Im doing an MLS Cometic right now. How should I prep the mating surfaces? I cant bring it to the machine shop. So I need an alternative method. Fine sandpaper? Scouring pad? thanks again.
you have to use it on the front cover part or it will leak oil, and i would go ahead and also use a thin layer on all the oil ports too. i have used the copper spray on 5 cosmetic head gaskets, nun of them had any rubber coating you speak ofNEVER use silicone or liquid gasket on a head gasket.
Liquid gasket on the front cover but on the headgasket is a no no. I too have used copper spray on my personal cometic but the new one i purchased, i scraped my nail on it and it definately has a black rubber residue kinda shit on it. Im going to try this one dry for shits and giggles. Copper spray is perfect on paper gaskets as it is used widely in the OEM industry.... EXCEPT Volvo advises against it on OEM gaskets.you have to use it on the front cover part or it will leak oil, and i would go ahead and also use a thin layer on all the oil ports too. i have used the copper spray on 5 cosmetic head gaskets, nun of them had any rubber coating you speak of
obviously no silicone near or around the pistons.
i owned 2 sr20's myself (one stock with cometic, and one fully build with HKS HG) and have assembled 4 others. all 4 with cometic.the one time i didnt use any liquid gasket on the front cover it leaked, (very slowly but it still leaked) luckly that motor was a friend of mine and he didn't care one bit.Liquid gasket on the front cover but on the headgasket is a no no. I too have used copper spray on my personal cometic but the new one i purchased, i scraped my nail on it and it definately has a black rubber residue kinda shit on it. Im going to try this one dry for shits and giggles. Copper spray is perfect on paper gaskets as it is used widely in the OEM industry.... EXCEPT Volvo advises against it on OEM gaskets.
