New vs. old.
Take an opportunity to clean the area...
and put your new dust collar into place.
Now on to the slave cylinder
Use a 12mm socket to remove the two bolts holding the slave cylinder in.
OEM slave cylinder and Project Nissan stainless steel clutch line.
Crush washer for the clutch line. Part#:46237-S13001
Remove the rubber stopper from the slave unit.
Use a 14mm wrench to put the clutch line in the cylinder.
Got these bolts from Courtesy Nissan, Part#:08121-S13003, but you can also use bolts from the parts store M10-1,50X20MM, the same bolts you can use for the motor mount brackets.
Use your socket wrench to put the new cylinder back onto the transmission and torque to 22-30ft.lbs.
Finished.
TO BE CONTINUED...
P.S.
That rubber stopper on your new clutch slave cylinder is the perfect size to use for blocking that small port on the bottom of the throttlebody that you won't be using.
"What it do!"
Old 04-30-2008, 03:23 AM   #144 (permalink)
positron's Avatar
Harness Clips
While I was ordering some stuff from Courtesy I took a browse through the clip section for the wiring and there are dozens of different clips for this car. I took a chance and ordered one that looked close to what I needed and it turned out to be the exact one. I cut these harness clips when I removed my wiring harness from the engine when I first got it and was just going to use zipties in their place but I found these instead.
Wiring harness clip Part#:24222-S13007
You can use them here on the fuel rail for the injector harnesses.
These zipties have a clip on them so you can clip them in the holes on the brackets.
And here on the those two clips on the front of the engine for the MAF/PS/CAS part of the wiring harness that runs across the front.
"What it do!"
Old 05-01-2008, 02:09 PM   #145 (permalink)
positron's Avatar
Transmission-Gasket Replacement
I decided to see how difficult it would be to replace the gaskets on my transmission while I had the chance so I removed some parts to check the condition of the gaskets.
Tools needed:
Socket wrench
Socket extension
12mm socket
17mm socket
I had a broken clutch pivot ball so I started by removing that.
All you need is a 17mm deepwell socket to remove it.
Next, I decided to check out the front transmission seal and the transmission front cover assembly.
Use a 12mm socket to remove 5 bolts here...
and the front cover assembly comes off.
The seals look fine but if I do decide to replace them does anyone know how I can get them off because there is no where to grab at them like the other seals. I searched but couldn't come up with anything.
The front cover...
and gasket.
There's also a O-ring on the underside.
For the gearbox you need a 12mm socket...
to remove 6 bolts and off it comes.
Underside shot.
Inside shot, really interesting to see the inside of the tranny which is another reason why I decided to check this stuff out.
Also going to replace this gasket.
Finally I will also replace the rear transmission seal.
PARTS ON THE WAY TO BE CONTINUED......
"What it do!"
Old 05-01-2008, 03:26 PM   #146 (permalink)
rexbo's Avatar
B&M Shifter time. GO
Old 05-01-2008, 03:41 PM   #147 (permalink)
Car Crazy Curry's Avatar
Car Crazy Curry is an unknown quantity at this poINT
Points: 3,875, Level: 39
Points: 3,875, Level: 39 Points: 3,875, Level: 39 Points: 3,875, Level: 39
The plug wear looks pretty normal to me. As for the BKR5EIX11 (aka useless) plugs they will fit the stock engine on a 1991-1998 240sx. So they are KA24DE plugs.
I could tell you all my industry secrets but then I'd have to kill you.
Pignose Fan Club Member #293
1989 Piggy Hatch-status: Stripped car and tearing down S14 KA for a rebuild
Car Crazy Curry is offline   Reply With Quote
Old 05-01-2008, 05:55 PM   #148 (permalink)
positron's Avatar
"What it do!"
Old 05-08-2008, 01:13 PM   #149 (permalink)
positron's Avatar
Power Steering Pump Installation???...
I attempted to put my power steering pump on today.
Tools needed:
Socket wrench
Socket extension
12mm socket
14mm socket
Old sock/rag
Rubber mallet...you'll see why later.
I originally received a HICAS P/S pump with this engine set but I don't have HICAS on my car. I could have used it anyway because I found out that you can easily modify a HICAS pump to non-HICAS status.
I also got a set of lightweight pullies to use on this engine and for the life of me, I can't figure out how you could remove the pulley from a HICAS pump as it's not held on with a nut like the other pumps for the SR and KA.
How do you remove this pulley?????
I did read how you could use a KA24DE pump with a non-HICAS SR pump bracket though so after tracking one down from a forum member I attempted to put this setup together.
As you can see here the SR non-HICAS and HICAS pump brackets are slightly different.
The non-HICAS SR bracket on the left is considerably larger than the non-HICAS bracket at the pump mounting point as you can see here.
The KA24DE pump with the SR non-HICAS bracket...
fits perfectly.
Here is where I tried to mount the KA24DE P/S pump on the HICAS bracket...it's too small.
Now it's time to put the pulley on the pump.
If you broke your pump down like I did, make sure you put all brackets back on. This one goes on the rear of the pump...
like so. It has a slot for the tab on the banjo line part of your P/S pressure hose.
I went ahead and put the pulley on the pump, this is where the socket extension and old sock came into play.
Since the pulley will spin, you will need some way to get some leverage in order to tighten and torque the nut down when you install the pulley.
I took a socket extension and in order to keep the extension from damaging the pulley by rubbing up against it, I put something soft around the extension.
Stick the extension through one of the holes in the P/S pulley and you can use your foot to hold the pulley steady while you tighten and torque it to 40-50ft.lbs.
Done!
Next, you will need to mount the P/S bracket back on the block here.
Use a 14mm socket for the three bolts here and torque to 33-44ft.lbs. If you managed to mix up some of your bolts like I did then the bolts that you use for this have 7 on the head.
Next, take the tensioner bracket...
and use a 12mm socket to put two bolts here. If you don't use the OEM bolts you can substitute M8-1,25X20MM from the parts store. Torque the bolts to 12-16ft.lbs.
The extra long bolt that you will use to mount the P/S pump to the bracket has 7B on the head, you can't make it out in this pic but that's what it says.
Spin one of the holes in the pulley and you can insert the bolt through it and into the bracket. Use a 14mm socket to tighten the bolt...
and torque to 23-31ft.lbs.
Am I finished you ask? Painfully no!
It was at this point that I realized that I messed up and left a part off.
This part that the tensioner bracket bolts connect to. Without this part on the P/S pump you can't adjust the tension on the P/S belts...doh! I had to take the pump back off and remove the pulley. After taking the nut off the pulley it's kind of hard to pull the pulley back off the pump so just grab a rubber mallet and whack the back of the pulley and it comes off quite easily without damaging the pulley.
Take the bracket...
put it on like so and bolt it down. Torque the bolts to 10-13ft.lbs.
Sadly after doing this I realized that the KA pump with the SR bracket was not going to work at least not the way I thought it would.
I mounted the pump on the P/S bracket and as you can see here the pump tensioner is no where near the bracket tensioner.
Not even close.
As for the pulley, it won't work either.
It makes contact...and it's not even close to halfway being threaded. I even broke out the OEM pulley and it's even wider than the Greddy unit so no go there.
KA P/S pump with SR bracket=FAIL
Unless someone sees something that I'm just not getting then I'm gonna track down a SR P/S pump to finish this up.
TO BE CONTINUED.......
"What it do!"
Old 05-09-2008, 11:16 AM   #150 (permalink)
minime is on a distinguished road
Damn dude, you're pretty serious about this.
status: SOLD!
minime is offline   Reply With Quote
LinkBack to this Thread: http://www.240sxforums.com/forums/sr20det-engines/107130-my-s13-sr20det-prep.html
Bolt holding plate (oem NISSAN) - Miata Turbo Forum - Home of the turbo Mazda Miata. This thread Pingback 07-20-2009 05:14 PM
A32 Gauge cluster removal - Howto (lots of pics) - Maxima Forums This thread Refback 07-11-2009 01:11 PM
Marino's S13 This thread Refback 06-10-2009 09:54 PM
2000 Integra Motor Oil Weight, 2000 Infiniti I30 Manual, 2000 Isuzu Rodeo Hydraulic Clutch Bleeding - 1985Bmw This thread Refback 03-08-2009 04:32 AM
Nexopia This thread Refback 12-30-2008 06:27 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
s13 sr20det vs. s14 sr20det in s14? keioffice SR20DET Engines 14 01-13-2008 04:42 AM
FS: S13 parts and stuffs. You buy now kazuo For Sale and Wanted 4 04-06-2006 04:55 PM
s13 and s14 oem parts!! 180sxjdm For Sale and Wanted 5 01-30-2006 11:10 PM
s13 sr20det into a 95 240sx sr240-drifting SR20DET Engines 7 07-31-2005 07:13 PM
s13 sr20det mods list stealths13 SR20DET Engines 7 08-29-2004 06:29 AM
