Alright here is the issue
89 hatch with 5 speed swap sr20
the motor was driving fine
then swapped into this chassis
it starts and runs fine holds boost at 5 psi when in neutral
and at idle holds vac at about 18
when the car is driven however it moves very sluggish, it takes a long time to get to 35, and seems like the motor is working harder then everything else and still doesn't move fast.
it has a brand new walbaro 255. fuel filter wasn't changed from the stock one so im not to sure if that's the problem.
any suggestions,
thanks
any suggestions,
thanks
