The car: 1993 240sx SE with a KA
The problem: Loss of power; knocking sound between 2000-3500 rpm (I'm told, thinking, and hoping its a valve issue) I know it's not a rod bearing. Had the oil pan off and everything is tight. Plus, I've put 3 to 4 thousand miles on this car with the knocking sound. Never got worse. Performance hasn't changed since the problem started.
The plan: My friend has a head he's selling me pretty cheap. If it's a valve getting stuck, or the tappet, I want to replace the whole head and do the dual exhaust cam setup while I'm at it.
The questions: What all should I need for this as far as parts go? This is what I'm thinking... if I don't need any of this, let me know as well.
1. Head Gasket
2. Valve Cover Gasket (Mine is twisted and leaks just a little)
3. Exhaust manifold gasket (Yes? No?)
4. Intake manifold gasket (Yes? No?)
5. Head Bolts (Have stock ones now. You can't reuse them, right?)
6. Assembly Lube
7. Oil
8. Coolant
(I'm sure I missed something.)
Thanks in advance
-TMF
1. Head Gasket
6. Assembly Lube
7. Oil
8. Coolant
Thanks in advance
-TMF
