So I went to change my injectors earlier today and was rewarded with about 40psi of gas spraying at me.
The first thing I always do when messing with the fuel system is obviously release pressure so that type of shit don't happen.
Anyways, I just picked up some new injectors and got some fuel line also and replaced all the rubber lines. But after releasing the FP I took off the main feed line that goes into the rail (the one that doesn't go to the FPR) and gas came spraying out like I didn't even release pressure at all?
My first question is, is that normal? And secondly, could that be a symptom of a clogged/blocked FPR (it is connected to vacuum) which would make the engine run really rich?
Thanks guys
Thanks guys
