I got some wire so I started on the fan wiring finally.
Tools needed:
Wire cutters
14 guage wire
Butt connectors
I had to decide wether to wire the fan motors for high power or low power and I opted for low power because of people saying that the fan motors burn out prematurely on high power.
+12v blue, (-12v black & -12v green) == low speed
+12v yellow, (-12v black & -12v green) == high speed
(+12v blue & +12v yellow), (-12v black & -12v green) == fans don't spin at all!
Low Speed: blue connects to +12v source, black and green connect to ground.
High speed: yellow connects to +12v source, black and green connect to ground.
These elec fans have 4 wires EACH.
2 go to 12V
2 go to GROUND
Low speed requires ONE 12V lead and ONE ground lead...
High Speed requires BOTH 12V active and BOTH Grounds active.
On my 240 and 200sx have the same color's on the fans and the FSM's state the same pattern.
BLUE & GREEN are the two 12V sources
YELLOW & BLACK are the GROUND sources.
BLUE 12V & YELLOW Ground will give LOW speed
BLUE 12V & BLACK Ground will also give LOW speed
GREEN 12V & YELLOW Ground will also give LOW speed
GREEN 12V & BLACK Ground will also give LOW speed
BLUE 12V & GREEN 12V with YELLOW ground & BLACK ground will give HIGH speed....
Using the provided diagram, it easily explains that there are four wires on each fan motor.
BLUE-12V power
GREEN-12v power
BLACK-GROUND
YELLOW-GROUND
So if I were wiring them for high power I would use all four wires but since I'm going with low power...I'll only use two. One wire for power and one for ground. There didn't seem to be a question as to which set I used so I chose the blue power and the black ground. The green power and the yellow ground will just be bypassed.
14 gauge wire. It seems to be the same guage as the wire that was provided with the fan controller unit.
Butt connectors. You'll need these to wire the fan motors.
Bird's nest!
Fan motors.
These are the two plugs that will need to be rewired.
I took a pair of wire cutters and cut the plugs off.
Like so.
I took a razorblade and cut some of the protective sheath back for some extra work space and bent the other wires out of the way since I'll only be needing the blue and the black. Speaking of those other wires, since I won't be using them should I tape or solder them off anyway? There will be no power running through them as far as I know.
Use the wire cutters to strip the end of the wires.
I started with the power wire first, take a butt connector(16-14) and place the wire in.
Crimp it to 16-14.
Repeat for the ground wire...
as well as the other fan motor.
I'm not certain how much wire I'm going to need to run for this setup so I just cut about a foot and a half, which is probably way too much, but I can always trim it down after the install. You'll need to cut four wires, two for the power and two for the grounds.
I took the first wire, stripped the end...
and inserted it into the butt connector. Crimp to 16-14. Repeat for the other butt connector.
Take the white wire coming from the FAN1 outlet on the fan controller, strip the other end of the EXTRA wire...
insert and crimp to 16-14. Repeat this for the FAN2 white power wire and the other EXTRA wire as well.
These are the three ring terminals provided for ground that came with the fan controller unit.
The grounds will be wired up like so.
Take one of the EXTRA ground wires, strip it, place the ring terminal on and crimp to 16-14.
Repeat for the other fan motors EXTRA ground wire. These will go in a ground spot in the engine bay.
While I was at it, I used the last provided yellow ring terminal for the fan controller unit's power source. Strip, insert and crimp to 16-14. This will be connected directly to the battery and will power the actual DIF fan controller unit which will in turn provide power to the individual fan motors from there...correct?
When I get my battery cables back, I'll post up a test to see if these fans work with this setup.
TO BE CONTINUED...
