61 - 80 of 138 Posts
Discussion starter · #61 · (Edited)
i know its been a long time since i updated this...
but for those of you who know my car is down again....it was running good and managed a 11.6
then one night i was foolin around and some how cooked #6 idk if the injector got stuck or what but the compression is down on just that cylinder
the comp #'s were 1-155 2-155 3-165 4-165 5-155 6-105 with oil 120
so i have been talkin to eric @ ericsperformanceparts.com and he hooked me up with a deal on Tomei Pon Cams, CP pistons, Eagle rods, ACL bearings, and an Engine gasket kit
Discussion starter · #62 · (Edited)
cam specs:
Brand: Tomei
Duration Intake: 256
Duration Exhaust: 256
Lift Intake: 8.5mm
Lift Exhaust: 8.5mm
not pictured is the engine gasket kit
more parts on the way....N1 oil and water pumps, Power Enterprises kevlar timeing belt, 850cc SARD injectors, ARP head studs
Discussion starter · #64 ·
hahahahaha dont be a hater evan...remember you got your 1 bar spring now...but i been running 1.5 bar for a while now....:happyfing
Discussion starter · #67 ·
Conrod bearings are in along with ARP main & head studs, timing belt, both N1 water and oil pumps, sard850cc injs, the only thing im waiting on is the 3 longer studs from ARP
the motor is being pulled this sunday and torn down and rebuilt over the next week or so...
Discussion starter · #68 ·
the 3 bolts from ARP were here when i got home...heres a pic of everything layed out...
mmmmmmmmmm sexy. I can't wait to see the actual rebuild.
love the color.lol.thats just sick man.why did you get the arp rud studs?eagle ruds comes with arp from the fab.I had the gt3076 nice turbo to drift.can you take a pic installing the arp main studs?and also this may seem like a stupid question but I speak dif language.This so called arp main bolts are for the crank right?
Discussion starter · #72 ·
yes the eagle rods came with arp bolts so i didnt have to buy them i just listed them in the build...and yes main studs are for the main journals on the motor...ill be posting pics later on this week as i get further along...motor should be out tonight
Discussion starter · #73 ·
motor is out and disassembled pics will be posted later
Discussion starter · #74 ·
heres the pics from last night....
Discussion starter · #75 · (Edited)
some more pics one of the guys took with his cell.... and yes i am standing on the car while its jacked up to level the motor
Discussion starter · #79 ·
Watching you pull it and break it down brings back bad memories for me, but it looks like you're having fun doing it. =)
Thats because your used to everyone else doing your work for you
