241 - 260 of 444 Posts
Currrently reading through the post -- definetly wished i would done hoses when install of mine was being done - especially the 3 side by side next to the right side of the block under the intake - Coolant hoses - but did take 15-20 min to find but found em at o'reillys and one i had to size down cuz it was a weird S
Discussion starter · #243 ·
Fan Controller Continued...
I had the taps on the ecu part of the harness so I tapped into the coolant temp sensor plug part of the harness instead.
Discussion starter · #244 ·
Power Steering Pump Installation???...
I've had every combination of P/S pump and bracket from here to Tucson so I finally thought that I had this pump situation complete.
Tools needed;
Socket wrench
Socket extension
14mm socket
17mm socket
Long socket extension
Old sock(Socko)
I finally got a SR pump with the right bracket so I can mount this pulley and be done with this.
Mount the pulley...
Place the nut on.
In order to keep the pulley from spinning while you tighten it...
I took a socket extension and stuck it through one of the pulley holes.
Put something soft on it to keep it from scratching or dinging up your pulley.
Take a 17mm socket and tighten the pulley.
To torque it up just place it on the ground and use your foot to step on the extension to hold the pulley while you torque the nut to 50ft.lbs.
Done.
The pump is ready to be mounted to the block.
Mount it here and then spin it so you can tighten the mounting bolt.
Use a 14mm socket to torque to 23-31ft.lbs.
After all this trouble I still ran into yet another problem.
This P/S pump adjuster bracket seems to be the wrong one...doh!
TO BE CONTINUED!!!
Discussion starter · #248 ·
I think I got all those brackets and stuff mixed up when I was packing and selling them all off. I probably sold the bracket that I actually needed to keep...doh! I think...I have the SR non-HICAS bracket, the SR non-HICAS P/S bracket for the front of the pump and I believe I switched the HICAS adjuster bracket with the non-HICAS adjuster bracket which is where I'm at now.:smacked49
cant catch a break on that damn P/S pump can you?
Discussion starter · #254 ·
Valve Cover...Continued
I finally got that missing little o-ring/gasket in and a tube of ultra-grey so now I can install this valve cover.
Tools needed:
Socket wrench
Socket extension
10mm socket
Liquid gasket
Rags
The FSM says to use a liquid gasket. I had the black and the red but people on many of the threads that I read up on were using the Permatex Ultra-Grey for this so that's what I chose.
Spark Plug Gaskets part#: 13271-52F00
I'm still not sure what to call this one but it's refered to as "Gasket-Rocker Cover" part#: 13270-53J13.
Like I said before, I had some trouble getting the valve cover to sit flush. Turns out one of the nuts on the oil tube, on the exhaust manifold side, was making contact with the valve cover so I took my dremel and made a cut to keep the tube from touching.
The gaskets will go here.
Take the ultra-grey...
and make a continuous bead on the valve cover and then place your gaskets.
Wipe off any excess liquid gasket, I think I over did it on a couple. With all your gaskets and o-rings on it's time to put the cover on.
The FSM states to put a 3mm bead of liquid gasket on the four half moon sections of the block. Remove any traces of old gasket first.
These two on the front...
and these two on the back.
Take the liquid gasket and make a continuous bead on the half moons...
and place the valve cover on...yeah, that fuel pressure guage is on the wrong line.
Get your hardware ready. Valve cover nuts.
Valve cover washers.
Place the rubber valve cover grommets on.
Place your valve cover washers on.
Place your valve cover nuts on. The valve cover nuts need to be tightened in a specific manner so refer to the FSM.
They get torqued to 2.9ft.lbs and then to 7.2ft.lbs.
Completed.
Next, your brackets for the coolant temp sensor harness and lines for the engine harness/throttlebody lines.
Place the brackets...
and tighten
Done with that.
Complete.
Discussion starter · #259 ·
+92859465036501874658436598346548365034169!!!!!!!!!!:1bowdown
I was just about to say that looks about like the sexiest motor I've seen
PS. how did that post office thing work out? I know you said you called them. did you just send 3 more for powdercoat?
They didn't do nothin! I bought three more washers from someone on a forum and got them powdercoated.
Can't wait to see this get put into a car, Awesome work
Thanks!
Discussion starter · #260 ·
O2 Sensor
I recieved my O2 sensor this morning.
Tools needed:
17mm wrench
O2 sensor socket
Socket wrench
OEM "skinny type" O2 sensor part#: 22690-50F00.
Old sensor vs. new sensor
The sensor goes here in the turbo outlet.
Remove the sensor bung from the adapter.
Place the sensor and screw on tight.
I used a 17mm wrench to tighten. You'll need a O2 sensor socket to tighten to spec with your torque wrench. It gets torqued to 30-44 ft.lbs.
Complete. I am officially done with the exhaust and the intake sides of the block...as far as I know.
