no actually it operates off of one cable, so the fact that your trunk still works tells me that the cable itself is fine, which means that A) the cable is mis-adjusted in the push direction causing the gas door to not open or B) the gas door release mechanism is broken
either way at this point you need to pop out the trunk panels and get at it manually
