I have accumulated so many random parts its rediculous. Was gonna throw stuff away but I figured somebody somewhere might need something I have.
Almost all the pics are posted already on www.myspace.com/phattymarr
You can reach me at pharrphaster@gmail.com
Lets see what all I can remember (I'm sure I'll leave somethings out) If you see something you want in the pics that is not listed just e-mail me about it :
S13
Stock ECU and wire harness from ECU forward (taken out of parts car)
$50 Each or $75 together
Dissasembled engine (beleive its SOHC cause i didnt get the head) have pretty much everything else and auto tranny $50 + Freight
MAS $25
Distributor with plug wires $20
Fuel rail with injectors $15
Alternator and other random brackets and such $10
Random Intimidator intake K&N knockoff $5
Random Pilot Fod lights $10
S14
Both driver and passenger window motors with window track $50 Each
windshield wiper motor $25
2 stock throttle bodies 60mm $25
stock MAS with K&N filter $25
Passenger fender liner $5
White face gauges, the slip over kind $10
3 factory seat belts not sure if they are for the front or back, cant remember $5 Ea
Stock rear bumper and wing $25
Motor mounts $10
300zx all Z32 except stuff with an *=Z31
Basically have a completely disassembled engine with other parts
1 block $50
4 different heads $50/Set
6 valve covers W/Heads
Random stock cams W/Heads
Random piping (see pictures) W/Heads
6 JDM coil packs 40K KM and 6 USDM coil packs $20 Each
Complete Upper Plenum with linkages, both throttle bodies and stock MAS $50
Stock headers and Nissan header gaskets $10
2 Valleys, goes under plenum and between each head W/Engine
Crank angle sensor $50
JDM water pump 40K KM $15
Alternator and other random engine parts $15
5-speed transmission 108K miles $150
Ttops from a 91’ $40
91’ Passenger fender some minor dings and scratches $40
91’Passenger door with some dings $50
91’ Rear Hatch $50
2 driveshafts $40
2 halfshafts $25
Various calipers $10 Each
Stock tie rods, upper and lower control arms for the front and other random suspension stuff $10
Complete rear subframe off a 91’ $75
Differential off a 91’ $200
3 stock wheels and spare $25 Each
*4 stock wheels* $5 Each
240z all except for *=280zx
Driver door with window and window mechanism $35
Whole big box full of all kinds of random body and suspension parts
Shortened struts for SCCA ITS
5 L-24 E88 heads 1 Highly Ported
1 L-24 E31 ITS head less valves $450
5 L-series valve covers $5 Each
Stahl header, high RPM for GT2 $50
ITS or street header $25
Stock oil pan $5
Differential R190 $50
Taillight covers missing center piece $5
4 16x7 old school racing wheels $10 Each
Front grill $15
Passenger headlight bucket $10
*Complete 4-lug suspension from a 76’ all four struts with springs and lower control arms* $50
*Various calipers* $5 Each
*Rear crossmember* $15 Each
*Complete L-28 engine with head and valve cover, no idea of miles* $125
Intake manifold pulled off a 260z with carburetors $40
S13
MAS $25
S14
Motor mounts $10
1 block $50
91’ Rear Hatch $50
2 driveshafts $40
2 halfshafts $25
Stock oil pan $5
Front grill $15
